Topic: Big easy stepper driver - motor not changing direction. (Read 2090 times) previous topic - next topic
Sjakob
Feb 13, 2013, 06:44 pm Last Edit: Feb 14, 2013, 09:32 am by Sjakob Reason: 1
Im trying to do set up like this :
http://www.schmalzhaus.com/EasyDriver/Examples/EasyDriverExamples.html
...with one stepper motor like this :
http://proto-pic.co.uk/stepper-motor-with-cable/
Im sure its alle wired up corectly but its not changing direction when I run the program-
The only way I can change direction is to change the wires around on one of the coils.
But I cant get the program to do it.
Im sure this is a very stupid question - sorry - I just started.
runaway_pancake
Does that mean that you're reverse the counting in the program or what?
one direction: 00, 01, 11, 10,...
other direction: 00, 10, 11, 01,...
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Chagrin
BigEasyDriver has a step/dir two wire interface.
OP, what program are you using to drive it?
Sjakob
#3
Feb 14, 2013, 09:28 am Last Edit: Feb 14, 2013, 10:25 am by Sjakob Reason: 1
Im using this sketch :
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper(1, 9, 8 );
int pos = 3600;
 stepper.setMaxSpeed(3000);
 stepper.setAcceleration(1000);
 if (stepper.distanceToGo() == 0)
   pos = -pos;
   stepper.moveTo(pos);
 stepper.run();
Witch is suposed to make the motor go back and forth. But it runs the same way - pauses and go same direction.
I do have step and direction pins conectet to 8 and 9 on the arduino.
runaway_pancake
I don't know anything about that AccelStepper library.
Any details?
Either way, I would check (voltmeter) the "step" and "dir" pins' status and connection.
Sjakob
ok. I will try that. Its the same with this sketch :
int Distance = 0;  // Record the number of steps we've taken
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  digitalWrite(9, HIGH);
  delayMicroseconds(100);
  Distance = Distance + 1;   // record this step
  // Check to see if we are at the end of our move
  if (Distance == 3600)
    // We are! Reverse direction (invert DIR signal)
    if (digitalRead(8) == LOW)
      digitalWrite(8, HIGH);
    // Reset our distance back to zero since we're
    // starting a new move
    Distance = 0;
    // Now pause for half a second
I tried with another motor and its the same - so you are prop right. Must be the wires.
