Author Topic: Vibration Sensor 1104  (Read 1025 times)
Good evening!!!
I try to make a program about arduino mega 2560 and sensor 1104....
i try something simple....just make a vibration ...but i can't find some material about this...
Could anyone help me ?????? smiley-cry
Netherlands
Online Online
can you post a link to the datasheet of that 1104, I get 156.000.000 hits in Google on the number 1104
Rob Tillaart
http://www.phidgets.com/products.php?product_id=1104_0
i can't understand how it works.....thanku very much for your interest!!!!
Netherlands
Online Online
it is an analog device so you should connect one pin to +5V one to GND and the third to Analog pin A0 for example
some loop like this should work.
  int x = analogRead(A0);
  float voltage = x * 5.0 / 1023;
  Serial.println(voltage);
Rob Tillaart
ok ...something like this  i have done ..but i need something to put into my code to make the vibration.......how is it work ???
for the temperature sensor and the  light sensor i have a formula..but for this ???????
Johannesburg UTC+2
It doesn't make a vibration: it's a sensor not an actuator.
When it feels vibration it will output a voltage based on the intensity of the vibration, eg 0V for "still" and 5V for a "earthquake"; you read that analog input as Rob suggested and your program acts based on the level of vibration.
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
thanku  !!!!!!!!...i thought something else.....
now i can explain this sensor into my project
Johannesburg UTC+2
Maybe have 3 LEDs.... green for still, yellow for minor vibration and red for a big shake, based on the analog reading?
IT Crowd:
you mean the pienzo?????????
my pienzo which is attached on the sensor has a green
ooops!!!!no i am wrong!!!!!
i have not any leds..... smiley-eek
Johannesburg UTC+2
No, I meant maybe you could add coloured LEDs to your project and have them light up depending on how big a shake the sensor registers.
IT Crowd:
my university can't give me any led.....i must do something with these matereals(sensor+arduino only)
i have my mobile phone near the sensor and when it is vibrating the output voltage is the same like before.. smiley-cry
Johannesburg UTC+2
Well, sensors by their very nature don't "do" anything, they "sense".... then you need an actuator to be the "do-er" based on what you sense. For example, you have a temperature sensor you say: well there's no point measuring the temperature if you don't act on that reading, eg switch the fan on if it's too hot.
But remember the Arduino has a built-in LED on pin 13- perhaps you could make that do something based on the readings
IT Crowd:
