Loading...
Pages: [1]   Go Down
Author Topic: Ds18b20 long wire problem  (Read 216 times)
Offline Offline
Newbie
View Profile
Hello, well I'm developing a system to get the temperature but I need put 20 sensors but the distance its too long, so I was trying with cat 5 ethernet cable, first I try with 3 sensor on each wire (using one wire) but I lost many data, so I try with 2 sensors in each wire, and I'm using 220ohm resistors but its change depending the long of the wire, is this ok or what can I do.
Logged
Offline Offline
God Member
View Profile
Put the computer closer to the data,   and use some other means of transmission.
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Maxim provides an appnote discussing this:
http://www.maximintegrated.com/app-notes/index.mvp/id/148
If you want better answers you should provide more detail as to your topology and how long your cables are.
Logged
Pages: [1]   Go Up
Print
Jump to:
