Topic: LiquidCrystal - Trying lcd[i].print(); without success... (Read 795 times) previous topic - next topic
reblochon
Feb 14, 2013, 04:05 pm Last Edit: Feb 14, 2013, 04:06 pm by reblochon Reason: 1
Controlling several lcd screen like on this topic works good for me: http://arduino.cc/forum/index.php/topic,5014.0.html. It's fantatic!!!!
But now, I'd like to be abble to select which lcd (lcd0, lcd1, lcd2...etc), with only one variable like i, where i is from 0 to 4.
I tried the following code
Code: [Select]
#include <LiquidCrystal.h>
LiquidCrystal lcd0(22, 23, 24, 26, 28, 30);
LiquidCrystal lcd1(22, 25, 24, 26, 28, 30);
LiquidCrystal lcd2(22, 27, 24, 26, 28, 30);
LiquidCrystal lcd3(22, 29, 24, 26, 28, 30);
LiquidCrystal lcd4(22, 31, 24, 26, 28, 30);
char *LCD[5] = {"lcd0", "lcd1", "lcd2", "lcd3", "lcd4"};
for (int i=0; i<=4;i++)
      LCD[i].begin(16,2);
      LCD[i].clear();
      LCD[i].setCursor(0,0);
for (i=0; i<=4;i++)
       LCD[i].print("blablabla : ");
       LCD[i].print(i);
But the compiler reject it with " request for member 'begin' in 'LCD', which is of non-class type 'char*'".
Is there a way to make it ? Any clue to guide me for that? The need for this is to be abble to select the lcd number with a number in a variable.
Thanks you very much,
Lionel
PaulS
Code: [Select]
That's an array of variable names. In the hex file that the compiler and linker combine to produce, there are no variable names.
You can create an array of LiquidCrystal instances:
Code: [Select]
LiquidCrystal lcds[] =
   LiquidCrystal(22, 23, 24, 26, 28, 30),
   LiquidCrystal(22, 25, 24, 26, 28, 30),
   LiquidCrystal(22, 27, 24, 26, 28, 30),
   LiquidCrystal(22, 29, 24, 26, 28, 30),
   LiquidCrystal(22, 31, 24, 26, 28, 30)
reblochon
:smiley-sweat: Thank you Paul!!!! It's beautifull!!!
Here is an example of working code.
Again thank you!!!
Code: [Select]
  lcds[i].begin(16,2);
  lcds[i].setCursor(0,0);
  lcds[i].clear();
  lcds[i].print("Yess");
  lcds[i].print(i);
void loop(){}
