Offline
Newbie
« on: February 16, 2013, 07:26:15 am » |
Hi, I am using the SoftwareSerial library to communicate with my ATTiny84. I can see that I am able to send and receive data via the FTDI breakout. In the Serial Monitor, I am receiving "junk" and it seems I am sending "junk". I have set the baud rate to 300, but I don't think it is a speed issue. Any ideas? Here is my code: #include <SoftwareSerial.h>
#define rxPin 2 #define txPin 3 // Attach the serial display's RX line to digital pin 2 SoftwareSerial mySerial(rxPin,txPin); // pin 2 = TX, pin 3 = RX (unused) int led = 0; int GREEN = 7; int val = 109;
void setup() { mySerial.begin(300); // set up serial port for 300 baud pinMode(rxPin, INPUT); pinMode(txPin, OUTPUT); pinMode(led, OUTPUT); pinMode(GREEN, OUTPUT); delay(500); // wait for display to boot up }
void loop() { val = mySerial.read(); mySerial.println(val); mySerial.write("Hello, world!"); digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level) delay(500); // wait for a second digitalWrite(led, LOW); // turn the LED off by making the voltage LOW delay(500); if (val == 110) { // "n" = 110 in dec from ascii digitalWrite(GREEN, HIGH); // turn the LED on (HIGH is the voltage level) } }
« Last Edit: February 16, 2013, 07:29:47 am by PhillyNJ »
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #1 on: February 16, 2013, 08:46:20 am » |
val = mySerial.read(); mySerial.println(val); Read and echo the first byte available in the buffer, even if there is nothing in the buffer == garbage. mySerial.write("Hello, world!"); Use a binary method to send ASCII data. Novel idea. I wonder why it's not more common.
Logged
Offline
Newbie
« Reply #2 on: February 16, 2013, 09:10:06 am » |
Hi Thanks for the help. - Can you provide an example? Read and echo the first byte available in the buffer, even if there is nothing in the buffer == garbage.
I understand, Garbage in, garbage out. So if I send a char, e.g. 'n', val should = '110' (ASCII) and should print out to serial '110'. Is this correct? Or will val always equal garbage. I am learning, so I appricate all the 'dumb down' help I can get
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #3 on: February 16, 2013, 09:16:54 am » |
Can you provide an example? I presume that you are able to read the documentation on the SoftwareSerial class, and see that it derives from Stream which derives from Print. I presume that you are then able to took at the various methods offered - write() for binary data and print() for ASCII data. I further presume that examples exist in the documentation. So if I send a char, e.g. 'n', val should = '110' (ASCII) and should print out to serial '110'. Is this correct? Yes. However, loop() executes quite often - millions of times per second, depending on what happens in each iteration of loop. Between the time that you send an 'n' and the Arduino receives it, it could have send 5000 garbage characters back to the sender. Then, one good character or string, then a few thousand more garbage characters. There is an available() method that bears investigating, to prevent reading what isn't there.
Logged
Offline
Newbie
« Reply #4 on: February 16, 2013, 09:53:12 am » |
I understand the docs and understand what you're saying. The issue isn't that I get SOME junk, I am saying when I send a char, it will print out to the serial monitor as 'ÿ'. So even if I use binary or ASCII, the result is the same. So, mySerial.write("Hello world"); shows in the serial monitor as 'ÿ' Below is an example that shows that I a receiving data on the ATTiny84, and my serial monitor is receiving data: #include <SoftwareSerial.h>
#define rxPin 1 #define txPin 2 #define ledPin 8
// set up a new serial port SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin); byte pinState = 0;
void setup() { // define pin modes for tx, rx, led pins: pinMode(rxPin, INPUT); pinMode(txPin, OUTPUT); pinMode(ledPin, OUTPUT); // set the data rate for the SoftwareSerial port mySerial.begin(9600); mySerial.write("Hello World - SoftwareSerial"); }
void loop() { // listen for new serial coming in: if(mySerial.available()){ char someChar = mySerial.read(); // print out the character: mySerial.write(someChar); // toggle an LED just so you see the thing's alive. // this LED will go on with every OTHER character received: toggle(ledPin); } }
void toggle(int pinNum) { // set the LED pin using the pinState variable: digitalWrite(pinNum, pinState); // if pinState = 0, set it to 1, and vice versa: delay(50); pinState = !pinState; } As you can see I am only toggling the led if I am receiving data on the ATTiny84. Once again, I get 'ÿ' in tbe serial monitor.
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #5 on: February 16, 2013, 10:19:36 am » |
The y with the two dots over is is what happens when you send -1 to the serial monitor. That is the return code from read() when there is nothing to read. All those funny ys are from printing -1s, not from writing "Hello world", which you shouldn't be doing.
When are you intending to start using the correct function (print(), if you need another hint) to send ASCII data?
Oh, and what clock rate are you using with the ATTiny? Have you selected the correct speed on both ends? If you are using other than a 16MHz chip, the speeds won't be the same.
Logged
Offline
Newbie
« Reply #6 on: February 16, 2013, 11:19:33 am » |
Thanks - starting using print as hinted  , also set my clock speed to 8 MHz. I followed these instructions ( http://hlt.media.mit.edu/?p=1695): Configuring the ATtiny to run at 8 MHz (for SoftwareSerial support)
By default, the ATtiny’s run at 1 MHz (the setting used by the unmodified “ATtiny45″, etc. board menu items). You need to do an extra step to configure the microcontroller to run at 8 MHz – necessary for use of the SoftwareSerial library. Once you have the microcontroller connected, select the appropriate item from the Boards menu (e.g. “ATtiny45 (8 MHz)”). Then, run the “Burn Bootloader” command from the Tools menu. This configures the fuse bits of the microcontroller so it runs at 8 MHz. Note that the fuse bits keep their value until you explicitly change them, so you’ll only need to do this step once for each microcontroller. (Note this doesn’t actually burn a bootloader onto the board; you’ll still need to upload new programs using an external programmer.) Still no luck
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #7 on: February 16, 2013, 11:40:55 am » |
What baud rate are you using on the tiny? On the Serial Monitor?
Logged
Offline
Newbie
« Reply #8 on: February 16, 2013, 11:41:57 am » |
I've tried 9600 and 4800.
Logged
Denmark
Offline
God Member
« Reply #9 on: February 16, 2013, 12:16:50 pm » |
Are you sure you are using the right pin. The sketch below will use pin D3/A7/PA7 physical pin 6 to output from Serial Edit: I use this core http://code.google.com/p/arduino-tiny/And Arduino 1.01 As far as I remember there was problems with SoftwareSerial in version 1.00 #include <SoftwareSerial.h>
#define rxPin 2 #define txPin 3 SoftwareSerial mySerial(rxPin,txPin); void setup() { mySerial.begin(9600); }
void loop() { mySerial.println("Testing "); }
« Last Edit: February 16, 2013, 12:46:36 pm by Erni »
Logged
Offline
Newbie
« Reply #10 on: February 16, 2013, 12:51:02 pm » |
Erni - you rock! My pins were off by one.. thanks so much.
Also thanks to Paul. I appreciate all the help and guidance.
Logged
