Loading...
Pages: [1] 2   Go Down
Author Topic: 433mhz Receiver  (Read 611 times)
Offline Offline
Newbie
View Profile
Due to conflicting information, there is a good chance i connected one of these up wrong, switching Gnd and 5v. Now i can't seem to get it to work.
Does that mean its fried? And is there a way to test this?
Thanks.
FTL
Logged
Offline Offline
Edison Member
View Profile
The only way is to buy an other one to compare them.
Was it powered via the Arduino with the USB bus or did you use an adapter with more current ?
Logged
Offline Offline
Newbie
View Profile
Via the arduino.
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
Did you ever have it working? Assuming you have a matching transmitter then try the below sketch to see what you get.
Code:
    pinMode(3,INPUT);        // ISR 1 Pin
    pinMode(7,OUTPUT);       // TX Pin
    pinMode(13,OUTPUT);      // Onboard LED
    attachInterrupt(1,rxISR,CHANGE);
void rxISR(){
    digitalWrite(13,digitalRead(3));    // Echo pin state to LED
    digitalWrite(7,HIGH);
    delay(100);
    digitalWrite(7,LOW);
    delay(100);
EDIT: Adding explanation...
Connect arduino pin 7 to the TX module DATA pin.
Connect arduino pin 3 to the RX module DATA pin.
Connect arduino 5V & GND to VCC & GND respectfully on both modules.
Upload sketch and run it and the arduinos on-board LED (pin 13) should flash on/off as the transmitter is turns on/off.
« Last Edit: February 15, 2013, 08:00:08 am by Riva » Logged
Offline Offline
Newbie
View Profile
Right, got the receiver working. Thanks for the help folks.
Now to figure out the transmitter. I can't believe it cam with no documentation. All these devices are different.
How can i tell what pins are what. Will photo be useful?
FTL
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
Look on both sides of the board near the pins and hopefully it will have something. If not then send pictures of both sides of the transmitter. The example image I posted has 3x TX module pins that are DATA, VCC & GND as you look in the photo but yours may be different so best to be sure first.
Logged
Offline Offline
Newbie
View Profile
Hope these are clare enough.
FTL
Logged
Offline Offline
Edison Member
View Profile
I can't find it.
The pins are most of the times : Ground, Data, Vcc, Antenna.
If you look at the board with a magnifier, perhaps you can see which pin is ground and which is the antenna.
Logged
Offline Offline
Newbie
View Profile
Its difficult to tell what is what. Even with a magnifyng glass... the back is really cluttered.
FTL
Logged
Offline Offline
Edison Member
View Profile
Do you have a flat bed scanner, perhaps that can make a good scan/photo.
Logged
Offline Offline
Full Member
W9LZ
View Profile
Put your camera on manual focus, and back away from the paper it's on. The background paper in the foil side shot is in focus, but with the limited depth of field, the foil side is out of focus. Manually focus that camera if you can, else take multiple shots of both sides, and pick those two that are sharp. Keep it smaller in size, we can blow up a clear shot on this end.
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
Looks like they forgot to silkscreen  the board  smiley-sad
The image of the back (with components on) could be a bit clearer.
Looking at the front (the side with the big metal can) the second pin (from the left) is most likely GND but without a clear picture of the back cannot figure the other pins out.
Wait for other peoples opinions and hopefully grab a better image of the back but my guess is ANT, GND, DATA & VCC or ANT, GND, VCC & DATA
Logged
Offline Offline
Newbie
View Profile
This is better.
FTL
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
It Looks like this one
http://detail.china.alibaba.com/offer/1126300215.html
But as you say there are so many different.
Logged
Offline Offline
Newbie
View Profile
Close bit no cigar...
FTL
Logged
Pages: [1] 2   Go Up
Print
Jump to:
