Topic: Boe-bot for arduino roaming with ping on servo turret (Read 9821 times) previous topic - next topic
S_Flex
as an alternative I been working on this sketch so i at least have some thing to work with.
The only lesson I have learned from this bot is to beware of what shield you buy for arduino. Unfortunately I do not own the boe-bot to return it and was helping a friend understand how it works and why it has this flaw.
Maybe time will tell if parallax is trying  to just make a buck or rely wants to support the products they sell.
I hope this code helps others.
Code: [Select]
Current Version: 2.0 (2/13/2013) Not tested
BOE Shield code from "Robotics with the BOE Bot"
Roaming With Whiskers source, modified to use a PING)))
sensor on the PING))) servo bracket.
Using code from the Ping))) example sketch.
http://thoughtfix.com/blog/2012/3/25/arduino-boe-shield-ping-and-a-servo.html
Ping view angles, 125 or maybe 115 degree's, 45 can be wrong too maybe 35 will work
                 centerDist
  leftDist2=125      90       45=rightDist2
leftDist=160 <---------------> 20=rightDist
Flex - changes (2/13/2013) v2.0
- added 45 degree turns
- made the ping() function move the turret to the angle with delay then return the ping
- Removed Look forward function since ping() does the work now
- LookAround() has 2 new angles so 45 degree turns can be done and added the new ping method
- Added 45 degree turn logic to loop() before the 90 degree turning logic so small turns can be done first
- Fixed the code so it doesnt go forward if the safe distance is equal to the center distance.
- Removed some variables that where not used
- Removed microsecondsToInches() function and moved the math in ping.
- Removed forward(),turnLeft(),turnRight() and backward() functions
- Added function move_or_turn(time, task) this will do all the movement.
- Added LengthConversion variable with notes to set length to inches or centimeters
- Changed logic so the code does not favor one direction then another and turns to the true max distance
Flex: Found code, did some small changes and am starting the version number at v1.0
// Servo calibration values, Not used, can be if needed.
const int max_LeftSpeed = 100;
const int max_RightSpeed = 200;
const int servoLeftPin = 13;                 // I/O Pin constants
const int servoRightPin = 12;
const int servoTurretPin = 11;
const int pingPin = 10;
const int piezoPin = 4;
const int LengthConversion = 74;             // Length: 74 = Inches or 29 = Centimeters
const int minSafeDist = 11;                  // Minimum safe distance of object
#include <Servo.h>                           // Include servo library
Servo servoLeft;                             // Declare left, right and Ping))) servos
Servo servoRight;
Servo PingServo;
// remember to look around after a 45 degree turn
int DoLook = 0;
// Define distance variables
int centerDist, leftDist, leftDist2, rightDist, rightDist2;
// Define variables for Ping)))
long duration, moveTime;
void setup() {                               // Built-in initialization block
  tone(piezoPin, 3000, 1000);                // Play tone for 1 second
  delay(1000);                               // Delay to finish tone
  servoLeft.attach(servoLeftPin);            // Attach left signal to pin 13
  servoRight.attach(servoRightPin);          // Attach right signal to pin 12
  PingServo.attach(servoTurretPin);          // Attach turret signal to pin 11
  if (DoLook == 0) {
    // Look Ahead get center distance
    centerDist = ping(90, 175);
  else {
    DoLook = 0; // set for forward
    // Look around to see if last turn was enough
    LookAround();
    // set to 1 to skip moving forward so it can turn again
    // To-Do: test if this logic works
    if (rightDist2 < minSafeDist
      || centerDist < minSafeDist
      || leftDist2 < minSafeDist) DoLook = 1;
  /* If the inches in front of an object is greater than
   the minimum safe distance (11 inches), move forward */
  if(centerDist > minSafeDist && DoLook == 0) {
    move_or_turn(121, 1);
    delay(110); // Wait 0.11 seconds
  else {
    // Stop moving
    servoLeft.writeMicroseconds(1500);
    servoRight.writeMicroseconds(1500);
    // Check your surroundings for best route
    if (DoLook == 0) LookAround(); // scan
    else DoLook = 0; // scan was done
    // Default move time
    moveTime = 250;
    // Check witch direction is the most so we dont faivor one direction then another
    if (rightDist > minSafeDist && rightDist > leftDist && rightDist2 > leftDist2) {
      // Right side has more distance
      if (rightDist2 > centerDist && rightDist2 > minSafeDist) {
        DoLook = 1; // remember to look around next loop
        moveTime = 125;
        move_or_turn(moveTime, 3); // do a 45 turn right
      else {
        // do a 90 Turn Right
        move_or_turn(250, 3);
   // maybe need to put backward here also and ask a question for 90 degree turns
    else if (leftDist > minSafeDist && leftDist > rightDist && leftDist2 > rightDist2) {
      // Left side has more distance
      if (leftDist2 > centerDist && leftDist2 > minSafeDist) {
        moveTime = 125;
        move_or_turn(moveTime, 2); // do a 45 turn left
      else {
    else {
      // Go Backward
      move_or_turn(250, 4);
    delay(moveTime);
Ping function moves turret to angle, pings then
converts time to length and returns the number
Distance_in_length = ping(angle, delayMS);
int ping(int angle, int delayMS) {
  PingServo.write(angle);      // move turret to angle
  delay(delayMS);              // wait time for turret
  pinMode(pingPin, OUTPUT);    // Set pin to OUTPUT
  digitalWrite(pingPin, LOW);  // Send a low pulse
  delayMicroseconds(2);        // wait for two microseconds
  digitalWrite(pingPin, HIGH); // Send a high pulse
  delayMicroseconds(5);        // wait for 5 micro seconds
  digitalWrite(pingPin, LOW);  // send a low pulse
  pinMode(pingPin,INPUT);      // switch the Pingpin to input
  //listen for echo with 25000 time out
  duration = pulseIn(pingPin, HIGH, 25000);
  // converts time to a distance then return the length
  return duration / LengthConversion / 2;
Look around at 5 angles
void LookAround() {
  //get the two right distances
  rightDist = ping(20, 320);
  rightDist2 = ping(45, 275); // TO-DO: check if 35 is better then 45
  // get the two left distances
  leftDist2 = ping(125, 320); // TO-DO: check if 115 is better then 125
  leftDist = ping(160, 275);
  // move turret back to center
  centerDist = ping(90, 320);
move and turn function
time - Time to wait for movement to complete
task - move or turn command number
Number   Task
1    =  Forward
2    =  Turn left
3    =  Turn right
4    =  Backwards
void move_or_turn(int mttime, int mttask) {
  if (mttask == 1 || mttask == 3) servoLeft.writeMicroseconds(1700);
  else if (mttask == 2 || mttask == 4) servoLeft.writeMicroseconds(1300);
  if (mttask == 3 || mttask == 4) servoRight.writeMicroseconds(1700);
  else if (mttask == 1 || mttask == 2) servoRight.writeMicroseconds(1300);
  if (mttime <= 0) mttime = 1;
  delay(mttime);
