Topic: getting a - expected unqualified id before"{" token.. (Read 2920 times) previous topic - next topic
mrfunk
any ideas
EthernetClient client;
EthernetServer server(80);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  //lcd.print("W-");
HazardsMind
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
Grumpy_Mike
Where?
It normally means you have missed out a semicolon on the line before.
mrfunk
#3
Feb 15, 2013, 09:01 pm Last Edit: Feb 15, 2013, 09:02 pm by Hackdub Reason: 1
line 73... cheers
// General code from http://www.pushingbox.com for Arduino + Ethernet Shield (official) v1.2
#include <SPI.h>
#include <Ethernet.h>
#include <LiquidCrystal.h>
#include "DHT.h"
#define DHTPIN A1     // what pin we're connected to
#define DHTTYPE DHT11   // DHT 11
DHT dht(DHTPIN, DHTTYPE);
// MODIFY HERE //
byte mac[] = {
 0x00, 0x13, 0x02, 0xCC, 0xD1, 0x19 };   // Be sure this address is unique in your network
byte ip[] = { 192,168,0, 101 };
//Your secret DevID from PushingBox.com. You can use multiple DevID  on multiple Pin if you want
char DEVID1[] = "v1CC65E36Dxxxx00";        //Scenario : 1
char DEVID2[] = "v9565F5FAAxxxx41";        //Scenario : 2
//Numeric Pin where you connect your switch
#define pinDevid1 8// mm
#define pinDevid2 9// mm
///               4    6  11  12 13  14
//                rs, en, D4, D5 D6  D7
LiquidCrystal lcd(A4, A5 , 3, 2, A3, A2);
int sensorPin = A0; // select the input pin for the  detector
//int countMAILW=0;
int count = 0;
int FED = 0;
int countMAILF = 0;
int sensorValue = 0;  // variable to store the value coming from the  detector
byte latch = 0;  //initial variable
const int pump = 4;
const int fan = 5;
// Debug mode
#define DEBUG true
//   End    //
char serverName[] = "api.pushingbox.com";
boolean pinDevid1State = false;
boolean pinDevid2State = false;
boolean lastConnected = false;                 // state of the connection last time through the main loop
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
server.begin();
 lcd.begin(16, 2);
 //lcd.print("W-");
 pinMode(pinDevid1, OUTPUT);// pin 8
 //pinMode(pinDevid2, INPUT);// pin 9
 pinMode(fan, OUTPUT);//
 pinMode(pump, OUTPUT);//
// pinMode(relay, OUTPUT);
 dht.begin();
 // start the Ethernet connection:
 if (Ethernet.begin(mac) == 0) {
   Serial.println("Failed to configure Ethernet using DHCP");
   lcd.setCursor(0,0);
   lcd.print("Disconnected ");
   //while(true);// no point in carrying on, so do nothing forevermore:
 else{
   Serial.println("Ethernet ready");
   lcd.setCursor(0,0);
   lcd.print("Net OK ");
   delay(2000);
   lcd.clear();
   Serial.print("My IP address: ");// print the Ethernet board/shield's IP address:
   Serial.println(Ethernet.localIP());
   lcd.print(Ethernet.localIP());
   delay(2000);
   lcd.clear();
   FED=0;
   lcd.setCursor(10,0);
   lcd.print("F");
   lcd.print(FED);
 delay(500);// give the Ethernet shield a second to initialize:
Client client = server.available();
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println();
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 1; analogChannel++) {
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(analogRead(analogChannel));
client.println("<br />");
break;
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
 float h = dht.readHumidity();
 float t = dht.readTemperature();
 // check if returns are valid, if they are NaN (not a number) then something went wrong!
 if (isnan(t) || isnan(h)) {
   Serial.println("Failed to read from DHT");
 else {
   Serial.print("Humidity: ");
   Serial.print(h);
   Serial.print("  %   ");
   Serial.print("Temp: ");
   Serial.print(t);
   Serial.println("C");
 // set the cursor to column 0, line 1
 // (note: line 1 is the second row, since counting begins with 0):
 lcd.setCursor(8, 1);
 lcd.print("H:");
 lcd.print(h);
 lcd.print("%");
 //delay(2000);
 lcd.setCursor(0, 1);
 lcd.print("T:");
 lcd.print(t);
 //lcd.print("C");
 //delay(2000);
   if(t>=26)
  { digitalWrite(fan, HIGH);
   lcd.setCursor(15, 0);
 lcd.print("F");}
  if(t<=24)
  { digitalWrite(fan, LOW);
 lcd.print("_");}
lcd.setCursor(0,0);
lcd.print("W-");
 lcd.setCursor(2,0);// (note: line 1 is the second row, since counting begins with 0):
 // print the number of seconds since reset:
 lcd.print(sensorValue);
 sensorValue = analogRead(sensorPin); // read the value from the soil detector:
 Serial.print("moisture sensor reads ");
 Serial.println( sensorValue );
 delay(100);
 if(sensorValue<750 && count==0)
   //countMAILF=0;
   delay(2000);
   delay(2000);
   digitalWrite(pinDevid1, HIGH);
   digitalWrite(pump, LOW);
   lcd.setCursor(14, 0);
 lcd.print("P");
 delay(10000);
 digitalWrite(pump, HIGH);
 lcd.print("R");
 //digitalWrite(pinDevid1, HIGH);
count++;// this increments the count by 1
 if(sensorValue>800)
 //if(countMAILF ==0)
{digitalWrite(pinDevid1, LOW);
 lcd.print("_");
count=0;}
 if (digitalRead(pinDevid1) == HIGH && pinDevid1State == false )// switch on pinDevid1 is ON
   if(DEBUG){
     Serial.println("pinDevid1 is HIGH");
   pinDevid1State = true;
   sendToPushingBox(DEVID1);//Sending request to PushingBox when the pin is HIGHT
 if (digitalRead(pinDevid1) == LOW && pinDevid1State == true) // switch on pinDevid1 is OFF
   if(DEBUG){
     Serial.println("pinDevid1 is LOW");
   sendToPushingBox(DEVID2);
  // digitalWrite(9, HIGH);
   //digitalWrite(pump, LOW);
  // countMAILF = val;
 //DEBUG part
 // this write the respons from PushingBox Server.
 // You should see a "200 OK"
   if(DEBUG){
     Serial.print(c);
 // if there's no net connection, but there was one last time
 // through the loop, then stop the client:
 if (!client.connected() && lastConnected) {
   if(DEBUG){
     Serial.println();
   if(DEBUG){
     Serial.println("disconnecting.");
   client.stop();
 lastConnected = client.connected();
//Function for sending the request to PushingBox
void sendToPushingBox(char devid[]){
 client.stop();
 if(DEBUG){
   Serial.println("connecting...");
   lcd.setCursor(0,0);
   lcd.print("connecting.... ");
 if (client.connect(serverName, 80)) {
   if(DEBUG){
     Serial.println("connected    ");
     lcd.setCursor(0,0);
     lcd.print("connected     ");
   if(DEBUG){
     Serial.println("sendind request");
   client.print("GET /pushingbox?devid=");
   client.print(devid);
   client.println(" HTTP/1.1");
   client.print("Host: ");
   client.println(serverName);
   client.println("User-Agent: Arduino");
   client.println();
   lcd.setCursor(0,0);
   lcd.print(" sent!       ");
   delay(5000);
   lcd.clear();
 else {
   if(DEBUG){
     Serial.println("connection failed");
Arrch
Auto Format Failed: Too many right curly braces
If you format your code in a more conventional way, this shouldn't be difficult to spot.
PaulS
The correct ratio of answers to questions is a minimum of 1:1. You ratio is a bit less than that.
HazardsMind
#6
Feb 15, 2013, 09:04 pm Last Edit: Feb 15, 2013, 09:06 pm by HazardsMind Reason: 1
The lack of proper formatting this code has, will haunt me in my dreams.
No function?
  lcd.begin(16, 2);
  //lcd.print("W-");
  dht.begin();
    lcd.setCursor(0,0);
  else{
    lcd.setCursor(0,0);
    delay(2000);
    lcd.clear();
    delay(2000);
    lcd.clear();
    FED=0;
    lcd.print("F");
    lcd.print(FED);
My GitHub:
UKHeliBob
Is this the full extent of the setup() function ?
server.begin();
mrfunk
OK lets start again.. I want to display some analogue values on a server, as well as using pushing box.
so I want to combine this code
// for W5100 ethernet shield
// the IP address will be dependent on your local network/router
// port 80 is default for HTTP, but can be changed as needed
// use IP address like http://192.168.1.102/ in your brouser
#include <SPI.h>
byte ip[] = { 192, 168, 1, 102 };
Server server(80);
 // start the server
 server.begin();
 // listen for incoming clients
 if (client) {
       // see if HTTP request has ended with blank line
       if (c == '\n') {
         client.println();
         //meta-refresh page every 2 seconds
         client.print("<HEAD>");
         client.print("<meta http-equiv=\"refresh\" content=\"2\">");
         client.print("<TITLE />Zoomkat's meta-refresh test</title>");
         client.print("</head>");
         for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
         break;
   delay(1);
   client.stop();
mrfunk
and wanted to combine with my code  with my code
#include <SPI.h>
#include "DHT.h"
// MODIFY HERE //
byte mac[] = {
char DEVID1[] = "v1CC65E36Dxxx00";        //Scenario
char DEVID2[] = "v9565F5FAAxxx41";        //Scenario
#define pinDevid1 8// Water
#define pinDevid2 9// FED
///               4    6  11  12 13  14
//int countMAILW=0;
int count = 0;
int FED = 0;
int countMAILF = 0;
const int pump = 4;
const int fan = 5;
// Debug mode
#define DEBUG true
//   End    //
 lcd.begin(16, 2);
 //lcd.print("W-");
 dht.begin();
   lcd.setCursor(0,0);
 else{
   lcd.setCursor(0,0);
   delay(2000);
   lcd.clear();
   delay(2000);
   lcd.clear();
   FED=0;
   lcd.print("F");
   lcd.print(FED);
 else {
   Serial.print(h);
   Serial.print(t);
 lcd.print("H:");
 lcd.print(h);
 lcd.print("%");
 //delay(2000);
 lcd.print("T:");
 lcd.print(t);
 //lcd.print("C");
 //delay(2000);
 if(t>=26)
   lcd.print("F");
 if(t<=24)
   lcd.print("_");
 lcd.setCursor(0,0);
 lcd.print("W-");
 delay(100);
   //countMAILF=0;
   delay(2000);
     delay(2000);
   lcd.print("P");
   delay(10000);
   lcd.print("R");
 if(sensorValue>800)
   lcd.print("_");
   count=0;
   if(DEBUG){
   if(DEBUG){
 //DEBUG part
   if(DEBUG){
     Serial.print(c);
   if(DEBUG){
     Serial.println();
   if(DEBUG){
   client.stop();
 client.stop();
 if(DEBUG){
   lcd.setCursor(0,0);
   if(DEBUG){
     lcd.setCursor(0,0);
   if(DEBUG){
   client.println();
   lcd.setCursor(0,0);
   delay(5000);
   lcd.clear();
 else {
   if(DEBUG){
mrfunk
sorry three replies due to charcter count..
the initial  server code came from ..http://arduino.cc/forum/index.php?topic=70177.0;wap2
but creates these errors
sketch_feb15a:11: error: no matching function for call to 'Server::Server(int)'
As of Arduino 1.0, the Server class in the Ethernet library has been renamed to EthernetServer.
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Server.h:4: note: candidates are: Server::Server()
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Server.h:4: note:                 Server::Server(const Server&)
sketch_feb15a:11: error: cannot declare variable 'server' to be of abstract type 'Server'
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Server.h:4: note:   because the following virtual functions are pure within 'Server':
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Print.h:48: note:    virtual size_t Print::write(uint8_t)
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Server.h:6: note:    virtual void Server::begin()
sketch_feb15a.ino: In function 'void loop()':
sketch_feb15a:23: error: 'class Server' has no member named 'available'
sketch_feb15a:23: error: cannot declare variable 'client' to be of abstract type 'Client'
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:7: note:   because the following virtual functions are pure within 'Client':
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:12: note:    virtual size_t Client::write(uint8_t)
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:13: note:    virtual size_t Client::write(const uint8_t*, size_t)
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:14: note:    virtual int Client::available()
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:15: note:    virtual int Client::read()
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:17: note:    virtual int Client::peek()
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:18: note:    virtual void Client::flush()
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:10: note:    virtual int Client::connect(IPAddress, uint16_t)
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:11: note:    virtual int Client::connect(const char*, uint16_t)
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:16: note:    virtual int Client::read(uint8_t*, size_t)
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:19: note:    virtual void Client::stop()
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:20: note:    virtual uint8_t Client::connected()
C:\Users\VJPC\Documents\arduino-1.0.3\hardware\arduino\cores\arduino/Client.h:21: note:    virtual Client::operator bool()
Grumpy_Mike
Close but no coconut.
You gave two sketches and the error from when you tried to combine the two but you did not give the combined code that gave those error messages.
For what you need to do to combine two sketches see here:-
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
mrfunk
ok cheers mike...
Im getting errors on just the client... before i merge it.. it looks like its not compatible with my library.
HazardsMind
Or you didn't put the library in the correct folder. What IDE are you using?
My GitHub:
mrfunk
#14
Feb 15, 2013, 10:16 pm Last Edit: Feb 15, 2013, 11:00 pm by Hackdub Reason: 1
1.03  ver
OK made a lot of progess.. found a working client in examples... DOH  ...
 Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
IPAddress ip(192,168,0,7);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
  while (!Serial) {
   ; // wait for serial port to connect. Needed for Leonardo only
 server.begin();
 Serial.print("server is at ");
 if (client) {
   Serial.println("new client");
       Serial.write(c);
         client.println("Connnection: close");
         client.println();
         client.println("<!DOCTYPE HTML>");
         client.println("<html>");
                   // add a meta refresh tag, so the browser pulls again every 5 seconds:
         client.println("<meta http-equiv=\"refresh\" content=\"5\">");
           int sensorReading = analogRead(analogChannel);
           client.print(sensorReading);
         client.println("</html>");
         break;
       if (c == '\n') {
   delay(1);
   client.stop();
   Serial.println("client disonnected");
Just struggling to get it to merge with my original code.....  the loop part... just cant find the right place to drop it in.
cheers
David
