Topic: Serial Communication and Blocking vs NonBlocking Functions (Read 6569 times) previous topic - next topic
andyopayne
Hi everyone,
I'm writing to get some help on a program I'm writing to control stepper motors.  I've already got a version of the program working where my program (developed in C#) will send a string of data (over serial) over to the arduino board with information about how to control up to four steppers (using the AccelStepper library: https://github.com/adafruit/AccelStepper).  This process works pretty well, however my arduino code currently calls non-blocking move functions... so every time the serial data is available, it reads it in and then immediately tries to move the motors to those positions.  However, it may not have reached the destination it had previously been trying to get to, before this next command had been issues.  This non-blocking sequence is helpful in some instances, like when you move a slider and you want the stepper to try to keep up with the most current position.  However, it's a bit troublesome if trying to control precisely the movement path of a motor (say for a CNC machine) where it needs to move to every position before moving onto the next instruction.
So, I think I need to rethink the workflow a bit.  First, I'm pretty sure I'll need to use blocking commands (the Accel Stepper library has both)... however, more importantly I need the Arduino to send a call back to my application letting it know that it just completed the last move and it's ready to receive the next one.  The issue I see is that my applications update cycle is relatively slow (and it's scene dependent... meaning the more stuff I have going on in the scene, the slower the refresh rate will be)... Typically the fastest I've been able to get it to run is 60Hz, but usually closer to 30Hz.  So, if I'm trying to get smooth motor control, this may be a problem, because my application will send a command and then wait for the call back... The arduino will execute the command and then send the call back and wait for the next command from GH.  However, there is probably going to be a delay of several milliseconds between those two actions... and this could cause somewhat jerky motion.
I'm wondering if anyone has any suggestions about how to resolve this.  Are there any ways to issue a callback to another application and have it basically be instantaneous?  The other issue I see is how can I control up to 4 motors in parallel if using blocking commands?  If it's a blocking function, wouldn't it have to move one motor, then the next, then the next, etc.  Is there a way to be able to control motors in parallel and still know when the stepper has completed moving to its destination?  If it would help, I can post the arduino code that I have so far... but currently it's just implementing the non-blocking functions and doesn't implement the call back function at all.  Thanks for the help.
PaulS
#1
Feb 12, 2013, 09:08 pm Last Edit: Feb 12, 2013, 09:10 pm by PaulS Reason: 1
Quote
I wouldn't recommend that. The advantage of the non-blocking methods is that two or more steppers can move simultaneously.
Using the blocking methods would negate that ability.
What I think you need to do is let the steppers operate in a non-blocking fashion, but do so in a while loop (blocking) that checks for the steppers having reached the commanded positions. When that happens, break out of the while loop, and get another instruction.
I think that your concern about the time required to request and receive the next command is over stated.
If it turns out that it isn't, you could always ask for another command as soon as the first one is started, and collect that command during the while loop. Then, when that while loop ends, you'd be ready for the next iteration.
andyopayne
Interesting.  Thanks for the reply and suggestions.  I agree that the blocking functions seemed troublesome (which is precisely why I was looking for help).  Thanks again for the suggestions.  I'll try to give it a go and see if I can come up with a solution.  As far as call backs go, is there a better way than just sending a string back to my application when the while loop breaks out of its loop?
PaulS
Quote
The only recommendation I have is to keep the string short and the baud rate high. "R" is transmitted and understood a lot quicker than "Hey, PC, off your duff. I'm ready for the next command."
andyopayne
Ok.  I've tried a few options, but can't seem to get anywhere.  I've tried adding a while loop which will terminate when one of the four motors has finished getting to its desired position.  I do this by storing the return boolean value from the stepper.run() function where it will return true if the motor is still trying to move to it's final position.  Once it breaks out of the loop, I then determine which of the four motors has finished (again, by using the return value) and then sending a character (1, 2, 3, or 4) back to my application telling my application it's ready for the next bit of information.  However, none of this seems to really work.  The code is somewhat long (see post below... it was too long to add in this post), but I've tried to add comments so that it's clear.  Please let me know if you have any suggestions.  Thanks.
andyopayne
Quote
#include <AccelStepper.h>
#define BAUDRATE 115200     //Set the Baud Rate to an appropriate speed
#define BUFFSIZE  256       // buffer one command at a time, 12 bytes is longer than the max length
#define DIR_PIN_A 2         //Set Direction Pin for Stepper A to Digital Pin 2
#define STEP_PIN_A 3        //Set Step Pin for Stepper A to Digital Pin 3
#define DIR_PIN_B 4         //Set Direction Pin for Stepper B to Digital Pin 4
#define STEP_PIN_B 5        //Set Step Pin for Stepper B to Digital Pin 5
#define DIR_PIN_C 6         //Set Direction Pin for Stepper C to Digital Pin 6
#define STEP_PIN_C 7        //Set Step Pin for Stepper C to Digital Pin 7
#define DIR_PIN_D 8         //Set Direction Pin for Stepper D to Digital Pin 8
#define STEP_PIN_D 9        //Set Step Pin for Stepper D to Digital Pin 9
long motorPos[4] = {0,0,0,0};
int motorSpeed = 2000;     //Set default speed value
int motorAcc = 1000;       //Set default acceleration value
int motorRun = 1;          //Set default run value
int motorReset = 0;        //Set default reset value
boolean needUpdate_1 = true;
boolean needUpdate_2 = true;
boolean needUpdate_3 = true;
boolean needUpdate_4 = true;
unsigned long timer = 0;
String msg_char = "";
char *parseptr;
char buffidx;
char buffer[BUFFSIZE];    // this is the double buffer
uint16_t bufferidx = 0;   // a type of unsigned integer of length 16 bits
uint16_t p1, s1;
// Define some steppers and the pins they will use: Ex: Accelstepper stepper1(1, 3, 4) <- STEP PIN 3, DIR PIN 4.
AccelStepper stepper1(1, STEP_PIN_A, DIR_PIN_A);
AccelStepper stepper2(1, STEP_PIN_B, DIR_PIN_B);
AccelStepper stepper3(1, STEP_PIN_C, DIR_PIN_C);
AccelStepper stepper4(1, STEP_PIN_D, DIR_PIN_D);
  stepper1.setCurrentPosition(0);  //Move steppers to default position
  stepper2.setCurrentPosition(0);
  stepper3.setCurrentPosition(0);
  stepper4.setCurrentPosition(0);
  setStepperSpeeds();
  Serial.begin(BAUDRATE);         // Start serial communication
  establishContact();             // send a byte to establish contact until receiver responds
  UpdateStepperValues();  //Get all the incoming values from Firefly
  if (motorReset == 1) {
    stepper1.setCurrentPosition(motorPos[0]);
    stepper2.setCurrentPosition(motorPos[1]);
    stepper3.setCurrentPosition(motorPos[2]);
    stepper4.setCurrentPosition(motorPos[3]);
  if (motorRun == 1) {
    timer = millis();
    do{
      needUpdate_1 = stepper1.run();
      needUpdate_2 = stepper2.run();
      needUpdate_3 = stepper3.run();
      needUpdate_4 = stepper4.run();
    } while (!needUpdate_1);
    if(needUpdate_1) msg_char = "1";
    else if(needUpdate_2) msg_char = "2";
    else if(needUpdate_3) msg_char = "3";
    else if(needUpdate_4) msg_char = "4";
    if(millis() - timer > 20){
      Serial.println(msg_char);  //send character for the next line from Firefly
void UpdateStepperValues(){
  char c;    // holds one character from the serial port
  if (Serial.available() > 0) {
    c = Serial.read();      // read one character
    buffer[bufferidx] = c;  // add to buffer
    if (c == '\n') {
      buffer[bufferidx+1] = 0; // terminate it
      parseptr = buffer;       // offload the buffer into temp variable
      motorPos[0] = parsedecimal(parseptr);    // parse the first number
      parseptr = strchr(parseptr, ',')+1;      // move past the ","
      motorPos[1] = parsedecimal(parseptr);    // parse the next number
      motorPos[2] = parsedecimal(parseptr);    // parse the next number
      motorPos[3] = parsedecimal(parseptr);    // parse the next number
      motorSpeed = parsedecimal(parseptr);     // parse the next number
      motorAcc = parsedecimal(parseptr);       // parse the next number
      motorRun = parsedecimal(parseptr);       // parse the next number
      motorReset = parsedecimal(parseptr);     // parse the next number
      setStepperSpeeds();
      stepper1.moveTo(motorPos[0]);            //set new absolute target position
      stepper2.moveTo(motorPos[1]);            //set new absolute target position
      stepper3.moveTo(motorPos[2]);            //set new absolute target position
      stepper4.moveTo(motorPos[3]);            //set new absolute target position
      bufferidx = 0;       // reset the buffer for the next read
      return;              //return so that we don't trigger the index increment below
    // didn't get newline, need to read more from the buffer
    bufferidx++;    // increment the index for the next character
    if (bufferidx == BUFFSIZE-1) {  //if we get to the end of the buffer reset for safety
      bufferidx = 0;
double parsedecimal(char *str)
  return atof(str);
void establishContact() {
  while (Serial.available() <= 0) {
    Serial.println("n");   // send an initial string
    delay(200);
void setStepperSpeeds() {
  stepper1.setMaxSpeed(motorSpeed);
  stepper1.setAcceleration(motorAcc);
  stepper2.setMaxSpeed(motorSpeed);
  stepper2.setAcceleration(motorAcc);
  stepper3.setMaxSpeed(motorSpeed);
  stepper3.setAcceleration(motorAcc);
  stepper4.setMaxSpeed(motorSpeed);
  stepper4.setAcceleration(motorAcc);
PaulS
Quote
Code: [Select]
    do{
This is checking only one motor. I'd do something like:
Code: [Select]
   while(1)
      done_1 = stepper1.run();
      done_2 = stepper2.run();
      done_3 = stepper3.run();
      done_4 = stepper4.run();
      if(done_1 || done_2 || done_3 || done_4)
Then, you can use done_n, to see which value to send back.
Of course, using && instead of || might be better, so that the while loop runs until all the motors get where they are supposed to be.
andyopayne
Thanks Paul.  That was my mistake... I had been fiddling around with different parts of the code and had originally tested whether or not all 4 motors had gotten to their position.  However, I tried your code snippet and it still doesn't seem to work.  Here's my new code (I think you have to check for !done_1, etc... because it returns true when the motor is moving and false when it's reached its final position):
Quote
    timer = millis();
    while(1)
      if(!done_1 || !done_2 || !done_3 || !done_4)
    if(done_1) msg_char = "1";
    else if(done_2) msg_char = "2";
    else if(done_3) msg_char = "3";
    else if(done_4) msg_char = "4";
    if(millis() - timer > 10){
However, if I launch the serial monitor... what I see at first is a bunch of 'n' characters printing every 200ms (this is from the establishContact function).  Once it receives it's first incoming serial data, it should then launch into the loop() function and determine the first motor positions and jump into the while loop.  So, if I send the following string:
Quote
500,400,300,200,1000,100,1,0
where the first four numbers are the target positions for each motor (starting with motor 1), the next number is Motor Speed, then Motor Acceleration, then Motor Run, and Motor Reset values... So this is the string my application would be sending... I'm using the Serial Monitor send function to simulate this just for debugging... So, I would think that once I send this string via the Serial Monitor, it would wait some brief time (to move the motors) and then when the first of the motors was done (motor 4), then it would print a character back to the serial port ("4") indicating it's ready for the next line.  However, as soon as I send the data via the serial monitor... nothing happens after that point.  It basically freezes (and nothing gets printed back).  So, something is getting stuck somewhere, but I'm not really sure where.  Any ideas?  Thanks again for your help.
PaulS
The AccelStepper::run() method returns true when the stepper gets where it was told to go. You are exiting the while loop as soon as one of the steppers is NOT yet where it was told to go. So, it's not surprising that you can't figure out which motor is where it is supposed to be.
andyopayne
Ah.  Ok.  My mistake.  Still, if I change the conditional to
Quote
Then, I still have the same issue... as soon as I send that string: 500,400,300,200,1000,100,1,0... then the program basically freezes... it never sends the msg_char back to the serial port indicating which motor has finished.  Do you think it has something to do with the millis() conditional check:
Quote
I put this in so that if they're all at their final destination point, that it has to wait at least 10ms before sending the next command... The buffer in my application can get flooded if too much data is sent too quickly, so this is just a simple check to make sure at least a small portion of time has elapsed before sending the call back command.
PaulS
Quote
Certainly easy enough to check:
Code: [Select]
         Serial.println("One of the motors got done...");
PaulS
Quote
I don't understand the need for this. The serial buffer has been emptied, presumably, since no "Hey, I'm ready" message has been sent. Once a motor (or, more accurately all 4 motors) get to their commanded position(s), you should be able to immediately ask for another instruction. There may well be situations where only a few steps are needed, and they are accomplished quickly.
andyopayne
Thanks for all the quick replies!  It seems like the AccelStepper library actually returns true if it's still moving and false when it's done (https://github.com/adafruit/AccelStepper/blob/master/AccelStepper.cpp)... so I think I have to check weather or not the motor has returned false.  But, I'm making a little progress.  I now have this as the function:
Quote
    timer = millis();
    while(1)
      if(!done_1 || !done_2 || !done_3 || !done_4){
        if(!done_1) msg_char = "1";
        else if(!done_2) msg_char = "2";
        else if(!done_3) msg_char = "3";
        else if(!done_4) msg_char = "4";
This works for the most part... if I enter in the string: 5000,4000,3000,2000,1000,100,1,0, then it waits a brief period of time (simulating moving motor 4 to 1000 steps) and then prints the number 4... then 3... then 2... then 1.  However, I noticed something funny.  For some reason, after I enter in the string command above, and before it's reached position 4 (so some small amount of time) the serial monitor starts printing the number 1 (almost as if it's broken out of the while loop and assigned the msg_char... however, all the done variables are initialized to true and the msg_char is initialized as an empty string.  So, I'm not sure why it's printing the number 1, before it prints 4, 3, 2, and then 1.
Also, the timer check was in there so it slows everything down.  Let's say I send a command, then all the motors reach their final position.  If this condition is true, then it will start sending the msg_char basically as fast as it can, because their is nothing in the loop function slowing it down.  If I send the data too quickly, then my application will crash.  So, I had tried to put a simple timer check to make sure at least 10ms had elapsed before sending the string back to my application.  But, when I try adding that into the code, nothing seems to work (like before).  When it isn't in there, then I get the response above.  Thoughts?
PaulS
Quote
Thoughts?
I chose done_n as the variable name, because the header file said run() returned true when the stepper got to the commanded position. Since that is not true, I'm having a hard time with the names.
Code: [Select]
    while(1)
      moving_1 = stepper1.run();
      moving_2 = stepper2.run();
      moving_3 = stepper3.run();
      moving_4 = stepper4.run();
      if(!moving_1 || !moving_2 || !moving_3 || !moving_4)
OK. Now I can see what is happening. The if block gets executed if any one of the motors gets to its final position.
Perhaps what needs to happen is that if any of the moving_n flags is false, motorRun needs to be set to other than 1.
Quote
That while(1) loop that currently waits for one motor to get to its commanded position certainly should slow things down.
Quote
Sending data too quickly means faster than it can be read. Since new data is only supposed to be sent in response to a ready directive, that should not happen, regardless of whether you diddle around before sending the ready directive, or not.
Of course, you do need to not send the ready directive until you are ready. Which, to me, means that all 4 motors have reached there commanded positions, not just one.
andyopayne
Regarding your comment:  Perhaps what needs to happen is that if any of the moving_n flags is false, motorRun needs to be set to other than 1.
Does this mean I need to check whether the boolean is true/false before telling the motor to run?  I tried something like this, but it doesn't seem to work.  Basically, it waits to get the first command, and when I send it the string: 500,400,300,200,1000,100,1,0, then you'd think it would wait until all the motors have finished moving (so however long it takes to move the motor 500 steps) and then it would print the command "next".  However, it never prints "next".  It just hangs there.  Any thoughts?
Quote
    while(1)
      if(!moving_1) moving_1 = stepper1.run();
      if(!moving_2) moving_2 = stepper2.run();
      if(!moving_3) moving_3 = stepper3.run();
      if(!moving_4) moving_4 = stepper4.run();
      if(!moving_1 && !moving_2 && !moving_3 && !moving_4){
        Serial.println("next");   //send character for the next line from Firefly
        moving_1 = true;          //reset all the moving variables
        moving_2 = true;
        moving_3 = true;
        moving_4 = true;
