Loading...
Pages: [1] 2   Go Down
Author Topic: Current measurement on positive or negative side?  (Read 570 times)
Denmark
Offline Offline
Newbie
View Profile
I´m going to use this sensor: ACS758ECB-200U-PFF-T (http://www.allegromicro.com/~/Media/Files/Datasheets/ACS758-Datasheet.ashx), and I was wondering if it makes any difference if I place the sensor on the positive or negative side of my motor (130 amp dc). If I could place on the negative side, it would allow for much shorter sensor wires. Thanks smiley
Planned setup is: Battery positive --- motor --- current sensor --- contactor --- mosfets --- battery ground
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
I think the sensor is designed for AC power supplies only and your trying to use it with a DC motor.
Logged
uk
Offline Offline
Sr. Member
View Profile
no it measures ac or dc, im sure it would work both ways, test it both ways
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
Thanks for point that out. Once I read the text instead of just looking at the pictures I see it.  smiley-red
Logged
Lost Wages
Offline Offline
Full Member
View Profile
I don't think that the position of the current sensor matters as long as it is in series with the motor. I might place it between ground and the rest of the motor circuit.
Logged
Offline Offline
Newbie
View Profile
Look up Kirchhoff's current law, Current will be the same whatever side you put the sensor, assuming it doesn't branch off at some point. Make sure you put it in series!
Logged
Denmark
Offline Offline
Newbie
View Profile
Thank You, I thought so, but it's nice to be sure. I'll probably need to read up on my electrical basics smiley
Logged
uk
Offline Offline
Sr. Member
View Profile
bloody hell 130a dc be careful with that, i used to work on lifts with very big dc generators scary stuff.
« Last Edit: February 14, 2013, 12:19:22 pm by jonisonvespaa » Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
I realize it is counter intuitive But I'd place the sensor in the high side of the motor... because of the possibility of a failure in the power connections to the sensor or the sensor proper. If low side sensing fails then you  have full supply voltage on the ground leads.. If high side sensing fails you have no power to the motor, much easier to troubleshoot and much safer to work around. This is one of the reasons why switching grounds is not wise unless it is an absolute last resort -- do-able but inadvisable. Supplies may be switched but it is Always a last resort to switch or sense ground in any high voltage control circuit.
The Allegro ACS series current sensors have a 2KV isolation barrier between sense and sensed conductors so there should be no issues of that nature in using the sensor in the high side of the motor power circuit.
Bob
« Last Edit: February 14, 2013, 03:19:35 pm by Docedison » Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Denmark
Offline Offline
Newbie
View Profile
There is little risk of personal injury, as the system is only 24 volts. But I see your points about troubleshooting and also it makes sense to not have permanent power on ground leads. I will have to find the best compromise between physical layout, possible interference and safety. Thank you.
Logged
Portugal
Offline Offline
God Member
Tomorrow I will know a BIT more than yesterday
View Profile
Quote
Quote
Does I understand this well? You have a motor that "eat" 130 amps @ 24V smiley-eek-blue smiley-eek-blue
Logged
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
If I were to wager a guess I'd say "hydraulic power pack" like jonisonvespaa described. Common on snow plow trucks or dump trailers.
Logged
uk
Offline Offline
Sr. Member
View Profile
130 amps 24v
what sort of motor is that? im guessing some sort of automotive starter or alternator maby?
Logged
texas
Offline Offline
God Member
old, but not dead
View Profile
Since the sensor is not actually carrying any current, it's not going to have any affect on safety either way in my opinion.  It's a hall sensor, meaning it magnetically measures the current in the wire, so circuit isolation is very high.
Is this for some kind of RC car?
Logged
Experience, it's what you get when you were expecting something else.
uk
Offline Offline
Sr. Member
View Profile
current does flow through the sensor, on pins 4 and 5 -  ip+ and ip-
Logged
Pages: [1] 2   Go Up
Print
Jump to:
