Topic: RGB LED Common Anode Help (Read 1 time) previous topic - next topic
kculm
Feb 16, 2013, 06:05 pm Last Edit: Feb 16, 2013, 06:20 pm by kculm Reason: 1
Hi all,
Need a Little help.
I came across the sketch the Runs though all the  Colors nice and smooth.  I get it to work fine on my BB using common anode  cathodes LEDS.
But because I have a bunch of common cathode Anode RGB LEDS I would like to use can someone help me out in figuring  out what I need to change in the code.
I am still learning .
Thanks
Code: [Select]
RGB LED - Automatic Smooth Color Cycling
Marco Colli
April 2012
Uses the properties of the RGB Colour Cube
The RGB colour space can be viewed as a cube of colour. If we assume a cube of dimension 1, then the
coordinates of the vertices for the cubve will range from (0,0,0) to (1,1,1) (all black to all white).
The transitions between each vertex will be a smooth colour flow and we can exploit this by using the
path coordinates as the LED transition effect.
// Output pins for PWM
#define  R_PIN  3  // Red LED
#define  G_PIN  5  // Green LED
#define  B_PIN  6  // Blue LED
// Constants for readability are better than magic numbers
// Used to adjust the limits for the LED, especially if it has a lower ON threshold
#define  MIN_RGB_VALUE  10   // no smaller than 0.
#define  MAX_RGB_VALUE  255  // no bigger than 255.
// Slowing things down we need ...
#define  TRANSITION_DELAY  70   // in milliseconds, between individual light changes
#define  WAIT_DELAY        500  // in milliseconds, at the end of each traverse
// Total traversal time is ((MAX_RGB_VALUE - MIN_RGB_VALUE) * TRANSITION_DELAY) + WAIT_DELAY
// eg, ((255-0)*70)+500 = 18350ms = 18.35s
// Structure to contain a 3D coordinate
typedef struct
 byte  x, y, z;
} coord;
static coord  v; // the current rgb coordinates (colour) being displayed
Vertices of a cube
   C+----------+G
 B+---------+F |
  | |       |  |    y
  |D+-------|--+H   ^  7 z
 A+---------+E      +--->x
const coord vertex[] =
//x  y  z      name
 {0, 0, 0}, // A or 0
 {0, 1, 0}, // B or 1
 {0, 1, 1}, // C or 2
 {0, 0, 1}, // D or 3
 {1, 0, 0}, // E or 4
 {1, 1, 0}, // F or 5
 {1, 1, 1}, // G or 6
 {1, 0, 1}  // H or 7
A list of vertex numbers encoded 2 per byte.
Hex digits are used as vertices 0-7 fit nicely (3 bits 000-111) and have the same visual
representation as decimal, so bytes 0x12, 0x34 ... should be interpreted as vertex 1 to
v2 to v3 to v4 (ie, one continuous path B to C to D to E).
const byte path[] =
 0x01, 0x23, 0x76, 0x54, 0x03, 0x21, 0x56, 0x74,  // trace the edges
 0x13, 0x64, 0x16, 0x02, 0x75, 0x24, 0x35, 0x17, 0x25, 0x70,  // do the diagonals
#define  MAX_PATH_SIZE  (sizeof(path)/sizeof(path[0]))  // size of the array
 pinMode(R_PIN, OUTPUT);   // sets the pins as output
 pinMode(G_PIN, OUTPUT);
 pinMode(B_PIN, OUTPUT);
void traverse(int dx, int dy, int dz)
// Move along the colour line from where we are to the next vertex of the cube.
// The transition is achieved by applying the 'delta' value to the coordinate.
// By definition all the coordinates will complete the transition at the same
// time as we only have one loop index.
 if ((dx == 0) && (dy == 0) && (dz == 0))   // no point looping if we are staying in the same spot!
   return;
 for (int i = 0; i < MAX_RGB_VALUE-MIN_RGB_VALUE; i++, v.x += dx, v.y += dy, v.z += dz)
   // set the colour in the LED
   analogWrite(R_PIN, v.x);
   analogWrite(G_PIN, v.y);
   analogWrite(B_PIN, v.z);
   delay(TRANSITION_DELAY);  // wait fot the transition delay
 delay(WAIT_DELAY);          // give it an extra rest at the end of the traverse
 int    v1, v2=0;    // the new vertex and the previous one
 // initialise the place we start from as the first vertex in the array
 v.x = (vertex[v2].x ? MAX_RGB_VALUE : MIN_RGB_VALUE);
 v.y = (vertex[v2].y ? MAX_RGB_VALUE : MIN_RGB_VALUE);
 v.z = (vertex[v2].z ? MAX_RGB_VALUE : MIN_RGB_VALUE);
 // Now just loop through the path, traversing from one point to the next
 for (int i = 0; i < 2*MAX_PATH_SIZE; i++)
   // !! loop index is double what the path index is as it is a nybble index !!
   v1 = v2;
   if (i&1)  // odd number is the second element and ...
     v2 = path[i>>1] & 0xf;  // ... the bottom nybble (index /2) or ...
   else      // ... even number is the first element and ...
     v2 = path[i>>1] >> 4;  // ... the top nybble
   traverse(vertex[v2].x-vertex[v1].x,
            vertex[v2].y-vertex[v1].y,
            vertex[v2].z-vertex[v1].z);
AWOL
You just need to invert your analogWrites , so subtract the value you need to write from 255 (assuming you're not using a Due)
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
kculm
Thanks for the fast response, but I am still in over my head. Not to be a pain, but could you explain. I very new at this. I fine I learn best by plying with the sketch and seeing how it works.
Thanks
kculm
One more thing I don't understand.
In the code it has me using
Pins 3,5,6 for r,g,b, and GND for the cathode .
but because I want to use command anode LEDS. I am not sure what pin to use for that.
AWOL
There are three analogWrites in your sketch.
You have to modify each one so that, instead of
Code: [Select]
analogWrite(pin,x);, it reads
Code: [Select]
analogWrite(pin, 255-x);
Pins 3,5,6 for r,g,b, and +5V for the anode .
kculm
AWOL,
Thanks a lot, I will give it a go.
kculm
Code: [Select]
Code: [Select]
Is this what you mean?
Before,
Code: [Select]
After,
Code: [Select]
analogWrite(R_PIN, 255- v.x);
    analogWrite(G_PIN, 255- v.y);
    analogWrite(B_PIN, 255- v.z);
AWOL
kculm
Thanks AWOL works great.
One last thing.  Do I need to put a resistor on all three Cathodes or just the one Anode.
BTW, Thanks for all your Help.
AWOL
