Loading...
Pages: [1]   Go Down
Author Topic: Arduino uno not printing messages in setup()  (Read 173 times)
Offline Offline
Newbie
View Profile
Hello,
my program was working normally until yesterday. Then I add some arrays in the program, changed nothing in the setup but I cannot even see the messages in setup.
Here are what I added, and my setup function which is the same as before:
Code:
char* responses_array[]={
  "80","81","82"};
char* alive_array[]={
  "75","76","77"};
char* responses_to_wait[NUMBER_OF_BODIES];
char* alive_to_wait[NUMBER_OF_BODIES];
int positions[NUMBER_OF_BODIES];
int bodies_to_send_to[NUMBER_OF_BODIES];
  Serial.begin(57600);
  Serial.println( "Arduino started sending bytes via XBee Vol.2" );
  // set the data rate for the SoftwareSerial port
  xbee.begin(9600);
  lcd.begin(16,2);              // columns, rows.  use 16,2 for a 16x2 LCD, etc.
  lcd.clear();                  // start with a blank screen
  lcd.setCursor(0,0);           // set cursor to column 0, row 0 (the first row)
  lcd.print(upRow);    // change this text to whatever you like. keep it clean.
  lcd.setCursor(0,1);           // set cursor to column 0, row 1
  lcd.print(bottomRow);
  for(int i=0;i<NUMBER_OF_BODIES;i++){
    positions[i]=0;
    Serial.print("Setting position at 0:  ");
    Serial.print(i);
  Serial.println(" ");
 in the Serial I see something like this:
Code:
¬Hø¬Hø¬Hø¬Hø¬Hø¬HøÔ
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
¬Hø¬Hø¬Hø¬Hø¬Hø¬HøÔ
Ô
¬Hø¬Hø¬Hø¬HøÔ
Ô
Ô
Ô
Ô
¬Hø¬Hø¬Hø¬Hø¬Hø¬HøÔ
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
Ô
¬Hø¬Hø¬Hø¬Hø¬Hø¬HøÔ
I have tried with two different arduino UNO, and cables but still nothing.
When I upload the program, TX and RX blink at the same time, and then TX blinks so fast.
As I remember before, TX was not blinking that fast.
If I run the last code, it runs without any problem.
« Last Edit: February 12, 2013, 02:37:28 pm by vima » Logged
Offline Offline
Sr. Member
View Profile
This isn't your whole code. What is the value of NUMBER_OF_BODIES?
You might be running out of RAM, you may want to store the strings in flash.
Logged
Offline Offline
Newbie
View Profile
Yes I have told you that this is now my whole code. It is just the new variables I added.
What do you mean in flash? Can you give me any example of this?
How much memory does arduino have?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Uno has:
About 30 Kbytes of FLASH memory for code space, but only 2 Kbytes of SRAM space for all your variables, arrays, const, String constants, stack space, heap space, etc in SRAM memory.
Other Arduino boards have different amounts of both types of memory.
Lefty
Logged
Offline Offline
Sr. Member
View Profile
I don't see a definition (or #define) for NUMBER_OF_BODIES, what is its value?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
It can't be, as it doesn't even compile. Where is NUMBER_OF_BODIES defined and valued?
Logged
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
What baud rate is the serial monitor set to ?
Logged
Pages: [1]   Go Up
Print
Jump to:
