Hi guys, this time I actually worked my way around the problem, but I was wondering if you could share some ideas about
how to improve the following code. I'm reading an array of chars from an eeprom, I later transform this array via atof() and do some mathematical operations and the last thing to do is write back to the memory the new floating number in the form of an array of chars (lucky me that I only have 4 significant figures i.e.: 71.53).
Just wondering if "I discovered the wheel" (Spanish expression meaning that this was done before) and that It was much easier that I thought. If so, could you point me in that direction. If not, then this is my workaround.
PS: I'm trying to reduce the basic sketch size as much as possible.
//Number 71.53 to convert to FArray{ 7, 1, ., 5, 3}
float F = 71.53;
char FArray[6];
//Temporal Variables that hold figures (i.e.: F10 = tens, F1 = ones)
int Fint, F10, F1, F01, F001;
//Temporal variable that holds Modulo
int Mod1, Mod01;
void setup(){
void loop(){
floatToArray();
delay(20000);
void floatToArray(){
Serial.println(F); //Float to convert
F = F * 100;
Fint = (int)F;
Mod1 = Fint % 1000;
F10 = (Fint - Mod1)/1000;
Serial.println(F10); // Tens
F1 = (Fint - (F10*1000));
Mod01 = F1 % 100;
F1 = (F1 - Mod01)/100;
Serial.println(F1); // Ones
Serial.println('.'); // just printing the dot
F01 = (Mod01 - (Mod01%10))/10;
Serial.println(F01); // 1st decimal figure
F001 = (Mod01 - (F01*10));
Serial.println(F001); //2nd decimal figure
FArray[0] = F10+48; //converting number to ascii
FArray[1] = F1+48; //converting number to ascii
FArray[2] = '.';
FArray[3] = F01+48; //converting number to ascii
FArray[4] = F001+48; //converting number to ascii
Serial.println(FArray);
