Loading...
Pages: [1] 2 3   Go Down
Author Topic: Russia gets hit by meteor and watch a flyby live  (Read 1494 times)
Earth
Offline Offline
Full Member
Webmaster
View Profile
WWW
http://www.space.com/19781-asteroid-2012-da14-flyby-webcasts.html
Logged
Webmaster living off grid in a camper with 300watts of solar panels charging 9 absorbed glass mat 12V batteries. i own about 40 dot coms. i can read, write and debug HTML, CSS, JSON and PHP. I can understand some javascript. A++ is new to me. i thought it was a dead language. lol! A rogue planet called Nibiru is close by and will cause disasters all over earth including fireballs, earthquakes, meteors and volcanic eruptions. But i will be ready with  Project Camper
0
Offline Offline
Tesla Member
View Profile
what i can't understand is if someone like nasa or similar had seen this metereo approcing, or we are completely unaware of some dangerus-but-not-too-big meter
Logged
my Arduino code: https://github.com/lestofante/arduinoSketch
sei nuovo? non sai da dove partire? leggi qui: http://playground.arduino.cc/Italiano/Newbie
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
The latter is true. Spotting such 'small' objects at distance is often more a matter of luck then anything else.
Lefty
Logged
Grand Blanc, MI, USA
Offline Offline
Edison Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
I read the blast was estimated at 500 kt, at an altitude of 10-15 miles. That's huge! I'm surprised it didn't do more damage. Good thing it wasn't closer in.
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Offline Offline
Brattain Member
View Profile
The angle of entry had a lot to do with it as it passed through the atmosphere for much longer then if it was falling at a more vertical angle where it might well have reached ground before breaking up.
Lefty
Logged
Earth
Offline Offline
Full Member
Webmaster
View Profile
WWW
more are coming
Logged
Offline Offline
Brattain Member
View Profile
more are coming
Always have been coming and always will be coming, it's just that human's clock rate is just not tuned to the universe's clock rate.
Lefty
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
How wide is the sky and beyond, out past the Moon orbit? How small is a 1km rock at 500,000km? Now how small is a less than 20m rock?
At relative speeds of asteroid and Earth you need to find the asteroid(s) and determine if/where any might hit the sky in enough time to give meaningful warning, more than just "Everybody duck!" which really means get your cameras out.
A 17m rock didn't get noticed until 32 seconds(?) before it exploded. Then it got noticed. That was the warning but who knew what to do? Maybe people knowing more what they see and take action to get under cover is sooner possible? That rock could have killed most everyone in the open for many km around just from the blast had it come much lower.
I think of these rocks and the ones going by as missed resources. I won't say they'd be used wisely (more likely be used to take war to a new level) but there they are.
Logged
Examples can be found at Learning in the Main Site and at the Playground
Earth
Offline Offline
Full Member
Webmaster
View Profile
WWW
wrong. the russian meteor was noticed and shot at by aliens protecting us. goto youtube and look it up
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
I'll file that with "chem-trails"TM and how real contrails don't last... not since WWII anyway.
Logged
0
Offline Offline
Tesla Member
View Profile
i can understand Radar in space will not work, but maybe you can do something similar with light (see lidar)...
An easyer way should be something like automatic photo + redshift, or triangulation, analysis..
I've seen a "automatic pilot" for spaceship that autocorrect inertial measurement "simply" taking photo of the know star and calculating the error... like sailor smiley
that can be used to track and identify any object into certain range
Logged
Offline Offline
Brattain Member
View Profile
Quote
Radar works just fine from earth to space. However the size of the return signature is related to both the distance and size of the object, so it's a sensitivity issue. The most sensitive method of detected far off and small space objects is photographs taken over multiple days looking at an identical part of space. Any object that has 'moved' relative to the background starts will appear as a streak and is easily to identify, track, and predict it's path thereafter. However there is a lot of space to look at and a finite number of picture takers so smaller objects are always subject to arriving without notice.
Lefty
Logged
0
Offline Offline
Tesla Member
View Profile
Quote
sorry, you are right, i get confused with Sonar smiley
Lefty
ok, so it is similar to my precedent idea. It is just harder than i through smiley-grin
Logged
Earth
Offline Offline
Full Member
Webmaster
View Profile
WWW
yous are all wrong. nasa can track a wrench floating around. they kept this whole thing secret so to not create havoc in the streets!
Plus the sound of the meteor blast over Russia was detected from as far away as Antarctica by the far-flung system of detectors that make up the Comprehensive Nuclear-Test-Ban Treaty network. http://oak.ctx.ly/r/2h1l sorry bout the giant pic
« Last Edit: February 20, 2013, 12:06:08 pm by TrailerTrash » Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Radar is inverse square including the return, inverse-square of -less-. That limits the degrees a radar may scan very far, the size of the sky may be thought in terms of scan circles. The sky is much bigger than it looks, and it looks awful big.
TT:
They track 1,000's of junk objects in orbit. It's easier to do when you have satellites in place and you're only scanning local space. It's easier when you have decades to build the map.
Quote
The Vienna, Austria-based Comprehensive Nuclear-Test-Ban Treaty Organization (CTBTO) runs the International Monitoring System made up of infrasound stations. Infrasound is low frequency sound with a range of less than 10 Hertz. Humans cannot hear the low frequency waves that were emitted by the meteor blast over Russia on Friday (Feb. 15), but they were recorded by the CTBTO’s network of sensors as they travelled across continents.
Gee, they caught it late. Not until the blast. Meanwhile phone and dash cams were already on the big glowing thundering thing blazing across the sky, and it ain't the Second Coming!
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
