Loading...
Pages: [1]   Go Down
Author Topic: Debouncing and toggle led using pushbutton problem  (Read 164 times)
Offline Offline
Newbie
View Profile
Hi i have the following code written and tested...it works with some strangeness...the led dims three times before going to on or off state....
I think the debounce is not working properly...i guess there is some modification needed in my code....some hints and tips please...thanks in advance for you time
ps  my input pin is pulled high...so should work when grounded or button pressed
Code:
int led = 12;
int presentState=1;
int buttonPress,countLow,countHigh;
  pinMode(13, OUTPUT);
    pinMode(12, OUTPUT);
// the loop routine runs over and over again forever:
    buttonPress=digitalRead(3);  //pin 3 is pulled high......so the function is activated only when button pressed and pin3 connected to ground....
    if(buttonPress==LOW)
      countLow++;//get some increment to assure the button is pressed continuously...manually...~~
      countHigh=0;
    countHigh++; //~~
    countLow=0;
    if(countHigh>60)
    countHigh=60;
    if(countLow>40)//when pressed long eg...40 machine cycles.....i hope we can eliminate debounce
     presentState=!presentState;
    presentState=presentState;
    digitalWrite(13,presentState);
« Last Edit: February 17, 2013, 06:53:30 pm by nepdeep » Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Read:-
http://arduino.cc/forum/index.php/topic,149015.0.html
You normally debounce by ignoring any change for a specific amount of time after the first transition. The loop exicuites very quickly and so it is too fast to debounce your switch in this way.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
How to use this forum
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Logged
Pages: [1]   Go Up
Print
Jump to:
