Topic: 8/8 button matrix (Read 2646 times) previous topic - next topic
littlewolf
Hi guys,
Can you help with the following code?
I have a 8/8 button matrix connected  to a button shield,
which is connected to an Arduino Mega.
I am trying to insert characters on a computer display.
It's my first code and I am a bit struggling.
Can you help?
Any suggestion would be useful.
Regards
Code: [Select]
// 8/8 keypad to print characters
// on computer display
#include <Keypad.h>
int R0=9;
int R1=8;
int R2=7;
int R3=6;
int R4=5;
int R5=4;
int R6=3;
int R7=2;
void setup();
pinMode(R0, INPUT);
pinMode(R1, INPUT);
pinMode(R2, INPUT);
pinMode(R3, INPUT);
pinMode(R4, INPUT);
pinMode(R5, INPUT);
pinMode(R6, INPUT);
pinMode(R7, INPUT);
const byte Rows = 8; // 8 rows
const byte Cols = 8; // 8 columns
char keys [Rows] [Cols] ={
  {'a','b','c','d','e','f','g','h'},
  {'i','j','k','l','m','n','o','p'},
  {'q','r','s','t','u','v','w','x'},
  {'y','z','A','B','C','D','E','F'},
  {'G','H','I','J','K','L','M','N'},
  {'O','P','Q','R','S','T','U','V'},
  {'W','X','Y','Z','1','2','3','4'},
  {'5','6','7','8','9','0','.',','},
  byte rowPins [Rows] = {R0, R1, R2, R3, R4, R5, R6, R7};
  // connect to row pinouts of the keypad
  byte colPins [Cols] = {A0, A1, A2, A3, A4, A5, A6, A7};
  // connect to column pinouts of keypad
  Keypad keypad = Keypad( makeKeymap (keys), rowPins, colPins,
  Rows, Cols };
    Serial.begin (9600);
    Keypad.begin();
    char key = keypad.getKey();
    if (key != No_Key){
      Serial.println( key );
HazardsMind
#1
Feb 12, 2013, 09:24 pm Last Edit: Feb 12, 2013, 09:32 pm by HazardsMind Reason: 1
Ok what is it doing or not doing? Any errors?
Edit: Keypad.begin() seems odd to me, none of the other keypad codes I've helped write had that in them.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
HazardsMind
My GitHub:
littlewolf
Those are the errors:
14:error: expected unqualified-id before '{' token
44:error: 'Keypad' does not name a type
In function 'void setup()':
50: error: 'Keypad was not declared in this scope
In function 'void loop()':
54: error: 'keypad' was not declared in this scope
56: error: 'No_Key' was not declared in this scope
Thanks
nickgammon
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
littlewolf
I tried but I have the same errors
UKHeliBob
Code: [Select]
void setup();Lose the semi colon
Have you got the Keypad.h file and, if so, which folder is it in ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
HazardsMind
#7
Feb 12, 2013, 09:51 pm Last Edit: Feb 12, 2013, 09:54 pm by HazardsMind Reason: 1
Why do you have two setup() functions?
Code: [Select]
void setup();
pinMode(R0, INPUT);
pinMode(R1, INPUT);
pinMode(R2, INPUT);
pinMode(R3, INPUT);
pinMode(R4, INPUT);
pinMode(R5, INPUT);
pinMode(R6, INPUT);
pinMode(R7, INPUT);
And...
Code: [Select]
    Keypad.begin();
My GitHub:
CrossRoads
You have void setup twice:
Code: [Select]
int R7=2;
void setup();
pinMode(R0, INPUT);
pinMode(R1, INPUT);
and
Code: [Select]
 Rows, Cols };
   Keypad.begin();
Probably move the stuff in the 2nd one to the end of the first one.
keypad.begin also does not belong:
http://playground.arduino.cc/code/Keypad
PaulS
Code: [Select]
void setup();
Why is there a semicolon after this function declaration?
Code: [Select]
  Rows, Cols };
That's a curly brace on the end, not a parenthesis.
Code: [Select]
    Keypad.begin();
You call methods using an instance (keypad) not a class name (Keypad). The begin method takes an argument - the keymap that makeKeymap() creates. But, since you have already supplied that to the instance, there is no reason to call keymap.begin() again.
You have two setup() functions.
Code: [Select]
    if (key != No_Key){
The constant is NO_KEY.
After correcting all these errors, the code compiles.
littlewolf
I don't know.
I tried to write this code using different examples.
There is not a proper code on the internet for this 8/8 matrix.
I used a normal Arduino header and I don't know about the folder inside.
littlewolf
#11
Feb 12, 2013, 10:22 pm Last Edit: Feb 12, 2013, 10:28 pm by littlewolf Reason: 1
Code: [Select]
This is my new code.
I still got errors.
Now what is wrong?
Regards
[code// 8/8 keypad to print characters
#include <Keypad.h>
int R0=9;
int R1=8;
int R2=7;
int R3=6;
int R4=5;
int R5=4;
int R6=3;
int R7=2;
pinMode(R0, INPUT);
pinMode(R1, INPUT);
pinMode(R2, INPUT);
pinMode(R3, INPUT);
pinMode(R4, INPUT);
pinMode(R5, INPUT);
pinMode(R6, INPUT);
pinMode(R7, INPUT);
 Rows, Cols );
   if (key != No_Key){
CrossRoads
I think this stuff all goes before void setup
Code: [Select]
  Rows, Cols );
You're missing the } to end void setup
May not need these, I think the keypad callout takes care of all this
Code: [Select]
pinMode(R0, INPUT);
pinMode(R1, INPUT);
pinMode(R2, INPUT);
pinMode(R3, INPUT);
pinMode(R4, INPUT);
pinMode(R5, INPUT);
pinMode(R6, INPUT);
pinMode(R7, INPUT);
Check the sample code at the end of the link I posted before to the keypad library in the playground.
PaulS
Quote
I still got errors.
Now what is wrong?
What are they?
You REALLY need to learn what should be global (outside any function) and what should be in a function. There is an example that comes with the Keypad library. Modifying that example to use 8 rows and 8 columns is trivial. If you pay attention.
littlewolf
I modified everything and I also included the
keypad library into the Arduino.
The error I receive now is to declare keypad into
void loop function
I think it's almost done
Just the last few bits
Thanks
Code: [Select]
#include <Keypad.h>
int R0=9;
int R1=8;
int R2=7;
int R3=6;
int R4=5;
int R5=4;
int R6=3;
int R7=2;
  Keypad customKeypad = Keypad( makeKeymap (keys), rowPins, colPins,
  Rows, Cols );
    if (key != No_Key){
