Topic: Ethernet PHP control - I want to stay in a loop and check for a new string (Read 3573 times) previous topic - next topic
dtokez
Hi all, basically I'm working on controlling some LED's via Ethernet. The main code is working nicely and I'm checking for a quite a few strings to switch things on and off via calling separate functions, but I have gone back to the bare bones code now to try and get something new working
I would now like to add a function with a loop that runs until another string comes in from the Ethernet controller, is this possible?
I want to create a animation that runs without running through the rest of the code. I tried a method using flags so I could decipher from a run once operation and a animation, but this was long winded and is causing me some headaches.
Thanks!
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 0, 177 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
void setup(){
  pinMode(7, OUTPUT); //pin selected to control
  //start Ethernet
  server.begin();
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
          client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
          client.println("<link rel='stylesheet' type='text/css' href='http://homeautocss.net84.net/a.css' />");
          client.println("<TITLE>Home Automation</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Home Automation</H1>");
          client.println("<hr />");
          client.println("<br />");
          client.println("<a href=\"/?lighton\"\">Turn On Light</a>");
          client.println("<a href=\"/?lightoff\"\">Turn Off Light</a><br />");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("?lighton") >0)//checks for on
            digitalWrite(7, HIGH);    // set pin 4 high
          else{
          if(readString.indexOf("?lightoff") >0)//checks for off
            digitalWrite(7, LOW);    // set pin 4 low
          //clearing string for next read
          readString="";
PaulS
You have that already. It's called loop().
If are planning to wait for another string from the same client, you are going to be disappointed. The client has made a request and gone away. If another client request appears, you have no way of knowing that it is the same client you hear from last time, or another client on the other side of the world. Nor should you try to know that.
Have you looked at what the client is actually sending? Each GET request is standalone. The same client might make a series of requests, but the server has no way of knowing that it is the same client.
dtokez
Hi Paul.
Thanks for the input. That makes sense, so each time the arduino asks the controller if it has x y z string waiting for it?
so, I want to check for the animation string from the ethernet controller, then run the animation loop until another string arrives - which I have to check for.
I'm using 'if' statements to check for certain strings, and they will only be true once then the string will be gone, so how could I make the 'if' loop run continuously and check for other strings without running the rest of the loop() function running?
I hope that makes sense, maybe I am being daft and over complicating this matter?
The main code is below, currently if you go into the stars() function it appears to run only twice, but I can't see where the flag is being set back to false?
//INCLUDES
#include <SPI.h>
#include "Tlc5940.h"
//END OF INCLUDES
//DEFINES
int TLCDelay = 50;  //Delay after setting TLC
int brightness = 4095;  //Initial brightness to display
int dimStep = 0;
boolean flag = false;  //flag for animation or single shot, false = single shot
int pinNumber = 0;
// number of items in an array
#define NUMITEMS(arg) ((unsigned int) (sizeof (arg) / sizeof (arg [0])))
//int vals [] = { 1000, 1000, 500, 500, 250, 200, 175, 175, 100, 75, 40, 5};
int vals [] = {
  2047, 1024, 512, 256, 128, 64, 16, 16, 32 };
int numVal = NUMITEMS (vals); //number of values in array
//END OF DEFINES
//ETHERNET SETUP
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
String readString;
//END OF ETHERNET SETUP
//START OF MODES
void allOn(){
  Tlc.clear();
  Tlc.setAll(brightness);
  Tlc.update();
  delay(TLCDelay);
void sides(){
  Tlc.clear();
  for (int i = 0; i < 4; i++)
    Tlc.set(i, brightness);
  for (int i = 7; i < 11; i++)
  Tlc.update();
  delay(TLCDelay);
void gradient(){
  Tlc.clear();
    Tlc.set(i, 4095);
  for (int i = 4; i < 8; i++)
    Tlc.set(i, 1000);
  for (int i = 8; i < 12; i++)
    Tlc.set(i, 250);
  for (int i = 12; i < 16; i++)
    Tlc.set(i, 100);
  Tlc.update();
  delay(TLCDelay);
void frontRow(){
  Tlc.clear();
  Tlc.set(0, brightness);
  Tlc.set(4, brightness);
  Tlc.set(7, brightness);
  Tlc.update();
  delay(TLCDelay);
void middle(){
  Tlc.clear();
  Tlc.set(5, brightness);
  Tlc.set(6, brightness);
  Tlc.update();
  delay(TLCDelay);
void alternate(){
  Tlc.clear();
  Tlc.set(2, brightness);
  Tlc.set(9, brightness);
  Tlc.update();
  delay(TLCDelay);
void stars(){
  Tlc.clear();
  Tlc.set(pinNumber, brightness);
  Tlc.update();
  pinNumber++;
  delay(100);
  delay(TLCDelay);
  flag = true;
//END OF MODES
//START OF DIMMING CONTROL
void up(){
  if ((brightness + vals[dimStep]) < 4095)
    brightness = (brightness + vals[(dimStep - 1)]) ; //set new brightness level
    dimStep--;
  Serial.println(brightness);
  Tlc.update();
  delay(TLCDelay);
void down(){
  if (dimStep < numVal)
    brightness = (brightness - vals[dimStep]); //set new brightness level
    dimStep++;
  Tlc.update();
  delay(TLCDelay);
//END OF DIMMING CONTROL
void setup(){
  Tlc.init(0);
  //start Ethernet
  server.begin();
void loop(){
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
          client.println();
          client.println("<link rel='stylesheet' type='text/css' href='https://dl.dropbox.com/u/33809233/a.css' />");
          client.println("<meta name=\"viewport\" content=\"user-scalable = yes\" />"); //?
          client.println("<meta name=\"viewport\" content=\"width=device-width, height=device-height, initial-scale=1, maximum-scale=1\" />");
          client.println("<a href=\"/?lighton\"\">All On</a>");
          client.println("<a href=\"/?lightoff\"\">All Off</a><br />");
          client.println("<a href=\"/?up\"\">Up</a>");
          client.println("<a href=\"/?down\"\">Down</a><br />");
          client.println("<a href=\"/?sides\"\">Sides</a>");
          client.println("<a href=\"/?gradient\"\">Gradient</a><br />");
          client.println("<a href=\"/?frontRow\"\">Front Row</a>");
          client.println("<a href=\"/?alternate\"\">Alternate</a>");
          client.println("<a href=\"/?middle\"\">Middle</a><br />");
          client.println("<a href=\"/?stars\"\">Stars</a><br />");
          delay(1);
          //stopping client
          client.stop();
            allOn();
            flag = false;
          else if(readString.indexOf("?lightoff") >0)
            Tlc.setAll(0);
            Tlc.update();
            delay(TLCDelay);
            flag = false;
          else if(readString.indexOf("?sides") >0)
            sides();
            flag = false;
          else if(readString.indexOf("?gradient") >0)
            gradient();
            flag = false;
          else if(readString.indexOf("?up") >0)
            up();
          else if(readString.indexOf("?down") >0)
            down();
          else if(readString.indexOf("?frontRow") >0)
            frontRow();
            flag = false;
          else if(readString.indexOf("?middle") >0)
            middle();
            flag = false;
          else if(readString.indexOf("?alternate") >0)
            alternate();
            flag = false;
          else if(readString.indexOf("?stars") >0 || flag == true)
            stars();
          readString="";
//Tlc.set(1, 0);
//Tlc.set(15, 0);
for (int i = 4095; i > (0-1) ; i--)
Tlc.set(15, i);
Tlc.set(10, i);
Tlc.update();
delay(1);
Tlc.set(9, 0);
Tlc.update();
delay(100);
dtokez
Hi Paul.
The main code is below, currently if you go into the stars() function it appears to run only twice, but I can't see where the flag is being set back to false? - I'm sure there must be a less clunky way of doing this without messing around with flags?
//INCLUDES
#include <SPI.h>
//END OF INCLUDES
//DEFINES
int dimStep = 0;
int pinNumber = 0;
int vals [] = {
//END OF DEFINES
//ETHERNET SETUP
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
String readString;
//START OF MODES
void allOn(){
  Tlc.clear();
  Tlc.update();
  delay(TLCDelay);
void sides(){
  Tlc.clear();
  Tlc.update();
  delay(TLCDelay);
void gradient(){
  Tlc.clear();
    Tlc.set(i, 4095);
    Tlc.set(i, 1000);
    Tlc.set(i, 250);
    Tlc.set(i, 100);
  Tlc.update();
  delay(TLCDelay);
void frontRow(){
  Tlc.clear();
  Tlc.update();
  delay(TLCDelay);
void middle(){
  Tlc.clear();
  Tlc.update();
  delay(TLCDelay);
void alternate(){
  Tlc.clear();
  Tlc.update();
  delay(TLCDelay);
void stars(){
  Tlc.clear();
  Tlc.update();
  pinNumber++;
  delay(100);
  delay(TLCDelay);
  flag = true;
//END OF MODES
void up(){
    dimStep--;
  Tlc.update();
  delay(TLCDelay);
void down(){
    dimStep++;
  Tlc.update();
  delay(TLCDelay);
void setup(){
  Tlc.init(0);
  //start Ethernet
  server.begin();
void loop(){
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
          client.println();
          delay(1);
          //stopping client
          client.stop();
            allOn();
            flag = false;
            Tlc.setAll(0);
            Tlc.update();
            delay(TLCDelay);
            flag = false;
            sides();
            flag = false;
            gradient();
            flag = false;
            up();
            down();
            frontRow();
            flag = false;
            middle();
            flag = false;
            alternate();
            flag = false;
            stars();
          readString="";
//Tlc.set(1, 0);
//Tlc.set(15, 0);
Tlc.set(15, i);
Tlc.set(10, i);
Tlc.update();
delay(1);
Tlc.set(9, 0);
Tlc.update();
delay(100);
PaulS
The Arduino is a server, when running your code. It doesn't ask anything anything. It responds when asked.
What might be confusing is the nature of the questions asked by the clients. What a client is asking the server is "Can you do something (with this data)?". That isn't really any different from the client asking "What is the temperature?" or "What are all the URLs on the Arduino site containing "PROGMEM"?" The supplied data doesn't change the fact that the client is asking the server a question.
If you mean that the if statement will only resolve to true once per client request, that is probably true. The client data doesn't go away just because you checked whether it contains a particular string, though. So, I'm not entirely sure that I understand the question.
I'm not sure that either assertion is true. Without seeing what the client asks, it's hard to understand what you want to do. From looking at the server page, though, it appears that each request from the client is a separate event, not something that could be used to put together any kind of animation. That is, the client request defines one frame of a movie, not a whole movie.
dtokez
Hi again Paul
Sorry I was babbling a bit last night and not making much sense!
Basically, this is what my code does currently...
check for string
if string arrived - turn something either on or off
run loop again to check for strings (if statements)
This is what I would like to do...
check for string
if string arrived - turn something on or off, or start animation sequence
continue running animation sequence and run main loop again to check for strings (if statements)
I think I have over complicated the matter, I have an idea. If I put all the if statements to test for strings into a function I could sit in a loop to run the animation and call the function to check for other strings, if any are true it would exit the loop?
Still not sure on the best way of doing it though
PaulS
There is still the assumption, incorrect, that the client can send more strings. It can't. It sends all the data needed to satisfy one request at one time. The "animation" you are looking for comes from the same client making multiple requests in the proper order with minimum delay between requests. There is nothing that the Arduino can do to get multiple requests from the same client any faster than the client makes requests.
afremont
If I understand you, you wish to have an animation (something like a screensaver) running until a network request comes in.  I take it that you "poll" something to see if the request has come in.  You then want to process the single request of adjusting some LEDs I think.  You then want to go back to the animation.  Is that correct?
If so, then you insert your poll of the network controller somewhere inside the animation process like inside a loop or procedure that frequently executes.  When you detect something, just handle it from within the animation or float some kind of signal up to the main level loop() to handle it.
Experience, it's what you get when you were expecting something else.
dtokez
This is pretty much what I'm trying to do, sorry for being rubbish at explaining myself  :~ lol I will try the approach you mentioned, many thanks :)
dtokez
OK, right I'm trying this idea on my basic working code but having some trouble.
The command enters the flash function, in which I have an infinite while loop. The LED flashes as I would expect and the program stays in the loop, but when I press another button on the browser I get no response from the arduino and get a 404 error.
I'm not sure where I'm going wrong here, I'm calling the checkString function on each loop?
#include <SPI.h>
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
String readString;
void checkString(){
  else if(readString.indexOf("?lightoff") >0)//checks for off
  else if(readString.indexOf("?flash") >0)
    Serial.println("test");
    flash();
  readString="";
void flash(){
  int i = 0;
  while (i == 0){
    delay(100);
    delay(100);
    checkString();
void setup(){
  //start Ethernet
  server.begin();
void loop(){
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
          client.println();
          client.println("<a href=\"/?flash\"\">Flash</a>");
          delay(1);
          //stopping client
          client.stop();
          checkString();
zoomkat
Any reason you are using 192.168.0.177 instead of 192.168.1.177 for the arduino IP address?
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
afremont
You are calling checkString() from inside flash(), but then that recursively calls flash() again.  I don't think that's what you want.  Are the other two functions working as you expect?
I don't want to be a jerk, but I think the problem here is the design.  In my opinion, you need to get the arduino to do the flashing for you as a background operation, that way you just turn it on or off same as the other functions.  Don't let that discourage you, because we can probably get it to work without doing that yet by reversing your approach.
Perhaps we could look at the problem from the standpoint that you spend most time flashing the LED and then checking for a client connection each loop.  It's not the best way to do it, but it should work.  You can't really call checkString() unless you have a new string to look at and that only happens when you get a new client connection.  I also notice that you spit back the HTML form before processing the request, this precludes you from sending some feedback to the user about what happened should you later want to.
Save your existing sketch somewhere new, because we are about to perform major surgery on its structure.  It's time to simplify your loop() by calling functions instead of having all that code in it.  Here is some pseudo code for what I'm talking about:
loop()
 if(flashing)
    turn on LED
    delay(100)
    turn off LED
    delay(100)
  endif
  checkForClient()
end loop()
checkForClient()
 if(client)
    read request
    handle request
 endif
end checkForClient()
It's not the most responsive way to do it, but it should get the job done.  Client processing will be delayed up to 200mS while the LED is toggled.  Does this make any sense?
dtokez
Hi afremont, thanks for the advice!
I will have a go at re-structuring the code now and let you know how I get on :)
dtokez
Just trying this out at the moment, does not work though. The LED starts flashing but again after that the arduino does not respond?
#include <SPI.h>
boolean flashing = false;
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
String readString;
void checkFor(){
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
          client.println();
          client.println("<a href=\"/?flashing\"\">Flashing</a>");
          delay(1);
          //stopping client
          client.stop();
          else if(readString.indexOf("?flashing") >0)
            flashing = true;
          readString="";
void setup(){
  //start Ethernet
  server.begin();
void loop(){
  if (flashing == true)
    delay(100);
    delay(100);
    checkFor();
  checkFor();
dtokez
ok, this seems to work finally.
But it seems clunky having to set 'flash = false' on the other if statements, especially when I end up with more animation loops and commands to turn outputs on and off.
Is there a better way to do it?
//simple button GET server code to control servo and arduino pin 5
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//for use with W5100 based ethernet shields
//Powering a servo from the arduino usually DOES NOT WORK.
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
boolean flash = false;
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
String readString;
void setup(){
  //start Ethernet
  server.begin();
void loop(){
  if (client) {
          readString += c;
          Serial.print(c);
        if (c == '\n') {
          client.println();
          delay(1);
          //stopping client
          client.stop();
            flash = false;
            flash = false;
            flash = true;
          readString="";
  if (flash == true)
    delay(100);
    delay(100);
