Topic: Motor Shield Programming Error (Read 1 time) previous topic - next topic
rduiohd
Feb 14, 2013, 09:46 pm Last Edit: Feb 14, 2013, 09:48 pm by rduiohd Reason: 1
Hello;
   I have some problems about adafruit motor shield programming.I'm sure that I installed library correctly however when I tried to upload a sketch in ladyada's site it shows an error;" 'CS20' was not declared on this scope.".Here is the code;
Code: [Select]
#include <AFMotor.h>
AF_DCMotor motor(2, MOTOR12_64KHZ);
 Serial.begin(9600);           // set up Serial library at 9600 bps
 Serial.println("Motor test!");
 motor.setSpeed(200);     // set the speed to 200/255
 Serial.print("tick");
 motor.run(FORWARD);      // turn it on going forward
 Serial.print("tock");
 motor.run(BACKWARD);     // the other way
 Serial.print("tack");
 motor.run(RELEASE);      // stopped
Note: I'm using Arduino Leonardo and a clone motor shield.
Thanks For any help
johnwasser
I suspect the Adafruit library is manipulating the timer hardware to get 64kHz PWM and has not been updated to work with the timer hardware of the Leonardo.  Look for an updated library or bypass the library and talk to the hardware directly.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
rduiohd
   Yes,I did try it on uno and it worked.Thanks for your reply
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
