0
Offline
Jr. Member
Arduino rocks
« Reply #15 on: February 17, 2013, 02:33:03 pm » |
I dont know if i followed exactly what you said. (english is not my main language) So i can use my duemilanove with ethernet shield on top and also use nrf24l01 chip with no conflict between those two ? didnt understand exactly what you mean by manually switching different pins from pin 10 :/
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #16 on: February 17, 2013, 02:59:16 pm » |
@ zoomkat i thought of that, but wouldnt that make the process of data slower ? It might make it slower, but may not be the slowest part of your network or noticable from a human perception point of view.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #17 on: February 17, 2013, 03:14:26 pm » |
Ok, may be i'll just connect my master node (custom pcb with nrf24l01 chip) to computer with ftdi cable and then it'll receive commands from serial via php page or something like that...it's not the best for sure, the best option would be connecting ethernet sield and nrf24 chip together, but i didnt understood how to do that.
Logged
the land of sun+snow
Offline
Edison Member
« Reply #18 on: February 17, 2013, 03:17:41 pm » |
You can use SPI pins 11..13 for more than 1 device, but you just have to use a different chip-select pin for each different device, pin 10 for one and some other pin for the others. So you have to make sure the nrf2401 shield uses a something different from the ethernet board for chip-select.
Logged
Something different - Kitchen-Sink Arduino-compatible boards
0
Offline
Jr. Member
Arduino rocks
« Reply #19 on: February 17, 2013, 03:28:30 pm » |
And that is done by software only ? i found this: One little catch is with Ethernet shields based on the Wiznet W5100 chipset, which includes the official Ethernet shield and many third-party shields. The W5100 has a design flaw that causes it to maintain control of the SPI bus even when another device has been selected, making it very tricky to combine the official Ethernet shield with other shields that use SPI. The Freetronics Ethernet Shield uses the W5100 chipset but includes a fix in hardware so it doesn't have that problem and will happily share the bus with other SPI devices. source: http://www.freetronics.com/pages/stacking-arduino-shields#.USE9h6Xvh8ESo maybe there's a problem with ethernet shield, even if i can use another pin for CS (on the nrf24l01 chip), the ethernet shield wont let me use it :s
« Last Edit: February 17, 2013, 04:46:41 pm by Carlcox89 »
Logged
Offline
Edison Member
« Reply #20 on: February 17, 2013, 05:08:38 pm » |
You're just gonna have to work that out between whatever shields you have. Check out the schematics, etc. Many shields seem to have marginal designs. You may have to cut some traces, and patch software, to get shields to play nice together, or toss some shields in the closet, and buy something else. XBee shields are notorious for this kind of problem too. EDIT: the other option is, you can try using the software SPI commands to connect to the NRF2401 module, and use a different set of pins than 10..13, http://arduino.cc/en/Reference/ShiftInhttp://arduino.cc/en/Reference/ShiftOut
« Last Edit: February 17, 2013, 06:29:47 pm by oric_dan »
Logged
0
Offline
Tesla Member
Arduino rocks
« Reply #21 on: February 17, 2013, 05:15:54 pm » |
So maybe there's a problem with ethernet shield, even if i can use another pin for CS (on the nrf24l01 chip), the ethernet shield wont let me use it :s The w5100 shield is what it is. As far as I know most shields are made with the idea of them being the only shield on the arduino. You start stacking shields and you are pretty much on your own to figure out the interfacing.
Logged
Dee Why NSW
Offline
God Member
« Reply #22 on: February 17, 2013, 06:56:06 pm » |
Yes, there are some interesting examples out there.
Some useful information here file:///E:/Arduino/arduino-1.0.1/libraries/NRF24/doc/index.html
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #23 on: February 17, 2013, 08:43:12 pm » |
Some useful information here file:///E:/Arduino/arduino-1.0.1/libraries/NRF24/doc/index.html My problem isnt with the nrf24 chip. I just need some opinion of what is the best approach for the master node to be connected to internet
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #24 on: February 19, 2013, 09:29:36 pm » |
So, no one has an opinion on what could be the best approach ? - arduino w/ Ethernet shield + nrf24 chip
- Nrf24 chip on custom pcb being connected to pc (serial) and a php that would handle the requests...etc
- Nf24 chip on custom pcb connected (serial) to arduino with ethernet shield
Logged
Offline
Edison Member
« Reply #25 on: February 19, 2013, 10:54:10 pm » |
I thought I had made a couple of straightforward suggestions.
Besides those, from my perspective, I'd probably look for an ethernet shield that's not so rigid in demanding domination over the buss.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #26 on: February 19, 2013, 10:59:41 pm » |
@ oric_dan , i just read the EDIT you made in that post before  i actually found a guy in the nrf24 maniacbug library post that has an arduino mega with ethernet shield and nrf24 working together. I think i'll follow that
Logged
California
Offline
Edison Member
« Reply #27 on: February 20, 2013, 12:39:12 am » |
I've pretty much been working on the same setup with the exception of using RFM12Bs instead of the nrf24s (Form factor issue and availability at the moment). I haven't had any issues with the Ethernet Shield and the RFM12B after adjusting the library to use pin 9 as the SS, but I haven't tried doing that for the NRF24s yet.
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #28 on: February 20, 2013, 01:43:48 pm » |
@ Arrch thanks for the info
Logged
Offline
Edison Member
« Reply #29 on: February 20, 2013, 03:14:06 pm » |
@ oric_dan , i just read the EDIT you made in that post before  i actually found a guy in the nrf24 maniacbug library post that has an arduino mega with ethernet shield and nrf24 working together. I think i'll follow that Can you give a link to this?
Logged
