Italy
Offline
God Member
O ti distingui o ti estingui
« on: February 12, 2013, 05:41:03 pm » |
Hi, All As promised the pinout diagram of Esplora.  rev 1 - 13.02.2013 Download PDF THIS IS A PRERELEASE VERSION! The ATMega32U4 Pinout (The processor of Esplora)  Download PDF
« Last Edit: February 13, 2013, 08:48:08 am by pighixxx »
Logged
US
Offline
Full Member
Electronics are the new Legos
« Reply #1 on: February 12, 2013, 07:15:52 pm » |
Very good, I'm a big fan of your graphics. Maps to what I wrote last December. http://21stdigitalhome.blogspot.com/2012/12/esplora-expansion-header-pinouts.htmlOn the Esplora a couple things: I hope at some point the Arduino team labels the pins but it might not happen readily as this is supposed to be the Arduino for Beginners when a broader take on using this (like RasPi - beginners through advanced) would result in more sales.
Logged
Italy
Offline
God Member
« Reply #2 on: February 12, 2013, 07:24:37 pm » |
Thanks for the notes, are appreciated! This is my first release of Esplora. This is the beginning of a new type of the infographics that I will do in the future. Esplora will be the first, then be modifying all the other cards. In the next release i change "Phisical Pin" to "Processor Pin"  Bye, Pighixxx
Logged
US
Offline
Full Member
« Reply #3 on: February 12, 2013, 09:47:04 pm » |
Grazie per la vostra attenzione
Logged
Italy
Offline
God Member
« Reply #4 on: February 13, 2013, 08:48:52 am » |
rev 1 on line. Refresh page to see in first post. Pighixxx
Logged
Netherlands
Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #5 on: February 13, 2013, 12:53:04 pm » |
Thanks for sharing!
Logged
Offline
Newbie
« Reply #6 on: February 19, 2013, 08:15:37 pm » |
Really nice work!
Logged
Italy
Offline
God Member
« Reply #7 on: February 20, 2013, 06:03:40 am » |
Thanks!
As soon a new version more readable...
Logged
US
Offline
Full Member
« Reply #8 on: February 20, 2013, 06:14:11 am » |
If you are tweaking it, can you label the microphone and icsp on the board? Also is there any info on current per pin? Again you do great work.
« Last Edit: February 20, 2013, 06:18:29 am by TheKitty »
Logged
Italy
Offline
Newbie
« Reply #9 on: May 07, 2013, 07:27:28 am » |
Hi everybody, i'm new in Arduino Esplora and i would like to know if is possible to choose the string pins (beside the 4 push buttons) as output pins as i get used on the Arduino Uno. I need to connect 7 indipendent leds to the board.. is it possible? How can i control them?? Thanks and sorry for my english!
Logged
US
Offline
Full Member
« Reply #10 on: May 07, 2013, 11:51:56 am » |
See the lines D14, 15, 16, 7, 8, D0, and D1 on the expansion header? They are digital pins that you can connect to an LED and resistor (220 to 330 ohm or so) to ground. This would probably require a little board to mount them. Then you can use digitalWrite function in code to turn them on and off.
Logged
Italy
Offline
Newbie
« Reply #11 on: May 08, 2013, 06:22:17 am » |
Thank you!!!!!  the answer was very complete! so i can control those pins as in Arduino Uno.. last question.. is it possible to read a voltage signal as input?? maybe on the TinkerKit input? thanks!
Logged
US
Offline
Full Member
« Reply #12 on: May 08, 2013, 07:01:00 pm » |
The diagram shows D8 is the same as Analog A9 but I have not tried to read that pin as an analog pin but you can try and let us know. If you wanted to use another pin or two for LEDs you can use the two Tinkerkit outputs or the SPI pins D14, 15, and 16.
Logged
