I made a little progress, I've got an index.htm page op the sd card of the ethernetshield. Now i use vbscript to get the snmp done.
<HTML>
<HEAD>
<TITLE>SNMP_Get Arduino</TITLE>
</HEAD>
<BODY>
Klik op onderstaande knop om de SNMPGET procedure uit te voeren.
<FORM NAME="Form1">
<INPUT TYPE="Button" NAME="Button1" VALUE="SNMP_GET">
<SCRIPT FOR="Button1" EVENT="onClick" LANGUAGE="VBScript">
Input=InputBox("Geef het IP adres op van het netwerkelement.","Userinput","192.168.0.233")
on error resume next
err.clear
strOutput = ""
strDeviceIP = Input
'strOutput = strOutput & strDeviceIP & vbcrlf
strCommunity = "public"
set objSNMP = CreateObject("OlePrn.OleSNMP")
objSNMP.Open strDeviceIP, strCommunity, 2, 1000
printer_hostname = objSNMP.Get(".1.3.6.1.2.1.1.5.0")
if err.number = 0 then
display1 = objSNMP.Get(".1.3.6.1.2.1.43.16.5.1.2.1.1")
display2 = objSNMP.Get(".1.3.6.1.2.1.43.16.5.1.2.1.2")
display3 = objSNMP.Get(".1.3.6.1.2.1.43.16.5.1.2.1.3")
display4 = objSNMP.Get(".1.3.6.1.2.1.43.16.5.1.2.1.4")
uptime = objSNMP.Get(".1.3.6.1.2.1.1.3.0")
model = objSNMP.Get(".1.3.6.1.2.1.25.3.2.1.3.1")
tps = 100
tpm = tps * 60
tph = tpm * 60
tpd = tph * 24
ticks = Uptime
seconds = int(ticks/tps) mod 60
minutes = int(ticks/tpm) mod 60
hours = int(ticks/tph) mod 24
days = int(ticks/tpd)
uptime = "Uptime: " & days & " dagen," & hours & " uren," & minutes & " minuten," & seconds & " seconden."
strOutput = strOutput & Printer_Hostname & vbcrlf & model & vbcrlf & " Display Panel:" & vbcrlf
strOutput = strOutput & string(20,61) & vbcrlf
strOutput = strOutput & display1 & vbcrlf & display2 & vbcrlf & _
display3 & vbcrlf & display4 & vbcrlf
stroutput = uptime 'strOutput & uptime
wscript.echo strOutput
end if
MsgBox strOutput
document.write("hostname = " & printer_hostname)
document.write("<br /> model = " & model)
document.write("<br /> uptime = "& uptime)
</SCRIPT>
</FORM>
</BODY>
</HTML>
I 've created a sketch where i open the index.htm page (webserver example)
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
//toegevoegd
EthernetClient client;
// tot hier
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,250);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
File webFile;
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for debugging
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Connection: close");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
//Serial.print(webFile.read());
webFile.close();
break;
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
This gives me a html page with the following text:
hostname = ET00200029147A
model = 968 AIO Printer
uptime = Uptime: 10 dagen,4 uren,51 minuten,33 seconden.
How do i get this data in my serial monitor?
Is it possible to use the html/vbscript variables in my sketch? How do i get the values out of them? (the website is on the sd card)
Maybe someone can help me integrate the html/vbscript in the sketch so it's easier to use the variables in arduino?
