Topic: Atmega8 - compile error (Read 907 times) previous topic - next topic
darksir
I have sketch when is fully functional on Mega328.
Now I have some errors when I tried to compile a program for Mega8 :
C:\DOCUME~1\Notebook\LOCALS~1\Temp/cchjwH1j.s: Assembler messages:
C:\DOCUME~1\Notebook\LOCALS~1\Temp/cchjwH1j.s:29: Error: illegal opcode jmp for mcu atmega8
C:\DOCUME~1\Notebook\LOCALS~1\Temp/cchjwH1j.s:269: Error: illegal opcode jmp for mcu atmega8
I have selected board : Arduino NG w ATMEGA8...
In sketch I using WDT, HW serial, SW serial and some IF, delays and write to ports. Arduino IDE is 1.0.2
Please can you help me find source of this problem?
many thanks,
Petr
Nick Gammon
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
darksir
I found this error.
In sketch I have function software reset, which contain :
Code: [Select]
void softReset()
asm volatile ("  jmp 0");            // mega8 not supported
So, when I commented it, everything is ok. I change this function to wdt reset and everything will be ok.
Petr
Nick Gammon
The Atmega8 doesn't have a "jmp" instruction. It has a "ijmp" which jumps to whereever the Z register is pointing. This compiles (not tested on an Atmega8 but works on a Atmega328):
Code: [Select]
void softReset()
   Serial.end ();  // if necessary
   asm ("cli");          // interrupts off
   // reset USART to reset defaults
  #ifdef __AVR_ATmega8__
    UDR = 0;
    UCSRA = _BV (UDRE);
    UCSRB = 0;
    UCSRC = _BV (URSEL) | _BV (UCSZ1) |  _BV (UCSZ0);
    UBRRL = 0;
    UBRRH = 0;
  #else
    UDR0   = 0;
    UCSR0A = _BV (UDRE0);
    UCSR0B = 0;
    UCSR0C = _BV (UCSZ01) |  _BV (UCSZ00);
    UBRR0L = 0;
    UBRR0H = 0;
  #endif
   asm volatile ("eor r1,r1");     // make sure zero-register is zero
   asm volatile ("ldi r16,0xFF");  // end of RAM (0xFF)
   asm volatile ("sts 0x5E,r16");  // SPH
   asm volatile ("sts 0x5D,r16");  // SPL
   asm volatile ("eor r31,r31");   // Clear Z register
   asm volatile ("eor r30,r30");
   asm volatile ("ijmp");          // jump to (Z)
void setup ()
  Serial.begin (115200);
  Serial.println ("Entering setup.");
  }  // end of setup
void loop ()
  delay (2000);
  softReset ();
  }  // end of loop
I put some extra stuff in there, because Optiboot (bootloader) expects certain things, like the stack pointer to be correct, and the USART to be in a default state.
I should point out however that this is not the same as doing a hardware reset (pushing the reset button). All this does is jump back to the start of the code. It doesn't set IO ports back to inputs, and things like that.
Really, you should never need to do a software reset like that. A "watchdog" reset would be better because that is an actual reset.
More info:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
