Topic: How can I upload multiple sketches (Read 2349 times) previous topic - next topic
Kenn13542
I have tried uploading multiple sketches, using tabs in the Arduino IDE, but it keeps coming up with:
Fading_Green.ino: In function 'void setup()':
Fading_Green:16: error: redefinition of 'void setup()'
Decoder_Sketch:34: error: 'void setup()' previously defined here
Fading_Green.ino: In function 'void loop()':
Fading_Green:22: error: redefinition of 'void loop()'
Decoder_Sketch:39: error: 'void loop()' previously defined here
They are in two differnt tabs and I thought that, that would solve it, but it didn't,
Any help with uploading multiple sketches would be great.
Thanks,Ken
retrolefty
Thanks,Ken
One can only upload a single sketch to a arduino board, it's a rule one arduino board, one sketch to run. If you have multiple sketches each with their own setup() and loop() function then you can't combine them by using the tabbed edit windows, as again you can only compile and load one sketch.
What you may want to do is to write one single sketch that performs all the same tasks that the individual sketch tasks did. That would require combining the coding somewhat manually and making sure you don't duplicate function or variable names and don't use the same hardware resources like pin numbers for the different tasks.
I bet this doesn't help?
Lefty
Kenn13542
kapelan
How could i combine them?
loop
runSketch_1();
runSketch_2();
loop has to be only one
James C4S
If you had two recipes to make cookies, how would you combine them?
Shpaget
Loops are like Highlanders. There can be only one.
A4kash
can't we run them simultaneously through a single sketch.
James C4S
If both programs are re-written to run as one, you can switch between them.  But this almost always means conflicts.
The microcontroller used in the Arduino is a very single minded device.  It isn't like a PC with an operating system that can easily store and run multiple programs.
