Topic: [SOLVED] uploads fail from debian to due: "no device found on ttyacm0" (Read 9556 times) previous topic - next topic
aude
greetings all,
i recently received an arduino due; i'm running debian squeeze.
all upload attempts fail.
upon plugging in the due via programming port, dmesg gives:
[ 2509.432034] usb 5-1: new full speed USB device using uhci_hcd and address 5
[ 2509.629816] usb 5-1: New USB device found, idVendor=2341, idProduct=003d
[ 2509.629822] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[ 2509.629827] usb 5-1: Product: Arduino Due Prog. Port
[ 2509.629830] usb 5-1: Manufacturer: Arduino (www.arduino.cc)
[ 2509.629833] usb 5-1: SerialNumber: A4139363931351316291
[ 2509.629987] usb 5-1: configuration #1 chosen from 1 choice
[ 2509.632923] cdc_acm 5-1:1.0: ttyACM0: USB ACM device
ls -al /dev/ttyACM* returns:
crw-rw-rw- 1 root dialout 166, 0 Feb 12 06:58 /dev/ttyACM0
i'm using the latest IDE (1.5.2 linux-32) w/support for the due from the main site.
in the ide, i am able to select '/dev/ttyACM0' under Tools > Serial Port
and the board under Tools > Board > Arduino Due programming port.
everytime i attempt to upload a basic/empty sketch, i receive:
Binary sketch size: 9,624 bytes (of a 524,288 byte maximum) - 1% used
No device found on ttyACM0
whether i run the ide as root or normal user.
i've combed g**gle to no avail. none of the suggestions i've read in the 'duino forums seems to help or present the same problem.
ps - i attempted to upload under windows- only once though. the drivers install, but the ide closes immediately upon opening with a sound notification but no error window or message appears. i only tried once though and haven't since the initial install (i.e., no reboot).
any help or advice would be grandly appreciated.
thanks
aude
also,
lsusb reports:
Bus 005 Device 005: ID 2341:003d
Bus 005 Device 003: ID 046d:c51b Logitech, Inc. V220 Cordless Optical Mouse for Notebooks
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 045e:0750 Microsoft Corp. Wired Keyboard 600
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 13b1:000e Linksys WUSB54GS v1 802.11g Adapter [Broadcom 4320 USB]
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
should i be able to see the board explicitly?
aude
oh- last addition:
the green power light is illuminated on the board.
the L (led, pin13?) blinks steadiily.
upon attempting to upload, the tx light blinks several times, rapidly, turns off, and then i'm presented on-screen with the upload error.
nigelbarker
I assume that when you plug the due in you see entries in /var/log/messages?
I see :-
Feb 12 23:47:32 nigellap kernel: [ 3748.664298] usb 7-1: new full speed USB device using uhci_hcd and address 16
Feb 12 23:47:32 nigellap kernel: [ 3748.862679] usb 7-1: New USB device found, idVendor=2341, idProduct=0010
Feb 12 23:47:32 nigellap kernel: [ 3748.862688] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=220
Feb 12 23:47:32 nigellap kernel: [ 3748.862695] usb 7-1: Product: Arduino Mega 2560
Feb 12 23:47:32 nigellap kernel: [ 3748.862700] usb 7-1: Manufacturer: Arduino (www.arduino.cc)
Feb 12 23:47:32 nigellap kernel: [ 3748.862704] usb 7-1: SerialNumber: 7523733353635140F092
Feb 12 23:47:32 nigellap kernel: [ 3748.862948] usb 7-1: configuration #1 chosen from 1 choice
Feb 12 23:47:32 nigellap kernel: [ 3748.864644] cdc_acm 7-1:1.0: ttyACM0: USB ACM device
and this confirms the correct serial port.
(Mind I'm on 64 bit, and using a mega not a due)
Nige
aude
cat /var/log/messages gives:
Feb 12 07:39:20 aude kernel: [10196.184023] usb 5-1: new full speed USB device using uhci_hcd and address 6
Feb 12 07:39:21 aude kernel: [10196.383289] usb 5-1: New USB device found, idVendor=2341, idProduct=003d
Feb 12 07:39:21 aude kernel: [10196.383295] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=220
Feb 12 07:39:21 aude kernel: [10196.383299] usb 5-1: Product: Arduino Due Prog. Port
Feb 12 07:39:21 aude kernel: [10196.383302] usb 5-1: Manufacturer: Arduino (www.arduino.cc)
Feb 12 07:39:21 aude kernel: [10196.383306] usb 5-1: SerialNumber: A4139363931351316291
Feb 12 07:39:21 aude kernel: [10196.383449] usb 5-1: configuration #1 chosen from 1 choice
Feb 12 07:39:21 aude kernel: [10196.386397] cdc_acm 5-1:1.0: ttyACM0: USB ACM device
aude
from this post: http://arduino.cc/forum/index.php?topic=63259.0
i tried to reload usbserial and cdc_acm when i noticed usbserial hadn't loaded.
and usbserial doesn't load when i restart and replug in the due- even though dmesg reports the above.
so i modprobe usbserial and reload cdc_acm, but nothing changes.
setserial -G /dev/ttyACM0 gives:
Cannot get serial info: Invalid argument
...not really sure what to do think about that..
nigelbarker
Sounds to me like Debian sees it ok, just the loader doesn't.
My version is 1.0.3 - 2012.12.10 (downloaded yesterday) but is the 64 bit version.
I downloaded the tgz, unzipped it and ran the executable as root.
However, I did do a fair amount of playing first (trying to get the command line to work), and am using a different board.
I'll have another play this evening, but I don't think I'm going to be much help.
Nige
aude
so after spending *hours* surfing and testing, the solution was incredibly simple.
when i plug in the due, the baud rate is set at 115200 automatically. all i have to do is set the baud rate to 1200 before every upload and all uploads are successful from the ide!
i suppose i'll make that a more permanent fix (with udev?) but for now, i don't mind hitting [up] at the terminal.
for anyone having the same problem, i first found the solution while in windows.
i followed the instructions on this site to set the baud rate with the 'mode' command from a command prompt:
https://sites.google.com/site/arduinodueatmelstudio/home/uploading-code-to-due
the linux equivalent, i got from:
http://stackoverflow.com/questions/8877269/writing-to-serial-port-from-linux-command-line.
in case those sites aren't around as long as this one, the commands issued were:
mode com3: baud=1200 data=8 parity=n stop=1
from the command prompt
and
stty -F /dev/ttyACM0 speed 1200 cs8 -cstopb -parenb
from the terminal.
cheers
wyojustin
Danoino
I have the same problem as described at the top:
When trying to upload a sketch via the USB Programming Port the following error message appears:
Code: [Select]
No device found on /dev/tty.usbmodem1421
However, when I connect the Arduino via the Native USB Port the sketch is uploaded and runs just fine.
I am using an Arduino Due, Arduino IDE 1.5.4 and Mac OS 10.9 (Mavericks).
Would the problem in my case also be the Baud rate? If yes, how do I change it on a Mac?
I would be very happy about any help.
