Loading...
Pages: [1]   Go Down
Author Topic: WQ730 Turbidity Sensor  (Read 238 times)
Offline Offline
Newbie
View Profile
Hello,
I need to implement a WQ730 Turbidity Sensor in the Arduino .
It's possible??
If no have you an idea about the turbidity sensor if is it compatible with Arduino??
Thank you in advance!!
Logged
Offline Offline
God Member
View Profile
It outputs a "4-20 mA" output,   which is an old fashioned standard for engineering sensors.
You need to measure this output current and then scale the result according to the description
of the device.
This description may help
http://www.bapihvac.com/CatalogPDFs/I_App_Notes/Understanding_Current_Loops.pdf
What you need to do,  is feed the current from the device through a suitable resistor,  and then
measure the voltage across the resistor using the analog input pin of the Arduino.  A 100 ohm
resistor is probably going to work.
Logged
Pages: [1]   Go Up
Print
Jump to:
