Topic: Unofficial Esplora Pinout Diagram (Read 32855 times) previous topic - next topic
pighixxx
Feb 12, 2013, 11:41 pm Last Edit: Aug 04, 2014, 12:44 pm by pighixxx Reason: 1
A new version available!
Download here: http://pighixxx.com/esplorapdf.pdf
Hi, All
As promised the pinout diagram of Esplora.
rev 1 - 13.02.2013
Download PDF
THIS IS A PRERELEASE VERSION!
The ATMega32U4 Pinout (The processor of Esplora)
Download PDF
TheKitty
Very good, I'm a big fan of your graphics.  Maps to what I wrote last December.  http://21stdigitalhome.blogspot.com/2012/12/esplora-expansion-header-pinouts.html
On the Esplora a couple things:
  • Can the Physical Pin category be labeled Processor Pin for clarity?
  • On ICSP, you can also label MISO, MOSI, and SCLK with the brown IDE pins D14-D16
  • On the orange TinkerKit outputs, could the lines point to the center pin of each?  The leftmost is +5 and the right ground on each. http://21stdigitalhome.blogspot.com/2013/01/arduino-esplora-tinkerkit-outputs.html
I hope at some point the Arduino team labels the pins but it might not happen readily as this is supposed to be the Arduino for Beginners when a broader take on using this (like RasPi - beginners through advanced) would result in more sales.
pighixxx
(cut)
Thanks for the notes, are appreciated!
This is my first release of Esplora.
This is the beginning of a new type of the infographics that I will do in the future. Esplora will be the first, then be modifying all the other cards.
In the next release i change "Phisical Pin" to "Processor Pin"  ;)
Bye,
Pighixxx
TheKitty
pighixxx
rev 1 on line.
Refresh page to see in first post.
Pighixxx :D
robtillaart
Rob Tillaart
okay1984
pighixxx
Thanks!
As soon a new version more readable...
TheKitty
#8
Feb 20, 2013, 12:14 pm Last Edit: Feb 20, 2013, 12:18 pm by TheKitty Reason: 1
If you are tweaking it, can you label the microphone and icsp on the board?  Also is there any info on current per pin?  Again you do great work.
odenvikingson
Hi everybody,
  i'm new in Arduino Esplora and i would like to know if is possible to choose the string pins (beside the 4 push buttons) as output pins as i get used on the Arduino Uno.
I need to connect 7 indipendent leds to the board.. is it possible? How can i control them??
Thanks and sorry for my english!
TheKitty
See the lines D14, 15, 16, 7, 8, D0, and D1 on the expansion header?  They are digital pins that you can connect to an LED and resistor (220 to 330 ohm or so) to ground.  This would probably require a little board to mount them. Then you can use digitalWrite function in code to turn them on and off.
odenvikingson
Thank you!!!!! ;)
the answer was very complete! so i can control those pins as in Arduino Uno.. last question.. is it possible to read a voltage signal as input?? maybe on the TinkerKit input?
thanks!
TheKitty
The diagram shows D8 is the same as Analog A9 but I have not tried to read that pin as an analog pin but you can try and let us know.  If you wanted to use another pin or two for LEDs you can use the two Tinkerkit outputs or the SPI pins D14, 15, and 16.
pighixxx
ghost2501
#14
May 07, 2015, 05:21 am Last Edit: May 07, 2015, 05:22 am by ghost2501
Hello In your earlier Esplora pin outs you show the orange tinkerkit outputs with the correct pin out it goes
5v   |   digital_out  | GND
your latest 3.0 revision has it wrong and shows it:
GND | digital_out    | 5V
I can assure you the latest 3.0 is incorrect and needs to be changed.
here is another reference that has been working for a long time now and I just hooked it up to my oscilloscope and i can assure you the current one is wrong.
