Topic: do constant strings use RAM? (Read 995 times) previous topic - next topic
thatdude624
I've seen it many times before, where programs use a program memory alternative to Serial.println("text here"); in applications where more RAM is needed. why is it that the compiler makes that use RAM, though? and how exactly does it use RAM?
for example, if the program has many "quoted" (not variable) strings in it, do these all get stored in RAM is does it load a string into RAM when println is called and then unloads it afterwards, or does it keep the last string loaded until the next string related function is called? I'm guessing the first one, but I want to be a bit sure, since I've seen examples that actually copy it from PROGMEM to a global array with a set size, which would just make things worse.
thanks!
PaulS
Quote
The characters have to be stored somewhere. By default that is in SRAM.
Quote
No. The strings are stored in SRAM when the sketch starts.
Quote
No. The string stay in SRAM.
Quote
Not constant strings in print statements.
thatdude624
#2
Feb 13, 2013, 04:01 pm Last Edit: Feb 13, 2013, 04:10 pm by thatdude624 Reason: 1
for every single string in the program? I wonder how my program hasn't run out of memory yet, I have stings all over the place, a few arrays and the SD card library in use, and yet it still runs fine.
if I try to use the F("stringHere") from the sticky in a function, I get this problem:
"cannot convert 'const __FlashStringHelper*' to 'char*' for argument '2' to 'void myFunction..."
so what would be the most effective and easy way to get all my functions to use PROGMEM strings instead?
I'm going to do a quick memory test to see if this is really what happens.
EDIT: sadly, it's true, no matter where the string is. surely the compiler should be able to automatically optimize this or something...
PaulS
Quote
For every unique string, yes.
If you have Serial.print("I got here"); 27 places in your code, there will only be one copy of the string kept.
Quote
Well, stings don't take up as much space as strings.
Quote
You need to overload your function, as the Print class has, to support the F() macro.
Quote
There was a clue above.
thatdude624
Quote
is F the same as PSTR? I can only find information on that function on Google.
James C4S
It is from WString.h:
Code: [Select]
class __FlashStringHelper;
#define F(string_literal) (reinterpret_cast<const __FlashStringHelper *>(PSTR(string_literal)))
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
thatdude624
Alright, in the end I decided to use this:
Code: [Select]
#define P(str) (strcpy_P(bufferA, PSTR(str)), bufferA)
where bufferA is
Code: [Select]
char bufferA[32];
and was already in use in my program as a general purpose text holder that holds data for short/very short periods of time (for example, as an alternative to returning a delay). It works, thanks!
Khalid
except //comments everything takes space...
Simply...You can't afford me..
Author Of:
http://my-woodcarving.blogspot.com/
http://www.free3dscans.blogspot.com/
http://my-diysolarwind.blogspot.com/
Oops..some one gave me Karma...:)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
