Topic: Potentiometer reading (Read 704 times) previous topic - next topic
NedelkaO
Hi, I'm working on MIDI controler using USB/MIDI cable. It works nicely, but when I a rotate pot it starts to flicker. I looked at the console and it seems like my filtering doesn't work, because the value is changing by 1. I mean like 125,124,125,124 and causing to my master volume in a DAW go crazy. Could anyone help me to create a filtering, that will elliminate this problem? Thanks a lot.
robtillaart
I assume the solution is to take the average of multiple readings, or to average the current reading with the previous one.
(depending on the reactivity you want)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
