Topic: Burn code on arduino nano (Read 543 times) previous topic - next topic
IdanAbutbul
the usb socket on my arduino nano broke and the arduino still working,
but without the usb socket i can't write code to the arduino,
there is a way that i can burn the code using the pins on the arduino ?
and if this is help i have also arduino mega and uno.
Runaway Pancake
#2
Feb 18, 2013, 04:00 am Last Edit: Feb 18, 2013, 04:09 am by Runaway Pancake Reason: 1
If you had a USBtinyISP (or similar) then you could use that.
As you have a "Uno", you could use the "Arduino as ISP" example sketch and rig the Nano, as the target device, to the Uno.  There aren't a lot of details of that specific (Nano-to-Uno) configuration, but there are examples using Uno/Duem. and "stand-alones", so you ought to be able to extrapolate based on that.
http://arduino.cc/en/Tutorial/ArduinoISP
> > > Adding another useful link --   http://gammon.com.au/forum/?id=11637
BTW - Do NOT screw this up!  :)
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
