Author Topic: Error Uploading Sketches getsync(): not in sync  (Read 808 times)
Recently I started using my Uno R2 as I got my teacher to start using the arduino platform in my digital electronics class. All went well for a long time and i was making programs and having fun but recently after uploading this code...
long readTemp() {
  long result;
  // Read temperature sensor against 1.1V reference
  ADMUX = _BV(REFS1) | _BV(REFS0) | _BV(MUX3);
  delay(2); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Convert
  while (bit_is_set(ADCSRA,ADSC));
  result = ADCL;
  result |= ADCH<<8;
  result = (result - 125) * 1075;
  return result;
  Serial.println( readTemp(), DEC );
I get this error every time i try to upload a new sketch to the R2
"avrdude: stk500_getsync(): not in sync: resp=0x00"
The program above is working and is communication over serial properly. I have tried to burn the boot loader but i get the same result. I have also tried pressing the reset before uploading. I do notice also the Arduino does reset when it starts to upload and tries to communicate over serial as the RX and pin 13 led blink before the error appears. I have tried this on 4 separate computers all running windows 7 x64 and it had previously worked on the computers until that last program was uploaded. I have used this code before with out having this problem. Any help would be great thanks.
Also note after attempting to upload it resumes the code from above.
Melbourne, Australia
Shannon Member
Lua rocks!
What have you got connected to the Uno?
Nothing is connected to the arduino its just it and the computer.
I have the same problem on my Arduino Uno, i have tried changing the serial port, restarting the program, etc
Any Ideas?
Shannon Member
Lua rocks!
Personally I destroyed one of my Unos accidentally, I guess by touching it when I had "static" on my hand. That maybe is what happened. Try the "loopback test" (see sticky). You could also try my "chip detector" sketch here:
http://www.gammon.com.au/forum/?id=11633
You need a second Uno to run that, but it could confirm whether or not your main processor chip is OK.
Hi Nick, I have an arduino Uno that has suddenly developed problems (see the post Toasted??) so I tried your sketch from a second Uno I have. When I run it and open the serial monitor all I get is some random garbage characters. am I supposed to do anything other than run the sketch to see the output configuration?
Shannon Member
Lua rocks!
Make sure your serial monitor is set to 115200 baud (you might have it at 9600). Then you should see some words or other.
Ah, that's better. Hmm, doesn't look like my bootloader is present. I wonder how that got erased. I take it I need to buy a programmer and re-burn the bootloader??
Atmega chip detector.
Entered programming mode OK.
Signature = 1E 95 0F
Processor = ATmega328P
Flash memory size = 32768
LFuse = FF
HFuse = D6
EFuse = FD
Lock byte = C0
Clock calibration = 98
Bootloader in use: Yes
EEPROM preserved through erase: Yes
Watchdog timer always on: No
Bootloader is 512 bytes starting at 7E00
Bootloader:
7E00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7E10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7E20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7E30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7E40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7E50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7E60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7E70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7E80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7E90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7EA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7EB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7EC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7ED0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7EE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7EF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7F90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7FA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7FB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7FC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7FD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7FE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
7FF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
MD5 sum of bootloader = DE 03 FE 65 A6 76 5C AA 8C 91 34 3A CC 62 CF FC
First 256 bytes of program memory:
Shannon Member
Lua rocks!
Since you have that sketch running, you should be able to put the bootloader back:
http://www.gammon.com.au/forum/?id=11635
Well I feel really stupid I found a resistor that had lodged under my board in my case that was shorting out the tx and rx pins with one of its leads. So now everything is fine no damage.
Success!!!  Thanks Nick, my Arduino is back to life and I learned a few things too.
