Pages: [1] 2   Go Down
Author Topic: Wrong analogRead values  (Read 548 times)
 I am trying to measure the voltage of an 5volt AC rectified voltage at 65Hz. Using the UNO R3 Below is the current code.
const int numReadings = 25;
int ac_input[numReadings];
const int analogInPin = A0;//Pin for input for AC voltage
float ac_output = 0;
int index = 0;
  pinMode(A0, INPUT);
  for (int thisReading = 0; thisReading < numReadings; thisReading ++)
    ac_input[thisReading] = 0;
  ac_input[index]= analogRead(analogInPin);
  ac_output = ((ac_input[index]/1023.0)*5.0);
  Serial.println(ac_output);
  delay(2);
  index = index + 1;
  if (index >=numReadings)
    index =0;
The problem is that the output on the serial monitor only shows the peak values of the voltage. That is from 4-5v instead of zero.
5
4.98
5
5
4.95
4.62
4.27
4.26
5
4.93
4.7
4.58
5
4.79
5
5
4.35
4.53
5
5
5
4.91
4.84
4.52
5
5
4.67
4.54
5
4.69
5
5
4.43
4.32
5
4.92
5
5
I have tried changing the board I'm using aswell as the input pin.
Has anyone experienced anything similar ?
« Last Edit: February 14, 2013, 02:41:35 am by gmbroh » Logged
UK
Have a look at this thread
http://arduino.cc/forum/index.php/topic,144195.msg1084872.html#msg1084872
Please use code tags when posting code.
they're already zero; this is pointless.
Melbourne, Australia
Shannon Member
Lua rocks!
What are you expecting exactly?  A 65 Hz signal would have a period of 15 mS, and you have a 2 mS delay between readings. What is your circuit?
Milton Keynes UK
How have you connected the Arduino to the source?
Where does the rectified signal come from - is it possible that it includes some smoothing?
The phrase "5 volt rectified AC voltage"  is gibberish.
If you have rectified it,  it isn't an AC voltage.  The electron flow is no longer alternating in direction.
You will expect to see a DC voltage with a voltage ripple.  Which is exactly what you are getting.
Depending on the type of rectifier,  you will see 65 Hz or 130 Hz ripple.    I can't tell from your
sampling rate, exactly which you are getting.
Your DC voltage has a peak of 5 volts and a minimum of about 4.5 volts.  That is exactly what you
are getting.
Milton Keynes UK
To me that seems like a reasonable way to describe a DC signal which has been obtained by rectifying an AC signal.
Do you mean that this is what would be expected from a rectified sin wave? If so, how did you predict the minimum value?
« Last Edit: February 13, 2013, 09:25:41 pm by PeterH » Logged
Shannon Member
Lua rocks!
Is that full-wave or half-wave rectification?
Shannon Member
Lua rocks!
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Left Coast, CA (USA)
Measurement changes behavior
And with or without a filter capacitor?
Lefty
Shannon Member
Lua rocks!
See reply #2:
are getting.
The input to the arduino is 0 to 5volts ac  I dont understand why you think its dc. I have attached a print screen of the input to the arduino
Lefty
It is full wave rectification without a filter capacitor.
Manchester (England England)
Solder is electric glue
Without any load resistor the sample and hold capacitor on the arduino input will act as a smoothing capacitor.
Put a 10K load ( resistor) between the analogue input and ground.
UK
Because your scope trace clearly shows everything above 0V.
Alternating current implies a current reversal.
Pages: [1] 2   Go Up
