Topic: Another Room Automation project (Read 9437 times) previous topic - next topic
oric_dan
I've pretty much been working on the same setup with the exception of using RFM12Bs instead of the nrf24s (Form factor issue and availability at the moment). I haven't had any issues with the Ethernet Shield and the RFM12B after adjusting the library to use pin 9 as the SS, but I haven't tried doing that for the NRF24s yet.
You mean the library for the RFM12, or for the ethernet module?
Also, which RFM12 library are you using? I tried the JeeLib library, but the examples don't work.
Carlcox89
http://arduino.cc/forum/index.php/topic,62222.msg1099825.html#msg1099825 :)
stan001
So, no one has an opinion on what could be the best approach ?
  • arduino w/ Ethernet shield + nrf24 chip
  • Nrf24 chip on custom pcb being connected to pc (serial) and a php that would handle the requests...etc
  • Nf24 chip on custom pcb connected (serial) to arduino with ethernet shield
Why don't you explore using Raspberry Pi as the central hub with built-in ethernet or USB wifi/BT adapter.. it is cheaper than an Eth Shield and a lot more powerful and flexible and runs an O/S...
If you need a longer bridge, you can have 2 Raspberry Pi running a wifi link to each other with external wifi antennas... flexible solution using common wifi products...
http://arduino-for-beginners.blogspot.com/2013/02/setup-nordic-nrf24l01-rf-modules-to.html
This HOWTO uses both the maniacbug libraries for both Arduino and ported to RPi so the codes looks similar...
My idea was to make the Arduino/nRF onto a PCB as remote notes connected to RPi with a nRF radio with external antenna for better range/coverage..
