« on: February 12, 2013, 05:51:49 pm » |
Hey there... Getting pretty frustrated. My code returns that it successfully sent the GET request, however I should get a phone call if it does. I know that it is an programming problem. I have censored out certain URLs in the code. Here is my code: /*
#include <SPI.h> #include <Ethernet.h> #include <Keypad.h> const byte ROWS = 4; const byte COLS = 3; const int DELAY_VAL = 2; const int MAX_SHIFT_VAL = 1023;
char keys[ROWS][COLS] = { {'1','2','3'} ,{'4','5','6'} ,{'7','8','9'} ,{'*','0','#'} }; // map out the keys
// map out the pins byte rowPins[ROWS] = {5,6,7,8}; byte colPins[COLS] = {2,3,4};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
byte mac[] = { 0x90, 0xA2, 0xDA, 0x04, 0x00, 0x8D }; //physical mac address char serverName[] = "api.tropo.com"; // zoomkat's test web page server
// instantiate a network client EthernetClient client; int buttonState = 0; // soft reset button state String phoneNumber = ""; String clip = "";
void setup() { // start the serial library: Serial.begin(9600); // set display brightness Serial.write(0x7C); Serial.write(157); // set screen size in case LCD gets derpy... Serial.write(0xFE); Serial.write(6); Serial.write(0xFE); Serial.write(4); delay(4000); // start the Ethernet connection: // set up soft reset button
////attachInterrupt(0, softReset, CHANGE); // clear screen clearDisplay(); }
void loop() { ////digitalWrite(softResetPin, LOW); // read the state of the reset button value: // check if the pushbutton is pressed (HIGH) delay(70); // delay loop to keep the LCD from redrawing stuff too much char keyPressed = keypad.getKey(); // need to check press selection on keypad
if (keyPressed) { if (keyPressed == '#') // # and * are reveresed for some reason { clearDisplay(); selectFirstLine(); Serial.print("THE GAME"); delay(500); } else if (keyPressed == '*') { clearDisplay(); selectFirstLine(); Serial.print("i said wut wut"); selectSecondLine(); Serial.print("in the *"); delay(1000); } else { // check for complete number if (phoneNumber.length() == 10) { selectSecondLine(); // determine which sound clip to play switch (keyPressed) { case '1': Serial.print("Rickroll"); clip = "afdsfads"; break; case '2': Serial.print("Nyan Cat"); clip = "dafsfadfda"; break; case '3': Serial.print("Still Alive"); clip = "adsfads"; break; case '4': Serial.print("Hurr Durr"); clip = "adsfdfas"; break; case '5': Serial.print("Heyyeahyeah"); clip = "adfasfdafads"; break; case '6': Serial.print("Friday"); clip = "adadfddafs"; break; case '7': Serial.print("Tiny Tim"); clip = "adsfdfa"; break; case '8': Serial.print("Banana Phone"); // OH GOD WHAT HAVE I DONE clip = "dasdfsafsd"; break; case '9': Serial.print("Britney Rant"); clip = "fadsfdsadsf"; break; } delay(3000); } else { phoneNumber = phoneNumber + keyPressed; } } } else { clearDisplay(); if (phoneNumber.length() == 10) { if (clip == "") { selectFirstLine(); Serial.print("Trolling option:"); } else { selectFirstLine(); Serial.print("Connecting..."); // proceed to lulz sendGET(); delay(10000); // close connection to ensure proper re-connect client.stop(); selectSecondLine(); Serial.print("Great Success!"); selectFirstLine(); delay(5000); phoneNumber = ""; clip = ""; } } else { selectFirstLine(); Serial.print("Phone number:"); if (phoneNumber.length() > 0) { selectSecondLine(); Serial.print(phoneNumber); } } } }
void clearDisplay() { Serial.write(0xFE); Serial.write(0x01); }
void selectFirstLine() { Serial.write(0xFE); Serial.write(128); //delay(10); }
void selectSecondLine() { Serial.write(0xFE); Serial.write(192); }
void sendGET() //client function to send/receive GET request data. { if (client.connect(serverName, 80)) { //starts client connection, checks for connection Serial.println("connected"); client.println("GET /1.0/sessions?action=create&token=asdffads&number=asdffdafad HTTP/1.0"); //download text client.println("Host: api.tropo.com"); client.println(); //end of get request } else { Serial.println("connection failed"); //error message if no client connect Serial.println(); }
while(client.connected() && !client.available()) delay(1); //waits for data while (client.connected() || client.available()) { //connected or data available char c = client.read(); //gets byte from ethernet buffer Serial.print(c); //prints byte to serial monitor }
Serial.println(); Serial.println("disconnecting."); Serial.println("=================="); Serial.println(); client.stop(); //stop client
Poole, Dorset, UK
« Reply #1 on: February 12, 2013, 06:07:55 pm » |
Which Aduino do you have?, who is the LCD attached to it?
Mark
« Reply #2 on: February 12, 2013, 06:10:28 pm » |
UK
« Reply #3 on: February 12, 2013, 06:56:47 pm » |
Does the "phone call" thing work correctly when you perform the identical GET request from the browser?
You sketch prints out the response to the HTTP GET request. Does that show the same response you get when you used the browser to do the GET?
Poole, Dorset, UK
« Reply #4 on: February 12, 2013, 07:01:08 pm » |
I think you should be using softSerial on pins other than 0+1, so that you can use Serial for debugging.
Mark
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #5 on: February 12, 2013, 07:06:43 pm » |
Please post all of the response you get from the sketch.
« Reply #6 on: February 12, 2013, 07:25:13 pm » |
So the response is totally correct. It does not show the output of the GET request. The GET request DOES work in a browser. The response serial is just successful and then it says Great success!
UK
« Reply #7 on: February 12, 2013, 07:34:46 pm » |
How do you know the response is correct, if you haven't seen it? This code looks as if it prints the response to the serial monitor: while (client.connected() || client.available()) { //connected or data available char c = client.read(); //gets byte from ethernet buffer Serial.print(c); //prints byte to serial monitor }
Why is there no output from that code?
« Reply #8 on: February 12, 2013, 07:36:45 pm » |
See, that's the problem. I have no idea why! It goes through and says "success" or whatever, but never ACTUALLY sends the GET request!
UK
« Reply #9 on: February 12, 2013, 07:46:56 pm » |
Well, I don't know whether it's sending it or not, and I don't suppose you do either. You need to sort out sendGET() so it tells you what actually happened during the process of sending the request and receiving the response. So far you haven't posted any evidence to prove that the function is even being called at all.
« Reply #10 on: February 12, 2013, 07:53:33 pm » |
Its not sending it, but it acts like it did send it successfully. I will try to see what debug I can get.
« Last Edit: February 12, 2013, 07:55:40 pm by TheSpy7 »
Rome, Italy
« Reply #11 on: February 12, 2013, 08:12:32 pm » |
Are you using a proxy? If you can get nc (or netcat) working on your system you can echo the messages sent to a local port, e.g. nc -l 8000 [edit] Then change your parameters to connect to localhost your system's IP address port 8000 and see what happens.
« Last Edit: February 12, 2013, 09:35:06 pm by spatula »
« Reply #12 on: February 12, 2013, 08:17:51 pm » |
Are you using a proxy? If you can get nc (or netcat) working on your system you can echo the messages sent to a local port, e.g. nc -l 8000 Then change your parameters to connect to localhost port 8000 and see what happens. Eh, not interested. I just want to know why the current code doesn't work.
Miramar Beach, Florida
« Reply #13 on: February 12, 2013, 09:49:14 pm » |
It is required that you start the ethernet connection with Ethernet.begin(mac). You mention it with a comment, but never start it. I added it below. void setup() { // start the serial library: Serial.begin(9600); // set display brightness Serial.write(0x7C); Serial.write(157); // set screen size in case LCD gets derpy... Serial.write(0xFE); Serial.write(6); Serial.write(0xFE); Serial.write(4); delay(4000);
// start the Ethernet connection: if(!Ethernet.begin(mac)) Serial.println("ethernet failed"); else Serial.println(Ethernet.localIP());
// set up soft reset button ////attachInterrupt(0, softReset, CHANGE); // clear screen clearDisplay(); }
Rome, Italy
« Reply #14 on: February 12, 2013, 09:50:13 pm » |
Fine. I took the liberty of modifying my original suggestion because it was wrong. Perhaps you might be more interested in persistent connections under HTTP/1.0.
