Topic: Timer gains 14 seconds every hour (Read 582 times) previous topic - next topic
Im-just-Rusty
I'm working on a project and used a bit of code which I found on line to intergrate as a timer in my program.  Once I got it working, I found that it gains aprox. 14 seconds every hour.  I put in a couple lines to correct for this but I'm still curious as to why it's occuring in the first place.  I would think a pulse width modulated signal would be more accurate.  Anyway, as I'm new at this, I may be doing some little something wrong.  If anyone sees the reason for the gained 14 seconds in my code, could you please let me know?   Thanks.
Code: [Select]
const int  buttonPin = 3;    // the pin that the button is attached to
const int ledPin = 8;        // to light an LED during development
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
int incomingByte;            // to read input into
int TM[3]={0,0,0};
String readString;
int clockInt = 0; // digital pin 2 is now interrupt 0
int masterClock = 0; // counts rising edge clock signals
int seconds = 0; // variable
int minutes = 0; // variable
int hours = 0; // variable
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  attachInterrupt(clockInt, clockCounter, RISING);
      // clockInt is our interrupt, clockCounter function is called
      // when invoked on a rising clock edge
  analogReference(DEFAULT);
  analogWrite(10, 127); // this starts our PWM clock with a 50% duty cycle
  if (Serial.available() > 0) { //if any key is pressed
   int incomingByte = Serial.read(); //read input into incomingByte
   switch(incomingByte){ //depending on the value of incomingByte...
    case 'z':
        // z is just here so I can check the time without having to set it
      Serial.print ("P  Station time is    ");
      Serial.print(hours);
      Serial.print(":");
      Serial.print(minutes);
      Serial.print(":");
      Serial.println(seconds);
      Serial.println ("");
    case 'J':
      Serial.print ("Set Station time       ");
      if (hours < 10){
        Serial.print("0");
      Serial.print(":");
      if (minutes < 10){
        Serial.print("0");
      Serial.print(":");
      if (seconds < 10){
        Serial.print("0");
      Serial.print(seconds);
      Serial.print (" ");
      hours = TimeProcess(); //hours, minutes, and seconds are populated
      Serial.print(":"); //colons pops up between each set of 2 numbers
      minutes = TimeProcess();
      Serial.print(":");
      seconds = TimeProcess();
      Serial.println ("");  // cariage return
      Serial.print ("  Station time         ");
      if (hours < 10){ //puts a "0" in the first digit location if needed
        Serial.print("0");
      Serial.print(":");
      if (minutes < 10){ //same as was done for hours
        Serial.print("0");
      Serial.print(":");
      if (seconds < 10){ //same as was done for hours
        Serial.print("0");
      Serial.println (" ");
      default:
      Serial.println ("Invalid entry. Enter J to set the Time.");
void clockCounter() // called by interrupt
  masterClock ++;  //with each clock rise add 1 to masterclock count
  if(masterClock == 489) // 490hz reached
    seconds ++;  //after one 490Hz cycle add 1 second
    masterClock = 0; //Reset after 1 second is reached
    //tone(13, 100, 500); //using tone to pulse LED without delay call
    if (seconds == 60) // Now getting into real time keeping
      minutes ++;  //increments minutes by 1
      seconds = 0;   //reset the seconds variable
      if (minutes == 30 || seconds == 30) //at each half hour and 30 seconds do this
      { //I could have put this anywhere within the hour. I just choose 30 min 30 sec
        seconds = (seconds - 14); //corrects the clock
      if (minutes == 60)//when minutes reach 60
        hours ++;//incriments hours by 1
        minutes = 0;//resets the minutes variable
        if (hours == 24)//when hours reach 24
          //days ++;
          hours = 0;//rest the minutes variable
  return;
long TimeProcess() //populates int hours, minutes, or seconds for easy printing
      long var;
      int cnt = 0;
      for (int complete = 0; complete != 1;)//"complete" is initialized at 0 then the condition of the
                                            // for loop is that "complete" is not 1
      { //loop will continue until "complete" becomes 1
       while (Serial.available() > 0 )
       {  //Serial.available recognizes digits pending in serial buffer
          char c = Serial.read(); //reads data in serial buffer one byte at a time.
          TM[cnt] = int(c - 48); //contents of c are copied to array TM
          cnt++; //cnt is incrimented with each entery into the array
          readString += c; //contents of char c are placed in readString
          Serial.print (c); //prints each charicter as it's typed
          delay(2);
          if (cnt == 2) // when 2 digits are entered do this
            Serial.print ("");
            complete = 1; //make "complete" 1 which satisfies the for loop
     if (readString.length()>0) //when readString gets content, do something
         char carray[readString.length() + 1]; //creates an array of readString content
         readString.toCharArray(carray, sizeof(carray)); // transfers readString into char array named carray.
         long f = atol(carray); //creates long variable "f" equal to "array to long" conversion of data in carray.
         var = f; //var is equal to "f" which we just converted to a number from array of chars.
         readString=""; // make readString empty for next time around
         readString[2]; //allocate 8 bytes of memory for readString
     return var;
holmes4
The counters for the timers are not incremented during interrupts.
Mark
HazardsMind
I wonder if this delay have something to do with your 14 second problem? Maybe, maybe not.
         delay(2);
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
PaulS
Code: [Select]
Mangling a for loop to make a while statement just feels wrong.
Coding Badly
No.  It's the same clock; the processor's clock.  What you are doing will never be more accurate than millis / micros.
Coding Badly
[font=Courier New]void clockCounter() // called by interrupt
[/font]
Two things... 1. The "489" is wrong.  2. The "490" is also wrong.
The frequency is slightly higher than 490 which puts the target value between 490 and 491.  Unless you account for the fractional part your clock will not be accurate; it will be off by at least 1/490*3600 = 7 seconds per hour.
HazardsMind
Hmmm.
Quote
and with that delay I pointed out, 3600 second in 1 hour, 3600 * delay(2) = 7.2 seconds total delay, per hour
So  1/490*3600 = 7 seconds per hour +   7.2 seconds total delay  = 14.2 seconds per hour.
My GitHub:
Im-just-Rusty
I'll try taking out the delay and also try to figure out an answer to the frequency issue and see if that helps.  Thanks.  I'll try to post any results I come up with (although I am pretty slow at all this programing stuff  lol).    :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
