Topic: High Accuracy Distance Sensor for short ranges (Read 5357 times) previous topic - next topic
HansBaer
Hi there!
I'm currently building a lift for scientific purposes. It's driven by a stepper-motor with a high transmission.
As it is my first project with a stepper motor, i realized afterwards that it isn't all too accurate, i think it is loosing steps under high load.
So basically i have to measure the  distance between two panels, one of them is going up and down.
The distances the sensor would have to measure are between 5 and 30 cm and i aim for an accuracy around +- 0.2mm, the smaller the better.
I came across this one from sharp though i am not sure if it is the right one, because i didn't find any data on its accuracy.
http://www.sharpsma.com/webfm_send/1205
Does anyone have experiences with similar requirements?
Would be grateful for your suggestions.
Cheers
Riva
Quote
I don't have experience if close tolerance distance measurements using arduino but the sensor you linked to won't do 0.2mm accuracy for sure. What you probably need is an encoder on the stepper motor/drive chain to give movement/position feedback.
Don't PM me for help as I will ignore it.
robtillaart
measuring 0.2 mm deltas
speed of sound 340M/s    (but differs per temperature => drift is bigger than needed accuracy warnings apply)
0.2 * 10-3 / 340 => 0.588235 *10-6 sec. ~0.6 uSec
So to need this accuracy you need to switch in 0.6 uSec . This is about 9 clock cycli of the Arduino.
So you are operating at the edge what is feasable for an Arduino..
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
HansBaer
hm, i see. for a few reasons i can't use an encoder on my stepper motor.
0.3 mm would be ok, too. So you say i should use a sonic sensor? any recommendations?
If my demands can't be met, i'll have to settle with the best thats possible. Ultrasonic vs. Infrared?
robtillaart
think it comes down to comparing datasheets of diff sensors
Rob Tillaart
robtillaart
budget ?
- http://www.sick.com/group/en/home/products/product_portfolio/distance_sensors/pages/distance_sensors_short_range.aspx -
Rob Tillaart
robtillaart
- http://www.pololu.com/file/0J284/GP2Y0D805Z0F.pdf - 0.5..5cm,
Rob Tillaart
HansBaer
budget is 40€ max.
I couldn't find anything about the resolution of this sensor in its data sheep. have i overlooked something?
neither in this one
http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/28015-PING-Sensor-Product-Guide-v2.0.pdf
robtillaart
can you explain why you need to measure distance?
what are you trying to reach?
Rob Tillaart
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
