Pages: [1] 2   Go Down
Author Topic: Brown out reset loop due to thin traces?  (Read 382 times)
I made a board with a mega328, GPS Module, a few LED's and SD Card on it and I notice that when the battery still has plenty of power (3.9V (LiPo) with the mega328 operating at 3.3V internal 8 MHZ clock source) it will enter what I think is a brown out reset loop.  I think the culprit may be the fact that the entire board is routed with 8mil traces.  I have .1uF capacitors next to each Vcc pin and 2 10uF capacitors at the output of the buck/boost converter.  I don't have an oscilloscope so I can't really see what is happening.  Based on experience, would 8mil traces likely be the culprit?
Arduino Uno;
Mega328
Manchester (England England)
Solder is electric glue
The brown out voltage is not related to the supply voltage it is fixed. See the data sheet.
Right.....brown out voltage is 2.7V based on the arduino fuse bit settings.  I'm just wondering if the 8 mil traces could cause a significant voltage drop (from 3.3V to below 2.7V) when, for example, a pin connected to an LED turns on?  If you need more information, please let me know.
Arduino Uno;
Mega328
No I would not consider there would be sufficient voltage voltage drop on a narrow trace. Mainly because there is very little current flowing.
Melbourne, Australia
Shannon Member
Lua rocks!
I would measure the voltage and see. Also your sketch, which we can't see, might have bugs.
That is what I kind of figured when I first made the board, but it just seems weird that it works fine when the battery is fully charged but when it gets down to about 3.8 - 3.9V, it just starts entering a reset loop.  The buck/boost converter is putting out 3.3V so it isn't even having to boost the voltage at that point.  I thought that perhaps I didn't have enough capacitors next to the Vcc pins on the mega as another possibility.
Arduino Uno;
Mega328
Unfortunately I don't have a scope so I can't see what the voltage is at the moment that it resets.  I am sure the sketch is buggy, but it does run when the battery is fully charged.  It makes it hard to debug when I can't figure out if the reset condition is due to bugs in the sketch or if it is a hardware design problem.
Arduino Uno;
Mega328
Shannon Member
Lua rocks!
Change the fuse to brownout at a lower voltage and see what happens.
the land of sun+snow
8 mil traces, buck-boost converter. OOF! Is this on the same pcb? I don't know which part
you're using, but see the picture, same idea for buck-boost,
Kitchen-Sink Arduino-compatible boards
To do that, do I just change this line in board.txt:
atmega328bb.bootloader.extended_fuses=0x05
to
atmega328bb.bootloader.extended_fuses=0x06
and then burn the bootloader again?
Arduino Uno;
Mega328
Well the traces dealing with the converter and charging circuit are all polygons.  So for instance, this is what the bottom layer looks like around the buck/boost converter (TPS63001DRCT) and the top layer is a solid ground plane with lots of vias stitching the two sides together.  The thick traces leading out from there are a revision that will go in the next board.  In the board that I am working on right now, they are thin traces but the polygons directly around that little SON10 package are all there.
converter by jg1996business, on Flickr
Arduino Uno;
Mega328
Shannon Member
Lua rocks!
to
Yes that should do it. If you have a ISP programmer you shouldn't have to burn the whole bootloader. eg.
avrdude -c usbtiny -p m328p -U efuse:w:0x06:m
to
I just have the arduinoISP and the "burn bootloader" button on the arduino ide.
Arduino Uno;
Mega328
Shannon Member
Lua rocks!
Your proposed approach should work. Personally I use this sketch:
http://www.gammon.com.au/forum/?id=11638
You connect up the wires as shown (you don't need the SD card just to change fuses) and can then interrogate and change fuses through the serial monitor.
But, burning the bootloader should work OK. Assuming that the Arduino as ISP sketch actually does change the fuses.
Thanks!  I may give that a try.
Arduino Uno;
Mega328
Pages: [1] 2   Go Up
