Topic: Latching memory ?? (Read 820 times) previous topic - next topic
heaintdead
I need an output to turn and stay high after the start button has gone back to false.
A latch from a momentary start
So input button goes high output goes high when input button goes back to false output remains high
liuzengqiang
You are supposed to detect transition on the button, say from low to high, and set output to high when you see this transition. To do this, store the button state and compair with new button state.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
CheapB
so when the input goes high you put the output in high and not touch it again. the output would only go low if you set it low, so unless there is more to the story, this seems pretty straight forward.
liuzengqiang
That's what I suspect. Let's wait and see what the OP will respond.
