Loading...
Pages: [1]   Go Down
Author Topic: nRF24l01 + arduino help  (Read 216 times)
Offline Offline
Newbie
View Profile
hi im trying to make two arduinos communicate via nrf24l01 module but im not able to receive any output
here  is the config and code
config1:
arduino micro + nRF24l01
Code:
#include<Servo.h>
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
Servo throttle;
Servo rudder;
Servo aileron;
Servo elevator;
boolean b = 0;
byte thisChar[8];
int i;
int data[8];
void arm()
   throttle.write(0);
   rudder.write(180);
   rudder.write(90);
void disarm()
  throttle.write(0);
   rudder.write(0);
   rudder.write(90);
void throttle1(byte a)
  a=map(a, 0, 255, 0, 180);
  throttle.write(a);
void rudder1(byte b)
  b=map(b, 0, 255, 0, 180);
  rudder.write(b);
void aileron1(byte c)
  c=map(c, 0, 255, 0, 180);
  aileron.write(c);
void elevator1(byte d)
  d=map(d, 0, 255, 0, 180);
  elevator.write(d);
void throlock()
void altlock()
  throttle.attach(5);
  rudder.attach(6);
  aileron.attach(9);
  elevator.attach(10);
  Mirf.spi = &MirfHardwareSpi;
  Mirf.init();
  Mirf.setRADDR((byte *)"serv1");
  Mirf.payload = 8;
  char data[Mirf.payload];
  Mirf.config();
    if(!Mirf.isSending() && Mirf.dataReady()){
    Mirf.getData((byte *) data);
   throttle1(data[1]);
   rudder1(data[2]);
   aileron1(data[3]);
   elevator1(data[4]);
   if (data[5]==0xFF)
     arm();
   if (data[6]==0xFF)
     disarm();
config 2:
Arduino mega 1280 +nRF24l01
Code:
#include <Mirf.h>
#include <SPI.h>
byte thisChar[8];
int data[8];
int i, a, f;
void setup(){
  Mirf.init();
  Mirf.setTADDR((byte *)"serv1");
  Mirf.payload = 8;
  Mirf.config();
void loop(){
   if (Serial.available() > 0) {
  int d,a;
  a=1;
  d=Serial.read();
  switch(d)
  case'a':
   Serial.println("arming.....");
   data[0]=0x00;
  data[1]=0x00;
  data[2]=0x00;
  data[3]=0x00;
  data[4]=0x00;
  data[5]=0xFF;
  data[6]=0x00;
  data[7]=0x00;
   Serial.println("ARMED......");
 case 'b':
    Serial.println("Disarming....");
      data[0]=0x00;
  data[1]=0x00;
  data[2]=0x00;
  data[3]=0x00;
  data[4]=0x00;
  data[5]=0x00;
  data[6]=0xFF;
  data[7]=0x00;
     Serial.println("disarmed.......");
  case 'c':
    data[0]=0x00;
  data[1]=0x64;
  data[2]=0x00;
  data[3]=0x00;
  data[4]=0x00;
  data[5]=0x00;
  data[6]=0x00;
  data[7]=0x00;
     Serial.println("MED");
  case 'e':
    data[0]=0x00;
  data[1]=0xFF;
  data[2]=0x00;
  data[3]=0x00;
  data[4]=0x00;
  data[5]=0x00;
  data[6]=0x00;
  data[7]=0x00;
     Serial.println("MAX");
    Mirf.send((byte *) &data);
    while(Mirf.isSending()){
the arduino micro is connected to a kkmulticopter board flashed with xCopter 4.5 firmware
im a total noob just getting to know arduino
thanks.
« Last Edit: February 14, 2013, 01:52:48 am by CyrilAnthony » Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Read this before posting a programming question
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Quote
Code:
    data[Mirf.payload];
What is that line supposed to do?
Logged
Offline Offline
Newbie
View Profile
sorry i didnt edit it before posting .
Logged
Pages: [1]   Go Up
Print
Jump to:
