Topic: SainSmart tft 3.2 lcd display not working. (Read 4461 times) previous topic - next topic
Samuel10
I got a new 3.2 lcd screen and it wont work. It lights up so it must be getting power, but nothing comes on the screen. I have no errors when compiling.
// UTFT_Textrotation_Demo (C)2012 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of the textrotation-functions.
// This demo was made for modules with a screen resolution
// of 320x240 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFont[];
// Uncomment the next line for Arduino 2009/Uno
//UTFT myGLCD(ITDB32S,19,18,17,16);   // Remember to change the model parameter to suit your display module!
// Uncomment the next line for Arduino Mega
UTFT myGLCD(ITDB32S,38,39,40,41);   // Remember to change the model parameter to suit your display module!
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(BigFont);
    myGLCD.print("Text rotation", 0, 0);
    myGLCD.setColor(0, 0, 255);
    myGLCD.print("0 degrees", 0, 16, 0);
    myGLCD.print("90 degrees", 319, 0, 90);
    myGLCD.print("180 degrees", 319, 239, 180);
    myGLCD.print("270 degrees", 0, 239, 270);
    myGLCD.setFont(SevenSegNumFont);
    myGLCD.setColor(0, 255, 0);
    myGLCD.print("45", 90, 100, 45);
    myGLCD.print("90", 200, 50, 90);
    myGLCD.print("180", 300, 200, 180);
  while (true) {};
Nick_Pyner
I understand there is some confusion about the wiring. If you trawl back through this forum you will find quite a bit of information about it.
Massey
Are you using the shield or plugging directly into the screen's connectors?
The shield has a contrast pot on it which will need to be wired in if you are not using the shield for this project.
Massey
A Veteran, whether active duty, retired, national guard, or reserve, is someone who, at one point in his or her life, wrote a blank check ma
Samuel10
Massey
Its an atmega 2560 with a shield and the screen on top.
Samuel10
It looks just like this.
http://www.amazon.com/gp/product/B008FWSH3C/ref=s9_simh_gw_p236_d9_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=10RTCY7G9YJX2K6Q52J8&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
Samuel10
Massey
I have adjusted the contrast pot. It gets power for sure.
dannable
I appreciate that this might not be what you want to hear, but I have the same setup and I have loaded up your code and it works just fine.
Sainsmart Mega 2560, interface board/shield, 3.2" tft display with touch. Not using the SD card slot.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
Samuel10
By chance have you done anything to the UTFT library?
Docedison
#8
Feb 16, 2013, 12:42 am Last Edit: Feb 16, 2013, 12:46 am by Docedison Reason: 1
Short of trying to compile your code it looks all right. The lines uncommented are for the mega and the display id "UTFT myGLCD(ITDB32S,38,39,40,41); is the same I use with several of my own  3.2" displays which leaves the contrast pot. If you have a Mega for the Itead display there are 2 versions 1.2 and 2.0... The 1.2 version has a contrast pot that must be adjusted to be able to see the display properly.
It is a 10 turn pot so be careful because the leads to the pot are fragile and be patient... the adjustment is only 2 or 3 turns close to one end of it's rotation (Added).
Bob
--> WA7EMS <--
Samuel10
I tried it. Now all I have is a bright white screen.
