Topic: Writing to a file on an SD card (Read 671 times) previous topic - next topic
n_pestell
I have successfully written a program which can open a file on an SD card and write "hello world" to the file. However I am encountering a problem when transferring this code to a more complicated program. The program counts the number of times something passes through a two light-gate system this integer variable is given the name lemnum. Lemnum is what I am trying to write to the file on the SD card, however the file doesn't open. Every time that the file should open, i.e. when 1 is added to lemnum, instead the error message is printed to the serial port. Below is the relevant section of the code.
else if ((array[0] == 0) && (array[1] == 0))//lemur has entered the box
        lemnum = lemnum++;//add one to the lemnum
        state = 1;//return to state 1
        Serial.println(lemnum);//print the number of lemurs to the serial port
        //open the file
        dataFile = SD.open("lemur.txt", FILE_WRITE);
        //if the file is available write to it
        if (dataFile)
            //write lemnum to the file
            dataFile.println(lemnum);
            //close file
            dataFile.close();
        //if the file doesn't open, pop up an error
            Serial.println("error opening lemur.txt");
        break;
Any help, is greatly appreciated! :)
HazardsMind
#1
Feb 15, 2013, 03:43 pm Last Edit: Feb 15, 2013, 04:17 pm by HazardsMind Reason: 1
Edit: removed
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
n_pestell
Do you mean that I should get rid of the if statement to give:
        //open the file
        //close file
        dataFile.close();
This still doesn't open the file. And when I do a Serial print of dataFile it gives 0.
HazardsMind
I take back my previous post, and ask to see your full code.
Also try the example again, and break it down.
http://arduino.cc/en/Tutorial/ReadWrite
My GitHub:
PaulS
n++ is equivalent to n = n + 1. So, your statement is equivalent to
lemnum = lemnum = lemnum + 1;
Looks a little silly that way, doesn't it.
Of course, the comment stating the obvious does, too.
Clearly that isn't the source of the problem, since incrementing lemnum and setting state should have no impact on the ability to open the file.
