Loading...
Pages: [1]   Go Down
Author Topic: Button programming problems can anyone help?  (Read 188 times)
Offline Offline
Newbie
View Profile
Little bit stuck cant seem to get the button to work right it only seems to work some of the time and if held down just skips throw the modes anyone help?
Code:
const int redledPin = 2;
const int greenledPin = 4;
const int blueledPin = 5;
const int buttonPin1 = 6;
int led=1;
void setup ()
  pinMode (redledPin, OUTPUT);
  pinMode (greenledPin, OUTPUT);
  pinMode (blueledPin, OUTPUT);
  pinMode (buttonPin1, INPUT);
void loop ()
 if (digitalRead(buttonPin1)== HIGH)
  led++;
  if (led >16) led = 1;
  delay(300);
   switch (led){
    case 0:
    analogWrite(redledPin, 0);
    analogWrite(blueledPin, 0);
    analogWrite(greenledPin, 0);
    case 1:
    analogWrite(redledPin, 250);
    analogWrite(blueledPin, 250);
    analogWrite(greenledPin, 250);
    case 2:
    case 3:
    case 4:
    case 5:
    case 6:
    case 7:
    case 8:
    delay(100);
    delay(100);
    case 9:
    delay(100);
    delay(100);
    case 10:
    delay(100);
    delay(100);
    case 11:
    delay(100);
    delay(100);
    case 12:
    delay(100);
    delay(100);
    case 13:
    delay(100);
    delay(100);
    case 14:
    delay(100);
    delay(100);
    case 15:
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
« Last Edit: February 12, 2013, 07:03:13 pm by PlasticOne » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Good thing you found the problem before writing a ton of improperly posted code.
You are not using the internal pullup resistor, so, how IS your switch wired?
Logged
Offline Offline
Newbie
View Profile
Just using a stranded push switch and the switch is wired one side into 5v with resistor into ground and the other side into pin 6 (hope that made sens i'm really new at this)
Logged
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
It is doing exactly what you programmed to do.  You hold the button down, led gets incremented and so it goes on.  What do you want it to do ?  I expect that you want it to increment led each time the button is pressed.  In which case you need to ignore the button being held down (same value from digitalRead each time you check) and note when the button has been released and wait for it to be pressed again.  You will also need to debounce the button at some time too in order to avoid false readings.
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
In short, button state change and debounce. Unless you can debounce and latch the button via hardware, look into those examples provided to you in the arduino software.
« Last Edit: February 12, 2013, 06:13:17 pm by HazardsMind » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Offline Offline
Newbie
View Profile
Thanks guys will take a crack at that and let you no how i get on : )
Logged
UK
Offline Offline
Tesla Member
View Profile
Maybe I'm just misunderstanding you, but that doesn't sound right.
I suggest you enable the internal pull-up resistor on the input pin, and connect the switch between the pin and ground. Then the input will read HIGH when the switch is open and LOW when it is closed.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
For future reference:
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Code tags, not monospaced font.
Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
You need to de-bounce the button (see examples). Also take a look at the use of digitalWrite(pin,HIGH|LOW) don't use analogWrite() just to turn LED's on and off.
Also take a look at "blink without delay()" and the use of functions in general.
Mark
Logged
Pages: [1]   Go Up
Print
Jump to:
