Topic: Help with GET request? (Read 2922 times) previous topic - next topic
TheSpy7
Hey there... Getting pretty frustrated. My code returns that it successfully sent the GET request, however I should get a phone call if it does. I know that it is an programming problem. I have censored out certain URLs in the code. Here is my code:
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 3;
const int DELAY_VAL = 2;
const int MAX_SHIFT_VAL = 1023;
char keys[ROWS][COLS] = {
   {'1','2','3'}
  ,{'4','5','6'}
  ,{'7','8','9'}
  ,{'*','0','#'}
}; // map out the keys
// map out the pins
byte rowPins[ROWS] = {5,6,7,8};
byte colPins[COLS] = {2,3,4};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
byte mac[] = { 0x90, 0xA2, 0xDA, 0x04, 0x00, 0x8D }; //physical mac address
char serverName[] = "api.tropo.com"; // zoomkat's test web page server
// instantiate a network client
EthernetClient client;
int buttonState = 0; // soft reset button state
String phoneNumber = "";
String clip = "";
  // start the serial library:
  // set display brightness
  Serial.write(0x7C);
  Serial.write(157);
  // set screen size in case LCD gets derpy...
  Serial.write(0xFE);
  Serial.write(6);
  Serial.write(0xFE);
  Serial.write(4);
  delay(4000);
  // start the Ethernet connection:
  // set up soft reset button
  ////attachInterrupt(0, softReset, CHANGE);
  // clear screen
  clearDisplay();
  ////digitalWrite(softResetPin, LOW);
  // read the state of the reset button value:
  // check if the pushbutton is pressed (HIGH)
  delay(70); // delay loop to keep the LCD from redrawing stuff too much
  char keyPressed = keypad.getKey(); // need to check press selection on keypad
  if (keyPressed)
    if (keyPressed == '#') // # and * are reveresed for some reason
      clearDisplay();
      selectFirstLine();
      Serial.print("THE GAME");
    else if (keyPressed == '*')
      clearDisplay();
      selectFirstLine();
      Serial.print("i said wut wut");
      selectSecondLine();
      Serial.print("in the *");
      // check for complete number
      if (phoneNumber.length() == 10)
        selectSecondLine();
        // determine which sound clip to play
        switch (keyPressed)
        case '1':
          Serial.print("Rickroll");
          clip = "afdsfads";
        case '2':
          Serial.print("Nyan Cat");
          clip = "dafsfadfda";
        case '3':
          Serial.print("Still Alive");
          clip = "adsfads";
        case '4':
          Serial.print("Hurr Durr");
          clip = "adsfdfas";
        case '5':
          Serial.print("Heyyeahyeah");
          clip = "adfasfdafads";
        case '6':
          Serial.print("Friday");
          clip = "adadfddafs";
        case '7':
          Serial.print("Tiny Tim");
          clip = "adsfdfa";
        case '8':
          Serial.print("Banana Phone"); // OH GOD WHAT HAVE I DONE
          clip = "dasdfsafsd";
        case '9':
          Serial.print("Britney Rant");
          clip = "fadsfdsadsf";
        delay(3000);
        phoneNumber = phoneNumber + keyPressed;
    clearDisplay();
      if (clip == "")
        selectFirstLine();
        Serial.print("Trolling option:");
        selectFirstLine();
        Serial.print("Connecting...");
        // proceed to lulz
        sendGET();
        delay(10000);
        // close connection to ensure proper re-connect
        client.stop();
        selectSecondLine();
          Serial.print("Great Success!");
          selectFirstLine();
          delay(5000);
          phoneNumber = "";
          clip = "";
      selectFirstLine();
      Serial.print("Phone number:");
      if (phoneNumber.length() > 0)
        selectSecondLine();
        Serial.print(phoneNumber);
void clearDisplay() {
  Serial.write(0xFE);
  Serial.write(0x01);
void selectFirstLine() {
  Serial.write(0xFE);
  Serial.write(128);
   //delay(10);
void selectSecondLine() {
  Serial.write(0xFE);
  Serial.write(192);
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /1.0/sessions?action=create&token=asdffads&number=asdffdafad HTTP/1.0"); //download text
    client.println("Host: api.tropo.com");
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
holmes4
Which Aduino do you have?, who is the LCD attached to it?
Mark
TheSpy7
Uno R3, the lcd is here: https://www.sparkfun.com/products/9395
PeterH
Does the "phone call" thing work correctly when you perform the identical GET request from the browser?
You sketch prints out the response to the HTTP GET request. Does that show the same response you get when you used the browser to do the GET?
holmes4
I think you should be using softSerial on pins other than 0+1, so that you can use Serial for debugging.
Mark
nickgammon
Please post all of the response you get from the sketch.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
TheSpy7
So the response is totally correct. It does not show the output of the GET request. The GET request DOES work in a browser. The response serial is just successful and then it says Great success!
PeterH
How do you know the response is correct, if you haven't seen it?
This code looks as if it prints the response to the serial monitor:
Code: [Select]
Why is there no output from that code?
TheSpy7
See, that's the problem. I have no idea why! It goes through and says "success" or whatever, but never ACTUALLY sends the GET request!
PeterH
Well, I don't know whether it's sending it or not, and I don't suppose you do either.
You need to sort out sendGET() so it tells you what actually happened during the process of sending the request and receiving the response. So far you haven't posted any evidence to prove that the function is even being called at all.
TheSpy7
#10
Feb 13, 2013, 01:53 am Last Edit: Feb 13, 2013, 01:55 am by TheSpy7 Reason: 1
Its not sending it, but it acts like it did send it successfully. I will try to see what debug I can get.
spatula
#11
Feb 13, 2013, 02:12 am Last Edit: Feb 13, 2013, 03:35 am by spatula Reason: 1
Are you using a proxy?
If you can get nc (or netcat) working on your system you can echo the messages sent to a local port, e.g.
Code: [Select]
nc -l 8000
[edit] Then change your parameters to connect to localhost your system's IP address port 8000 and see what happens.
TheSpy7
Code: [Select]
nc -l 8000
Then change your parameters to connect to localhost port 8000 and see what happens.
Eh, not interested. I just want to know why the current code doesn't work.
SurferTim
It is required that you start the ethernet connection with Ethernet.begin(mac). You mention it with a comment, but never start it. I added it below.
Code: [Select]
  Serial.write(0x7C);
  Serial.write(157);
  Serial.write(0xFE);
  Serial.write(6);
  Serial.write(0xFE);
  Serial.write(4);
  delay(4000);
  if(!Ethernet.begin(mac)) Serial.println("ethernet failed");
  else Serial.println(Ethernet.localIP());
  // clear screen
  clearDisplay();
spatula
Fine. I took the liberty of modifying my original suggestion because it was wrong.
Perhaps you might be more interested in persistent connections under HTTP/1.0.
