Loading...
Pages: [1]   Go Down
Author Topic: SainSmart tft 3.2 lcd display not working.  (Read 745 times)
Offline Offline
Newbie
View Profile
I got a new 3.2 lcd screen and it wont work. It lights up so it must be getting power, but nothing comes on the screen. I have no errors when compiling.
Code:
// UTFT_Textrotation_Demo (C)2012 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of the textrotation-functions.
// This demo was made for modules with a screen resolution
// of 320x240 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
// Uncomment the next line for Arduino 2009/Uno
//UTFT myGLCD(ITDB32S,19,18,17,16);   // Remember to change the model parameter to suit your display module!
// Uncomment the next line for Arduino Mega
UTFT myGLCD(ITDB32S,38,39,40,41);   // Remember to change the model parameter to suit your display module!
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(BigFont);
    myGLCD.print("Text rotation", 0, 0);
    myGLCD.setColor(0, 0, 255);
    myGLCD.print("0 degrees", 0, 16, 0);
    myGLCD.print("90 degrees", 319, 0, 90);
    myGLCD.print("180 degrees", 319, 239, 180);
    myGLCD.print("270 degrees", 0, 239, 270);
    myGLCD.setFont(SevenSegNumFont);
    myGLCD.setColor(0, 255, 0);
    myGLCD.print("45", 90, 100, 45);
    myGLCD.print("90", 200, 50, 90);
    myGLCD.print("180", 300, 200, 180);
  while (true) {};
Logged
Dee Why NSW
Offline Offline
God Member
View Profile
I understand there is some confusion about the wiring. If you trawl back through this forum you will find quite a bit of information about it.
Logged
Washington
Offline Offline
Newbie
View Profile
Are you using the shield or plugging directly into the screen's connectors?
The shield has a contrast pot on it which will need to be wired in if you are not using the shield for this project.
Massey
Logged
A Veteran, whether active duty, retired, national guard, or reserve, is someone who, at one point in his or her life, wrote a blank check made payable to their Governmen for an amount of "up to and including my life."
Offline Offline
Newbie
View Profile
Massey
Its an atmega 2560 with a shield and the screen on top.
Logged
Offline Offline
Newbie
View Profile
It looks just like this.
http://www.amazon.com/gp/product/B008FWSH3C/ref=s9_simh_gw_p236_d9_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=10RTCY7G9YJX2K6Q52J8&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
Logged
Offline Offline
Newbie
View Profile
Massey
I have adjusted the contrast pot. It gets power for sure.
Logged
Leeds, England
Offline Offline
Full Member
Quick, chuck it in the bin before the boss finds out...
View Profile
I appreciate that this might not be what you want to hear, but I have the same setup and I have loaded up your code and it works just fine.
Sainsmart Mega 2560, interface board/shield, 3.2" tft display with touch. Not using the SD card slot.
Logged
Offline Offline
Newbie
View Profile
By chance have you done anything to the UTFT library?
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Short of trying to compile your code it looks all right. The lines uncommented are for the mega and the display id "UTFT myGLCD(ITDB32S,38,39,40,41); is the same I use with several of my own  3.2" displays which leaves the contrast pot. If you have a Mega for the Itead display there are 2 versions 1.2 and 2.0... The 1.2 version has a contrast pot that must be adjusted to be able to see the display properly.
It is a 10 turn pot so be careful because the leads to the pot are fragile and be patient... the adjustment is only 2 or 3 turns close to one end of it's rotation (Added).
Bob
« Last Edit: February 15, 2013, 06:46:58 pm by Docedison » Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Offline Offline
Newbie
View Profile
I tried it. Now all I have is a bright white screen.
Logged
Pages: [1]   Go Up
Print
Jump to:
