Author Topic: Unable to compile  (Read 131 times)
Maybe a stupid error but i'm not able to compile this code, it always tell me that the KeyCode was not declare in the scope.
Here the code:
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
// Re-Modified for Arduino and 125Khz JsxzLz RFID Kit from Ebay by Biohazard
// RFID reader comes with 11 pins: D3 D2 D1 Rest Mcst Gnd L1 L2 PC TX VCC
// We need these to be connected:
// Rest to Arduino pin 2
// Gnd to Arduino GND
// L1 and L2 to the antenna
// TX to Arduino RX0
// VCC To Arduino 5V
int  val = 0;
char code[14];
String keyCode;
String  master = "4B00108513470F";
// 10 digits card code
// 2 digits parity bits
int bytesread = 0;
  Serial.begin(9600);     // RFID reader TX pin, Baud rate: 9600, Data bits: 8, stop bit: 1.
  pinMode(2,OUTPUT);      // Set digital pin 2 as OUTPUT to connect it to the RFID RESET pin
  digitalWrite(2, HIGH);  // Activate the RFID reader
  Serial.println("rfid ready to read");
  if(Serial.available() > 0) {            // if data available from reader
    if((val = Serial.read()) == 10) {     // check for header
      bytesread = 0;
      while(bytesread < 14) {             // read 14 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) {  // if header or stop bytes before the 10 digit reading
            break;                        // stop reading
          code[bytesread] = val;          // add the digit
          bytesread++;                    // ready to read next digit
      if(bytesread == 14) {         // if 14 digit read is complete
        keyCode = code;
        keyCode = keyCode.substring(0,14);
        if (KeyCode == master)
          Serial.println("Master key passed");
      bytesread = 0;
      digitalWrite(2, LOW);               // deactivate the RFID reader for a moment so it will not flood
      delay(1500);                        // wait for a bit
I declare the KeyCode at the statup so why this error
Thanks
Manchester (England England)
Solder is electric glue
keyCode = code;
keyCode is not the same as KeyCode
Case matters.
I'm probably slow today, sorry, i don't understand what you means?
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
KeyCode  and keyCode they are NOT the same. This type of programing is case sensitive.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
In this line:-
it is the first time the compiler has seen the variable KeyCode.
Previously it has only been told about the variable keyCode  which is a different variable.
The first starts with a capital letter and the second a lower case letter. This means they are different variables.
Sorry for the stupid error thanks very much. For sure now it work
