Topic: Wrong analogRead values (Read 8624 times) previous topic - next topic
gmbroh
Feb 13, 2013, 11:04 pm Last Edit: Feb 14, 2013, 08:41 am by gmbroh Reason: 1
I am trying to measure the voltage of an 5volt AC rectified voltage at 65Hz. Using the UNO R3 Below is the current code.
Code: [Select]
const int numReadings = 25;
int ac_input[numReadings];
const int analogInPin = A0;//Pin for input for AC voltage
float ac_output = 0;
int index = 0;
  pinMode(A0, INPUT);
  for (int thisReading = 0; thisReading < numReadings; thisReading ++)
    ac_input[thisReading] = 0;
  ac_input[index]= analogRead(analogInPin);
  ac_output = ((ac_input[index]/1023.0)*5.0);
  Serial.println(ac_output);
  delay(2);
  index = index + 1;
  if (index >=numReadings)
    index =0;
The problem is that the output on the serial monitor only shows the peak values of the voltage. That is from 4-5v instead of zero.
5
4.98
5
5
4.95
4.62
4.27
4.26
5
4.93
4.7
4.58
5
4.79
5
5
4.35
4.53
5
5
5
4.91
4.84
4.52
5
5
4.67
4.54
5
4.69
5
5
4.43
4.32
5
4.92
5
5
I have tried changing the board I'm using aswell as the input pin.
Has anyone experienced anything similar ?
AWOL
Have a look at this thread
http://arduino.cc/forum/index.php/topic,144195.msg1084872.html#msg1084872
Please use code tags when posting code.
Code: [Select]
they're already zero; this is pointless.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
nickgammon
What are you expecting exactly?  A 65 Hz signal would have a period of 15 mS, and you have a 2 mS delay between readings. What is your circuit?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
PeterH
How have you connected the Arduino to the source?
Where does the rectified signal come from - is it possible that it includes some smoothing?
michinyon
The phrase "5 volt rectified AC voltage"  is gibberish.
If you have rectified it,  it isn't an AC voltage.  The electron flow is no longer alternating in direction.
You will expect to see a DC voltage with a voltage ripple.  Which is exactly what you are getting.
Depending on the type of rectifier,  you will see 65 Hz or 130 Hz ripple.    I can't tell from your
sampling rate, exactly which you are getting.
Your DC voltage has a peak of 5 volts and a minimum of about 4.5 volts.  That is exactly what you
are getting.
PeterH
#5
Feb 14, 2013, 03:23 am Last Edit: Feb 14, 2013, 03:25 am by PeterH Reason: 1
To me that seems like a reasonable way to describe a DC signal which has been obtained by rectifying an AC signal.
Do you mean that this is what would be expected from a rectified sin wave? If so, how did you predict the minimum value?
nickgammon
Is that full-wave or half-wave rectification?
nickgammon
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
retrolefty
And with or without a filter capacitor?
Lefty
nickgammon
See reply #2:
Quote
gmbroh
gmbroh
are getting.
The input to the arduino is 0 to 5volts ac  I dont understand why you think its dc. I have attached a print screen of the input to the arduino
gmbroh
Lefty
It is full wave rectification without a filter capacitor.
Grumpy_Mike
Quote
Without any load resistor the sample and hold capacitor on the arduino input will act as a smoothing capacitor.
Put a 10K load ( resistor) between the analogue input and ground.
AWOL
Quote
Because your scope trace clearly shows everything above 0V.
Alternating current implies a current reversal.
