Loading...
Pages: [1] 2   Go Down
Author Topic: Keypad/Servo sketch issues - Updated on reply #8  (Read 442 times)
Offline Offline
Newbie
View Profile
Hi guys,
First off, i'm an offshore electrical engineer however electronics (particularly Arduino) is not something i've spent much time with.  More used to heavy machinery, 24kV switchboards and 11kV propulsion motors on ships etc.
Anyway, excuses aside...
I've been tasked to develop a secure entry system into a hazardous area on board a ship, utilising a keypad and servo motor in the first instance.  Fortunately i found the vast Arduino online support network early on and have managed to pick up enough to write/borrow/chop a sketch together.
However, i'm having trouble when i verify my sketch, i get the following errors...
Code:
Programme_Attempt_2:9: error: variable or field 'keypadEvent' declared void
Programme_Attempt_2:9: error: 'KeypadEvent' was not declared in this scope
Programme_Attempt_2:7: error: 'Password' does not name a type
Programme_Attempt_2:25: error: 'Keypad' does not name a type
Programme_Attempt_2.ino: In function 'void setup()':
Programme_Attempt_2:35: error: 'keypad' was not declared in this scope
Programme_Attempt_2:35: error: 'keypadEvent' was not declared in this scope
Programme_Attempt_2.ino: In function 'void loop()':
Programme_Attempt_2:39: error: 'keypad' was not declared in this scope
Programme_Attempt_2.ino: At global scope:
Programme_Attempt_2:43: error: variable or field 'keypadEvent' declared void
Programme_Attempt_2:43: error: 'KeypadEvent' was not declared in this scope
From the little i know, it looks or seems to me like the sketch isn't finding the Keypad librarie?   It IS in the libraries folder along with 2 other libraries (servo and password) which seem to be working.
I have attached the code below if it helps anyone help me.
Any help is much appreciated,
Colin.
Code:
#include <Keypad.h>  //instructs to use keypad library
#include <Password.h> //instructs to use password library
#include <Servo.h> //instructs to use servo library
Servo myservo; //declares servo
Password password = Password( "1, 2, 3, 4" ); //password to unlock door/start servo, can be changed.
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = { 5, 4, 3, 2 };// Connect keypad ROW1, ROW2, ROW3 and ROW4 to these Arduino pins.
byte colPins[COLS] = { 8, 7, 6 };// Connect keypad COL1, COL2 and COL3 to these Arduino pins.
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  Serial.print(254);
  Serial.print(0x01);
  delay(200);
  pinMode(11, OUTPUT);  //Green light
  pinMode(12, OUTPUT);  //Red light
  myservo.attach(13); //Servo on digital pin 9 //servo
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
  keypad.getKey();
  myservo.write(0);
  //take care of some special events
  void keypadEvent(KeypadEvent eKey){
  switch (keypad.getState()){
  case PRESSED:
  Serial.print("Enter: ");
  Serial.println(eKey);
  delay(10);
  Serial.print(254);
  switch (eKey){
    case 'A': checkPassword(); delay(1); break;
    case 'B': password.reset(); delay(1); break;
     default: password.append(eKey); delay(1);
void checkPassword(){
if (password.evaluate()){  //if password is right open door/turn servo 160deg
    Serial.println("Accepted");
    Serial.print(254);delay(10);
    //Add code to run if it works
    myservo.write(5); //160deg
        digitalWrite(11, HIGH);//turn on
    digitalWrite(11, LOW);// turn off
}else{
    Serial.println("Denied"); //if passwords wrong keep door locked/servo motionless
    //add code to run if it did not work
    myservo.write(0);
    digitalWrite(12, HIGH); //turn on
    digitalWrite(12, LOW);//turn off
« Last Edit: February 15, 2013, 06:42:45 am by coldo » Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
You want to secure an entry system into a hazardous area with an arduino? Ok. well it looks like your sketch can't find the libraries. Where did you put them, in the Arduino sketch folder, under your documents or in the Arduino 1.0.3 folder?
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
These are pretty good indicators that the Keypad.h and Password.h files could not be found. Where did you download these libraries to?
Logged
Offline Offline
Newbie
View Profile
Thanks for the quick response guys.
The libraries are saved;
My Documents > Arduino > Libraries
Libraries directory contains 3 folders titled; Keypad, Password and Servo.  All containing .cpp and .h files.
Does it matter where i save my sketch file....?  As this is in a different location?
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
Well try moving them to the other folder. If it doesn't have a libraries folder in it, make one. If it still doesn't work, try the spelling, they might be all lower case letters.
Logged
Offline Offline
Newbie
View Profile
Ok, just checked spelling, libraries are in the same format as the sketch.
Also moved the libraries between the Arduino 1.0.3 folder and my Arduino folder in my documents - same errors are apparent unfortunately.
Any other suggestions?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Post a screen shot of the library structure. You are restarting the IDE each time, right?
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
Do you have a link of where you got them?
Logged
Offline Offline
Newbie
View Profile
Hi again guys.
OK.
Embarassingly... the original error which resulted in the keypad/password libraries not being found or working was a schoolboy indexing error which i noticed last night and have now fixed.  Thanks again for your time though.
HOWEVER...
Now the servo library wont work!?  Or at least the .cpp file.  The errors im getting are shown below.
Code:
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp: In function 'void handle_interrupts(timer16_Sequence_t, volatile uint16_t*, volatile uint16_t*)':
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:81: error: 'LOW' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:81: error: 'digitalWrite' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:88: error: 'HIGH' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:88: error: 'digitalWrite' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:92: error: 'clockCyclesPerMicrosecond' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp: At global scope:
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:232: error: 'boolean' does not name a type
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp: In constructor 'Servo::Servo()':
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:249: error: 'clockCyclesPerMicrosecond' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp: In member function 'uint8_t Servo::attach(int, int, int)':
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:263: error: 'OUTPUT' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:263: error: 'pinMode' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:270: error: 'isTimerActive' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp: In member function 'void Servo::detach()':
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:281: error: 'isTimerActive' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp: In member function 'void Servo::write(int)':
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:292: error: 'map' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp: In member function 'void Servo::writeMicroseconds(int)':
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:300: error: 'byte' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:300: error: expected `;' before 'channel'
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:301: error: 'channel' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:309: error: 'clockCyclesPerMicrosecond' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp: In member function 'int Servo::read()':
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:320: error: 'map' was not declared in this scope
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp: In member function 'int Servo::readMicroseconds()':
C:\Users\Colin\Documents\Arduino\libraries\Servo\Servo.cpp:327: error: 'clockCyclesPerMicrosecond' was not declared in this scope
Again, if anyone has any input it is greatly appreciated, thanks.
Colin.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Why do you have a copy of the Servo library in your sketch folder's libraries directory?
Logged
Offline Offline
Newbie
View Profile
I do?  Could you elaborate - how to fix/what i've done wrong?  Apologies for my ignorance!
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Isn't C:\Users\Colin\Documents\Arduino where you store your sketches?
Quote
This looks like Servo is a library in your libraries folder in the sketch directory. It does not belong here because Servo is a core library.
Logged
Offline Offline
Newbie
View Profile
Quote
Ah, i see.  Yes, this is where my sketches are stored.  I've now deleted the servo copy.
Quote
Ok.  So... i have re-arranged and and re-imported the servo library from the Arduino 1.0.3 directory however the same errors are apparent.
To clarify -
My sketch is in >   C:\Users\Colin\Documents\Arduino
Keypad, Password and Servo libraries are all now in > C:\Users\Colin\Documents\arduino-1.0.3\libraries
Keypad and Password libraries appear to be recognised - Servo is not.
Sorry for the very schoolboy issues - all your time is greatly appreciated!
I
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
That is not where Keypad and Password belong. Those are not core libraries, and do not belong in the core library folder. Servo is and does.
What do your copies of Servo.h and Servo.cpp look like? What does your sketch look like?
When I compile the code in the initial post, I only get this "error" message:
Code:
Binary sketch size: 9,350 bytes (of a 28,672 byte maximum)
Logged
Offline Offline
Newbie
View Profile
Quote
Code:
Ok.
Moved the keypad and Password libraries from the core libraries to an appropriate location.  Re-checked and they appear to work as normal.
The servo.h and servo.cpp are shown below;
Servo.h looks like;
Code:
  Servo.h - Interrupt driven Servo library for Arduino using 16 bit timers- Version 2
  Copyright (c) 2009 Michael Margolis.  All right reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
  A servo is activated by creating an instance of the Servo class passing the desired pin to the attach() method.
  The servos are pulsed in the background using the value most recently written using the write() method
  Note that analogWrite of PWM on pins associated with the timer are disabled when the first servo is attached.
  Timers are seized as needed in groups of 12 servos - 24 servos use two timers, 48 servos will use four.
  The sequence used to sieze timers is defined in timers.h
  The methods are:
   Servo - Class for manipulating servo motors connected to Arduino pins.
   attach(pin )  - Attaches a servo motor to an i/o pin.
   attach(pin, min, max  ) - Attaches to a pin setting min and max values in microseconds
   default min is 544, max is 2400
   write()     - Sets the servo angle in degrees.  (invalid angle that is valid as pulse in microseconds is treated as microseconds)
   writeMicroseconds() - Sets the servo pulse width in microseconds
   read()      - Gets the last written servo pulse width as an angle between 0 and 180.
   readMicroseconds()   - Gets the last written servo pulse width in microseconds. (was read_us() in first release)
   attached()  - Returns true if there is a servo attached.
   detach()    - Stops an attached servos from pulsing its i/o pin.
#ifndef Servo_h
#define Servo_h
#include <inttypes.h>
 * Defines for 16 bit timers used with  Servo library
 * If _useTimerX is defined then TimerX is a 16 bit timer on the curent board
 * timer16_Sequence_t enumerates the sequence that the timers should be allocated
 * _Nbr_16timers indicates how many 16 bit timers are available.
// Say which 16 bit timers can be used and in what order
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#define _useTimer5
#define _useTimer1
#define _useTimer3
#define _useTimer4
typedef enum { _timer5, _timer1, _timer3, _timer4, _Nbr_16timers } timer16_Sequence_t ;
#elif defined(__AVR_ATmega32U4__)
#define _useTimer3
#define _useTimer1
typedef enum { _timer3, _timer1, _Nbr_16timers } timer16_Sequence_t ;
#elif defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__)
#define _useTimer3
#define _useTimer1
#elif defined(__AVR_ATmega128__) ||defined(__AVR_ATmega1281__)||defined(__AVR_ATmega2561__)
#define _useTimer3
#define _useTimer1
#else  // everything else
#define _useTimer1
typedef enum { _timer1, _Nbr_16timers } timer16_Sequence_t ;
#endif
#define Servo_VERSION           2      // software version of this library
#define MIN_PULSE_WIDTH       544     // the shortest pulse sent to a servo
#define MAX_PULSE_WIDTH      2400     // the longest pulse sent to a servo
#define DEFAULT_PULSE_WIDTH  1500     // default pulse width when servo is attached
#define REFRESH_INTERVAL    20000     // minumim time to refresh servos in microseconds
#define SERVOS_PER_TIMER       12     // the maximum number of servos controlled by one timer
#define MAX_SERVOS   (_Nbr_16timers  * SERVOS_PER_TIMER)
#define INVALID_SERVO         255     // flag indicating an invalid servo index
typedef struct  {
  uint8_t nbr        :6 ;             // a pin number from 0 to 63
  uint8_t isActive   :1 ;             // true if this channel is enabled, pin not pulsed if false
} ServoPin_t   ;
typedef struct {
  ServoPin_t Pin;
  unsigned int ticks;
} servo_t;
class Servo
public:
  Servo();
  uint8_t attach(int pin);           // attach the given pin to the next free channel, sets pinMode, returns channel number or 0 if failure
  uint8_t attach(int pin, int min, int max); // as above but also sets min and max values for writes.
  void detach();
  void write(int value);             // if value is < 200 its treated as an angle, otherwise as pulse width in microseconds
  void writeMicroseconds(int value); // Write pulse width in microseconds
  int read();                        // returns current pulse width as an angle between 0 and 180 degrees
  int readMicroseconds();            // returns current pulse width in microseconds for this servo (was read_us() in first release)
  bool attached();                   // return true if this servo is attached, otherwise false
private:
   uint8_t servoIndex;               // index into the channel data for this servo
   int8_t min;                       // minimum is this value times 4 added to MIN_PULSE_WIDTH
   int8_t max;                       // maximum is this value times 4 added to MAX_PULSE_WIDTH
#endif
Logged
Pages: [1] 2   Go Up
Print
Jump to:
