Loading...
Pages: [1]   Go Down
Author Topic: SainSmart LCD Keypad Shield + ethernet shield  (Read 715 times)
Offline Offline
Newbie
View Profile
Like many others, I'm having trouble using a SainSmart LCD keypad shield in conjunction with an ethernet shield.
When stacked directly on my Arduino, I can get the LCD to display.
When stacked on top of the ethernet shield however, there's nothing output.
I read elsewhere about both shields using pin 4.
Is there anything I can do to get it to work, preferably without soldering?
Logged
Offline Offline
Newbie
View Profile
I also have this issue.  I have an Arduino Mega2560 with ethernet shield on top, headers on top of that, sainsmart 1602 lcd w/keypad on top of that.  When I try to use both shields, it immediately fails on grabbing DHCP.  Here is my code:
Code:
#include <DNS.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SD.h>
#include <Time.h>
#include <Timezone.h>
#include <LiquidCrystal.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
unsigned int localPort = 8888;
IPAddress timeServer(172, 16, 0, 4);
const int NTP_PACKET_SIZE = 48;
byte packetBuffer[NTP_PACKET_SIZE];
EthernetUDP Udp;
int timeZoneHour = -5;
long timeZoneOffset = (timeZoneHour * -1) * 60 * 60;
int NTP_UPDATE_INTERVAL = 10;
int counter = 0;
LiquidCrystal lcd(8, 13, 9, 4, 5, 6, 7);
void resetSauce() {
  void (*softReset) (void) = 0; //declare reset function @ address 0
  softReset();
unsigned long sendNtpPacket(IPAddress& address) {
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  packetBuffer[0] = 0b11100011;
  packetBuffer[1] = 0;
  packetBuffer[2] = 6;
  packetBuffer[3] = 0xEC;
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  Udp.beginPacket(address, 123);
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
unsigned long grabNtpTime() {
  Serial.print("GRABBING NTP FROM ");
  Serial.println(timeServer);
  counter = 0;
  sendNtpPacket(timeServer);
  delay(1);
  if (!Udp.parsePacket()) {
    Serial.println("No NTP packet found");
    return 0;
  Serial.println("SUCCESS");
  Udp.read(packetBuffer, NTP_PACKET_SIZE);
  unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
  unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
  unsigned long secsSince1900 = highWord << 16 | lowWord;
  const unsigned long seventyYears = 2208988800UL + timeZoneOffset;
  unsigned long epoch = secsSince1900 - seventyYears;
  return epoch;
void printDigits(int digits) {
  if (digits < 10) {
    lcd.print('0');
  lcd.print(digits);
void printDayOfWeek(int digits) {
  if (digits == 1) { lcd.print(" SUN"); }
  else if (digits == 2) { lcd.print(" MON"); }
  else if (digits == 3) { lcd.print(" TUE"); }
  else if (digits == 4) { lcd.print(" WED"); }
  else if (digits == 5) { lcd.print(" THU"); }
  else if (digits == 6) { lcd.print(" FRI"); }
  else if (digits == 7) { lcd.print(" SAT"); }
void printDateTime() {
  time_t eastern, utc;
  TimeChangeRule *tcr;
  TimeChangeRule usEDT = {"EDT", Second, Sun, Mar, 2, -240};
  TimeChangeRule usEST = {"EST", First, Sun, Nov, 2, -300};
  Timezone usEastern(usEDT, usEST);
  utc = now() + 2;
  eastern = usEastern.toLocal(utc, &tcr);
  printDayOfWeek(weekday(utc));
  lcd.print(" ");
  printDigits(hourFormat12(utc));
  lcd.print(":");
  printDigits(minute(utc));
  lcd.print(":");
  printDigits(second(utc));
  if (isAM()) {
    lcd.println(" AM");
    lcd.println(" PM");
  //Serial.println(tcr->abbrev);
void setupTime() {
  setSyncProvider(grabNtpTime);
  if (!Ethernet.begin(mac)) {
    lcd.println("DHCP FAILED");
    for(;;);
  Udp.begin(localPort);
  lcd.print("IP Address [DHCP]: ");
  lcd.println(Ethernet.localIP());
  setupTime();
  printDateTime();
Logged
Offline Offline
Newbie
View Profile
I gave up trying to use the SainSmart shield. I thought it was something to do with pin conflicts, and I found this interesting post:
http://www.martyndavis.com/?p=284
So I managed to get the ethernet shield to work unstacked by wiring it with the Arduino's ICSP pins, but still no luck with the LCD.
In the end, I got a (non-shield) display
http://www.oomlout.co.uk/lcd-display-16-x-2-p-212.html
and used that instead, wired to the stacked Arduino+Ethernet
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Liudr here in the forum sells a very nice (I have 2) RS232 "Backpack" that will work on 2 X 16 or 4 Xx 20 displays.. also has a connector for a 16 key matrix keypad... and a "Beeper". They're great for development or testing especially the keypad..  {Edit RKJ} ..
Bob
« Last Edit: March 06, 2013, 09:45:27 am by Docedison » Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Offline Offline
Newbie
View Profile
i got it working, i basically rerouted pin 4 going to lcd shield and placed it at I believe pin 22 and just bent pin 10 going to lcd shield, all is working now.
Logged
Pages: [1]   Go Up
Print
Jump to:
