Topic: LiquidWare Buttonshield Errors- Don't Understand. (Read 658 times) previous topic - next topic
BenCakir
I am using a ButtonShield from Liquidware for a project, but the documentation is flaky and there are compatibility errors.
The only way to get the library is to download their Arduino IDE, which runs on 18. WHen I try to take the library from it and put it in the official 1.0.3 distro, then run the sample code,I get this:
Code: [Select]
#include <ButtonShield.h>
ButtonShield buttonsA = ButtonShield(0);
ButtonShield buttonsB = ButtonShield(1);
Serial.print("ModeA: ");
Serial.print(buttonsA.readButtons());
Serial.print(" ModeB: ");
Serial.print(buttonsB.readButtons());
Code: [Select]
/Applications/Arduinorecent.app/Contents/Resources/Java/libraries/ButtonShield/ButtonShield.cpp:2:20: error: wiring.h: No such file or directory
/Applications/Arduinorecent.app/Contents/Resources/Java/libraries/ButtonShield/ButtonShield.cpp: In member function 'void ButtonShield::setMode(uint8_t)':
/Applications/Arduinorecent.app/Contents/Resources/Java/libraries/ButtonShield/ButtonShield.cpp:39: error: 'INPUT' was not declared in this scope
/Applications/Arduinorecent.app/Contents/Resources/Java/libraries/ButtonShield/ButtonShield.cpp:39: error: 'pinMode' was not declared in this scope
/Applications/Arduinorecent.app/Contents/Resources/Java/libraries/ButtonShield/ButtonShield.cpp:40: error: 'HIGH' was not declared in this scope
/Applications/Arduinorecent.app/Contents/Resources/Java/libraries/ButtonShield/ButtonShield.cpp:40: error: 'digitalWrite' was not declared in this scope
/Applications/Arduinorecent.app/Contents/Resources/Java/libraries/ButtonShield/ButtonShield.cpp: In member function 'int ButtonShield::readButtons()':
/Applications/Arduinorecent.app/Contents/Resources/Java/libraries/ButtonShield/ButtonShield.cpp:50: error: 'digitalRead' was not declared in this scope
Variations of these errors appear in different examples:
http://www.liquidware.com/system/0000/2370/ButtonShield_Datasheet_13Jul09.pdf
http://antipastohw.pbworks.com/w/page/26626459/ButtonShield
https://github.com/liquidware/antipasto_arduino
spatula
Try editing ButtonShield.cpp and replace #include <wiring.h> with #include <Arduino.h>.
