Tweaked the code a bit. Here is new output followed by new code.
|þþþþþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þÀ1þþPhone number:þÀ1þþPhone number:þÀ1þþPhone number:þÀ11þþPhone number:þÀ11þþPhone number:þÀ11þþPhone number:þÀ111þþPhone number:þÀ111þþPhone number:þÀ1111þþPhone number:þÀ1111þþPhone number:þÀ11111þþPhone number:þÀ11111þþPhone number:þÀ11111þþPhone number:þÀ111111þþPhone number:þÀ111111þþPhone number:þÀ111111þþPhone number:þÀ1111111þþPhone number:þÀ1111111þþPhone number:þÀ11111111þþPhone number:þÀ11111111þþPhone number:þÀ11111111þþPhone number:þÀ111111111þþPhone number:þÀ111111111þþPhone number:þÀ111111111þþTrolling option:þþTrolling option:þþTrolling option:þþTrolling option:þþTrolling option:þÀRickrollþþConnecting...connection failed
disconnecting.
þÀGreat Success!þþþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:þþPhone number:
#include <SPI.h>
#include <Ethernet.h>
#include <Keypad.h>
#include <EthernetClient.h>
const byte ROWS = 4;
const byte COLS = 3;
const int DELAY_VAL = 2;
const int MAX_SHIFT_VAL = 1023;
int buttonState = 0; // soft reset button state
String phoneNumber = "";
String clip = "";
char keys[ROWS][COLS] = {
{'1','2','3'}
,{'4','5','6'}
,{'7','8','9'}
,{'*','0','#'}
}; // map out the keys
// map out the pins
byte rowPins[ROWS] = {5,6,7,8};
byte colPins[COLS] = {2,3,4};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
byte mac[] = { 0x90, 0xA2, 0xDA, 0x04, 0x00, 0x8D }; //physical mac address
byte subnet[] = {255,255,255,0};
byte gateway[] = {192,168,1,1};
char server[] = "www.api.tropo.com"; // zoomkat's test web page server
// instantiate a network client
EthernetClient client;
// start the serial library:
// set display brightness
Serial.write(0x7C);
Serial.write(157);
// set screen size in case LCD gets derpy...
Serial.write(0xFE);
Serial.write(6);
Serial.write(0xFE);
Serial.write(4);
delay(4000);
Ethernet.begin(mac, subnet, gateway);
// start the Ethernet connection:
// set up soft reset button
////attachInterrupt(0, softReset, CHANGE);
// clear screen
clearDisplay();
////digitalWrite(softResetPin, LOW);
// read the state of the reset button value:
// check if the pushbutton is pressed (HIGH)
delay(70); // delay loop to keep the LCD from redrawing stuff too much
char keyPressed = keypad.getKey(); // need to check press selection on keypad
if (keyPressed)
if (keyPressed == '#') // # and * are reveresed for some reason
clearDisplay();
selectFirstLine();
Serial.print("THE GAME");
else if (keyPressed == '*')
clearDisplay();
selectFirstLine();
Serial.print("i said wut wut");
selectSecondLine();
Serial.print("in the *");
// check for complete number
if (phoneNumber.length() == 10)
selectSecondLine();
// determine which sound clip to play
switch (keyPressed)
case '1':
Serial.print("Rickroll");
clip = "dfs";
case '2':
Serial.print("Nyan Cat");
clip = "fds";
case '3':
Serial.print("Still Alive");
clip = "fds";
case '4':
Serial.print("Hurr Durr");
clip = "dfsfds";
case '5':
Serial.print("Heyyeahyeah");
clip = "sdf";
case '6':
Serial.print("Friday");
clip = "sfd";
case '7':
Serial.print("Tiny Tim");
clip = "dfs";
case '8':
Serial.print("Banana Phone"); // OH GOD WHAT HAVE I DONE
clip = "fsd";
case '9':
Serial.print("Britney Rant");
clip = "dsf";
delay(3000);
phoneNumber = phoneNumber + keyPressed;
clearDisplay();
if (clip == "")
selectFirstLine();
Serial.print("Trolling option:");
selectFirstLine();
Serial.print("Connecting...");
// proceed to lulz
sendGET();
delay(10000);
// close connection to ensure proper re-connect
client.stop();
selectSecondLine();
Serial.print("Great Success!");
selectFirstLine();
delay(5000);
phoneNumber = "";
clip = "";
selectFirstLine();
Serial.print("Phone number:");
if (phoneNumber.length() > 0)
selectSecondLine();
Serial.print(phoneNumber);
void clearDisplay() {
Serial.write(0xFE);
Serial.write(0x01);
void selectFirstLine() {
Serial.write(0xFE);
Serial.write(128);
//delay(10);
void selectSecondLine() {
Serial.write(0xFE);
Serial.write(192);
void sendGET() //client function to send/receive GET request data.
if (client.connect(server, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET /1.0/sessions?action=create&token=fsdfd&number=fsdfds2 HTTP/1.0"); //download text
client.println("Host: www.api.tropo.com");
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
Serial.print(c); //prints byte to serial monitor
Serial.println("disconnecting.");
Serial.println("==================");
client.stop(); //stop client
