Topic: Wrong analogRead values (Read 8422 times) previous topic - next topic
nickgammon
#15
Feb 14, 2013, 09:26 am Last Edit: Feb 14, 2013, 09:35 am by Nick Gammon Reason: 1
analogRead works.
However you have built delays into your code.
Code: [Select]
delay (2);
That's 2 mS. Printing the previous result:
Code: [Select]
1/960 * 6 = 6.25 mS
Taking the reading:
Code: [Select]
0.104 mS
So you are basically sampling every 8.354 mS.
The period of a 65 Hz wave would be:
Code: [Select]
1/65 = 15.3 mS
Your sampling isn't fast enough.
You are supposed to sample at twice the frequency, in this case: 7.65 mS, although because of the full-wave rectification I suspect half that, namely 3.825 mS.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
gmbroh
Quote
The input to the arduino is 0 to 5volts ac  I dont understand why you think its dc.
Because your scope trace clearly shows everything above 0V.
Alternating current implies a current reversal.
At first the code was working really well. All I was doing was changing the delay to get different sample rates. Please see below
AWOL
In your other thread on this subject, which I referred to in reply #1, I suggested buffering readings and then printing them out.
Why didn't you do this?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
nickgammon
Quote
The problem is that the output on the serial monitor only shows the peak values of the voltage. That is from 4-5v instead of zero.
The chart you posted (reproduced output) shows the graph reaching zero. What are you talking about?
gmbroh
Quote
The chart of the reproduced output is from when the code was working but not I am not getting those values.
AWOL
Try this: (Compiled but untested.)
Code: [Select]
const int numReadings = 100;
const int analogInPin = A0;
int inputReading [numReadings];
  for (int i = 0; i < numReadings; i++) {
    inputReading [i]= analogRead(analogInPin); // roughly 9kHz sampling
    float voltage = ((inputReading[i]/1023.0)*5.0);
    Serial.println(voltage);
Learning
Unplug it! It'll go to zero. (or pretty close) 8)
AWOL
Bonus marks to Learning if you can explain why those sunglasses are unearned.  8)
(Hint: have you tried it?)
Grumpy_Mike
No it won't it will float which is why I suggested you need a load resistor. So why have you not tried this.
Better still put the scope lead on the analogue input and run the code again. Is it different than when the scope is disconnected.
gmbroh
Code: [Select]
I tried connecting a 10k resistor as someone suggested. And it WORKED !. I uploaded your code for fun and it also works. Its a bit better than mine.... :(
Grumpy_Mike
Quote
As some one once said, tell me when I am wrong not when I am right  8)
Cool glasses justified I think.
